Question about Kenmore Washing Machines
Kenmore elite washing machine spin cycle slow. The clothes are still dripping wet when removed from the washer.
In my HE3T, this was indicative of the water pump going out. In its 8th year, my HE3T is now on its 3rd water pump.
Posted on Aug 20, 2010
2 Suggested Answers
  • 311 Answers
SOURCE: My Kenmore Elite washer spins to slow cauisng the
If this is occurring mostly on heavier loads your clutch may be slipping. If you take a flathead screwdriver and push down the lid switch so the washer will spin with the lid up, grab the inside of the drum. If you can easily stop the drum its most likely a bad clutch. If you tip the washer back and see oil underneath then its probably your transmission leaking oil onto the the clutch causing it to slip (in which case you need transmission and clutch assy). If you see oil I would probably not bother calling a tech it would be a pretty expensive repair.
IF the problem is with the clutch only it may be worth repairing but to replace the clutch you will have to remove the pump, motor, transmission, and the clutch mounts on top. The other less common possibility could be a bad drive block under the inner tub. hope this helps. _MJ_
Posted on Jan 28, 2010
During the spin cycle it spins correctly until the last 2-3 minutes and then it just fluffs clothes
Some machines used a variable speed slow down process to avoid clothing damage, this removes the items from the outside of the drum where if the clothing was left for a length of time after the cycle has finished it could damage the fibres, this way the clothing is also easier to remove from the machine and promotes airflow over the items
Jun 14, 2016 | Sears Kenmore Elite 3.9 cu. ft. Front-Load...
WSM2480 Clothes Still Wet After Slow Spin Cycle
It's possible that the tub didn't drain properly in the allotted time and the remaining water is slowing your drum from coming to maximum extraction speed.
Jan 10, 2014 | GE WSM2420D Unitized Spacemaker Washer /...
Clothes still wet after cycle is over
Be sure drain hose is not kinked and no higher than the top of washer to drain pipe. Remove clothes as soon as it stops spinning
Jun 23, 2010 | Kenmore 23822 Top Load Washer
Have a quiet pak4 kenmore elite. the spin cycle seems to not wring out the clothes well. In some cases, the items are dripping wet. I tried running an empty cycle, (rinse and spin setting), and it seem to...
Try this: remove the front lower acces panel(below the door going acroos the lower portion of the washer)
by removeing the attaching screws and pull off, then inside you will see a cylinder shaped unit with a cap with a twist handle on it,this is the filter pump, unscrew the cap to remove the trap and clean out completely, there will be some water in it when you open it so have a towel ready to sop up the water,reassemble everything and try a load of clothes, this will fix your problem. Good luck !
Jan 12, 2010 | Kenmore Elite 45986 Front Load Washer
Clothes way too wet after washing
your washer is not hitting high speed spin thats why the cloths are still wet,bad transmission,sorry-mike
Jun 03, 2009 | Kenmore Washing Machines
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Washing Machines Logo
301 people viewed this question
fordexpert
Mike Squire
Robert Rankin
