Question about Dmm Serpentine Belt Tool
Install serpentine belt for 1999 lincoln continental. Need to learn how to move the tensioner.
  • 3 Answers
Tensioner generally has a bolt recessed within the pully. A torq wrench or ratchet with a long poll is needed to much the pully up or down. The tensioner places alot pressure on the belt to keep it on track. You will have to pull or push very hard to move it will puting the belt on.
Posted on Aug 02, 2009
Water pump 98 lincoln contenianal
If your engine looks the same as the video, the pump can removed without having to move other components out of the way.
Drain radiator
Loosen the pump pulley bolts with the serpentine belt still on. This will put tension on the pulley so it doesn\'t turn. Then take serpentine belt off. Then remove the four bolts on the water pump. Have a drip pan under the pump. Clean pump mating surface on the engine. Install new pump with O ring. The link below gives detailed info.
How do you replace the water pump on Lincoln Continental
May 21, 2014 | 1998 Lincoln Continental
How do you replace the fan belt tensioner on a 2000 lincoln continental
I`m pretty sure your belt tensioner pully is just held on with a couple bolts.Remove your serpentine belt,your main belt.look at the pulley see where the bolts are that hold it on and remove them.They are spring loaded so when u take it off make sure you have the new one to put on because once you remove it ,it is no good and have to put the new one on.
Apr 02, 2014 | 2000 Lincoln Continental
Serpentine belt
There is a belt tensioner that has to be moved to release the tension on the belt. Once the tensioner is moved you can remove the belt and install the new one. Sometimes you need a special tool to move the tensioner.
Make sure you have a drawing of the routing of the belt, normally there is a sticker on the hood or the radiator support.
Apr 25, 2013 | 1995 Lincoln Continental
Diagram for installing serpentine belt on a 1999 lincoln continental
Hope this helps, it it does please leave feedback Thank You and Good Luck
Drive Belt
fm99contn_303.05-002a 81868861
Jan 01, 2011 | 1999 Lincoln Continental
How do you get the serpentine belt back onto a 1999 lincoln continental? we can't figure out how to put slack in the belt to get it back on the alternator.
there is a belt tensioner pulley you must lever back to produce the slack needed to slip on the belt. There is a socket type cutout behind the pulley. put in the appropriate size ratchet handle or breaker bar and move tensioner arm back against the spring tension on the pulley. slip on belt making sure the grooves of the belt are in the pulleys correctly
Nov 02, 2010 | 1999 Lincoln Continental
How do i replace the serpentine belt on a 98 mk vIII
Click on the following free direct Link. It has the correct Serpentine Belt Diagrams for your 1998 Lincoln Mark VIII for your 4.6L V8 Engine Options (AC/No AC etc.).
Let me know if this helped, or if you have additional information questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/1998/make/lincoln/model/mark_viii/1998_lincoln_mark_viii_drive_belt_routing_diagram.htm
"HOW TO":
Standard Rules to Removal the Serpentine Belt with an Automatic Tensioner:
1. Find the Tensioner(s). (See Diagrams on Link)
2. Using a Serpentine Belt Tensioner Tool, Or Wrench OR Ratchet, Rotate/Move the Tensioner USING THE AVAILABLE NUT (on the Pulley or Arm Base) OR the OPENING (3/8ths or 1/2 inch square opening) rotating the Tensioner Pulley/Arm - moving it away from contact with the belt and towards the area where the belt is not in contact with the Tensioner Pulley. The Tensioner is spring loaded, and is hard to rotate/move.
3. Remove the loosened belt off one of the other more easily accessed Pulleys.
4. DO NOT quickly release the Tensioner, but gently allow the Tensioner to rest in its closed position.
Standard Rules for Installing the Serpentine Belt with an Automatic Tensioner:
a. Pick a Pulley that is most easily accessed. This will usually be on top. This will be the last Pulley that the belt will go on.
b. Using the Diagram: Install the new Serpentine Belt on the remainder of the Pulleys....over, under, left right.
c. Using a Serpentine Belt Tensioner Tool or Wrench or Ratchet Tool: Rotate/Move the Tensioner Pulley/Arm "away" from Belt contact area on the Tensioner. This spring is pretty hard and with a new belt, it will be even harder to install. Rotate/Move this to as-close to the maximum allowed inorder to have enough slack in the belt to get it up and over the last pulley.
d. Using your other hand - Pull the Belt up and over the Last remaining Pulley.
e. Before releasing the pressure on the Tensioner, visually inspect the remainder Pulleys and the Belts' Positioning on them
Feb 15, 2010 | 1998 Lincoln Mark VIII
1997 lincoln Continental serpentine belt change
you need to find which pulley is the belt tensioner. use a socket and a breaker bar to lift the tensioner. once the belt loosen, slide the belt off one of the pulleys close to you. then slowly release the tensioner.
Oct 24, 2009 | 1997 Lincoln Continental
How do i get to the serpantine belt on 96 lincoln continental
Step 1 Inspect the belt already in your Lincoln for cracks or wear. It is best to replace serpentine belts early, before any major damage occurs, as a break in the belt will cause a critical failure in a motor vehicle while under power.
  • Step 2 Find the belt routing diagram under the hood, this can usually be found on the top of the radiator mount. Lincolns, even those of the same year model, may have different accessories run by the serpentine belt. So the exact routing of the belt will vary from vehicle to vehicle.
  • Step 3 Loosen the tensioner pulley until you can push it relatively easily. The belt should still be too tight remove, if it is not the idler pulley is malfunctioning.
  • Step 4 Unscrew the idler pulley belt until the idler pulley loosens enough to allow the belt to be removed.
  • Step 5 Make note of the direction of rotation of the serpentine belt as it is important to install the new belt in a way that it is intended to rotate.
  • Step 6 Insert the new belt in accordance with your Lincoln's belt installation chart.
  • Step 7 Tighten the idler and tensioner pulleys an assistant with a pry bar may be needed to properly tighten your Lincoln's serpentine belt.
  • Sep 24, 2009 | 1997 Lincoln Continental
    1996 Lincoln Continental Serpentine / drive belt : I'm quite familiar w/ the belt removal & instalation process for the Merc Gr Marquis, Ford Crown Vic & Linc Town Car but, my newly purchased '96...
    you need a serpentine belt installation tool. it is a 1 inch wide 2 foot long 3/16 inch thick steel flat with holes cut out for the tensioner bolts to fit in.there is no room for a socket.the tensioner is slackened first,then the belt can go on.you need the tool
    Jul 14, 2009 | Lincoln Continental Cars & Trucks
    Installing serpentine belt for 2000 Lincoln Continental
    d273ea4.gif Item Part Number Description 1 10300 Generator 2 8509 Water Pump Pulley 3 8678 Belt Idler Pulley 4 6B209 Drive Belt Tensioner 5 3A674 Power Steering Pump 6 8620 Drive Belt 7 19703 A/C Compressor 8 6312 Crankshaft Pulley
    Mar 15, 2009 | 2000 Lincoln Continental
    Dmm Serpentine Belt Tool Logo
    189 people viewed this question
    Top Dmm Measuring Tools & Sensors Experts
    Vuk B
    Carlos Elizondo
    Carlos Elizondo
    Level 1 Expert
    Are you a Dmm Measuring Tool and Sensor Expert? Answer questions, earn points and help others
