Question about Whirlpool Ultimate Care II GSW9650LW Top Load Washer
Whirlpool ultimate care II stops after filling
Whirlpool ultimate care II stops after filling with water
    Novelist:
  • 116 Answers
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Posted on Aug 02, 2009
My Whirlpool Ultimate Care II Washer doesn't stop filling with water
If this only happens when the machine is turned on,the tube from the tub to the water level switch is pinched or broken. If the clear plastic tube is not pinched or broken,the water level switch in the control console is bad. If the machine lets water through when it is in the OFF position,the water valve where the hoses connect are bad.
Dec 27, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Wont stop filling with water
You need to replace the fill switch its not sensing or stopping the w ater. It is fairly simple. Remove the plastic molding on the ends. Remove two screws holding down the control panel. The fill switch is over to the left, and has a clear tube attached to it. Remove tube and wires, lift tab keeping it from turning, turn 45 degrees and remove switch. Replace and test in all positions. Good luck whirlpool is a good brand.
Jul 12, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Fills up with water and wont stop
Bad Preasure valve comes to mind first and formost it acts like a level sensor balanceing the size indicated for fill.
Feb 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My washer machine Whirlpool Ultimate Care II LSQ9549L is leaking water when I fill the tub with water. I opened cabinet and there is a small white box below the tub that is dripping water. My questions are...
is it filling filling filling and not stopping. or will it fill and stop when it is supposed to. if it's fill fill filling could be a hole in the pressure hose or a faulty pressure switch. but if itt does all the cycles and is leaking you probably have a bad pump tip the unit back a little so you can see under but do not tip all the way you will see the pump. see if it leaking if so replace tha pump.
Jan 04, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Yes if its filling slow do to a blockage in a screened hose it will .If it never stops filling and doesnt over flow than its syphoning the water and you need to elevate thr drain hose higher than the water level and it will kick into wash. Please rate This !!
Jul 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II GSW9650LW Top Load Washer Logo
539 people viewed this question
Dan Webster
Dan Webster
Sal De
