My out board motor t9.9EXR - Washing Machines
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 14, 2014 | Minolta Office Equipment & Supplies
I have canon np 6650 it shown E010. i have try to reset, checking the fuse on the dryer paper please help me
if error E010 occure, it means your Main motor not running,
motor or motor drive board or mother board problem,
if show E010 after running the main motor, check motor driver board or mother board,
but 99.9% case of E010, cause of main motor problem so check the main motor first,
Aug 11, 2011 | Canon NP 6650II Copier
Maytag Neptune MLE2000AYW won't spin, motor wont ever move during motor control test in service document, I never get any output on the motor output leads to drive the motor. Switching power supply just...
Three places I check for appliance parts, besides the local appliance repair store, are:
RepairClinic: http://www.repairclinic.com/Circuit-Board-Or-Timer-Parts?s=t-MLE2000AYW-%3d%3dc13
AppliancePartsPro: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47166
ApplianceZone: http://www.appliancezone.com/SearchProducts.aspx?id=MLE2000AYW&ctl00%24MainContent%24btnSearch=GO%21
It sounds like you have gone through the tests in the Service Book, and usually when the motor won't spin it is the control board, the motor, or the wiring harness. If you are getting no power from the leads on the control board to the motor, I would replace the control board. If you had or have any codes that come up on the machine, what are they? I have had to replace many motor control boards, and everytime it gets the machine going again. Only a few times did I actually have to replace the motor. It sounds like your motor is fine though. The most common cause of failure in these motor control boards is electrical surge. Many control boards now have built in surge protection to help prevent failures.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 22, 2011 | Maytag Neptune MLE2000A Front Load Stacked...
Will not complete cycle..shows F11. This has been an ongoing problem, cannot get anyone to fix. What would you recommend? Would like to tell the world not to buy!
The F11 error code indicates a serial communication problem between the central control board and the motor control board. This can be caused by:
  • A loose or failed wire harness connection between the central control board and the motor control board.
  • A bad wire harness connection between the motor control board and the drive motor.
  • A failed drive motor.
  • A defective motor control board.
  • A failure in the central control board.
Jan 23, 2011 | KitchenAid KHWS01PMT Front Load Washer
The tub that holds the clothes does not spin. The water goes in and it takethe soap and softner but will not spin. The timer works and it seems to go through the cycles and fillls and emptys but the tub...
I've only seen one of these belts break in my 7 years of fixing Neptune's. I have replaced dozens of motor/ motor control board kits. Maytag upgraded the washer motors about 5 years ago, if yours is older it's probably got the older style motor. If that's the case you need to verify that the motor control board is getting power from the main control board, if it is, then you need to replace both the motor and motor control board (it comes as a kit). If it isn't you need to put 120 volts to the motor control board and see if the motor spins at 50 rpm (normal agitate speed), if it does, you just need the main control board, if it still doesn't run you need the main board and the motor/ motor control kit. If it has the newer motor, you would also need to test and replace the motor and/ or the motor control board separetly.
Jul 15, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer issues
Could be just about anything. It's all designed to prevent it from spinning if there is a problem. If the motor is still turning, but never gets up to spin speed, check the out of balance circuit. There are two cabinet strike switches and an inertial unbalance switch. Or check the door latch assembly, it's possible for the door to lock enough to turn the 'door lock' light on, but not move far enough to actuate the 'spin enable' switch. Maytag has upgraded the motor/ motor control board for the older Neptunes. If the motor is not running at all, check that the main control board is sending power to the motor control board. If it is you need the motor/ motor control kit (just one part #) If the main board is not sending power to the motor control board, you need a main control board, but you still need to test the motor control board. Take a test cord and put 120 volts to the motor control board, the motor should start turning at 50 rpm (normal agitate speed) if it doesn't you would need the motor/ motor control kit as well.
Jul 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
paul
paul
