Question about Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100)
SB5100 Docsis 2.0 Upgrade from Docsis 1.1
My local cable company recently upgraded their system to Docsis 2.0 but my sb5100 is at Docsis 1.1. They advised me that I need to change my modem that has the new Docsis since I've had this modem for over a year. Of course, they will charge me a whopping $100 for the new modem.
I would like to know if I can upgrade the firmware from 1.1 to 2.0 on my modem.
  • manuelic Jun 28, 2008
    yes, i have the same problem, but i habe CableModem SB5100 and SB5101 in DOCSIS 1.0 and 1.1, please tell me, what can i do ?
Technical Details
  • Model: SB5100
  • Type: External, platform-independent modem with HTML-based user interface for status troubleshooting
  • Standards: Integrated DOCSIS 2.0 A-TDMA and S-CDMA technology
  • PC interface: USB for Windows 98/2000/XP
  • Cable interface: F-Connector, female, 75 ohms
  • CPE network interface: USB, Ethernet 10/100BaseT (auto sensing)
  • LED indicators: Yes (front panel)
  • Users: Supports up to 32 users (1 via USB and up to 31 via Ethernet or 32 users on Ethernet)
  • Power: Internal power supply: 9 Watts (nominal)
  • Input power: 100-240 VAC, 50-60 Hz
  • Excite@Home Level 2 Approved: Yes
  • Bridging: Ethernet and USB connections are bridged allowing LAN traffic between USB device and Ethernet LAN
  • Networking: 10/100BaseT Ethernet (auto sensing)
  • Remote management: Yes (via SNMP)
  • Software upgradeable: Yes (over the network)
  • Top-mounted stand-by button: Yes (enhances network security to end-user)
  • Troubleshooting: HTML-based diagnostic user interface
  • Global safety approval and certificates: CB scheme (EN60950/IEC950), CE-Evaluation test report (EN55022/EN55024), FCC Part 15, UL 1950
  • Downstream demodulation: 64 or 256 QAM
  • Downstream maximum data rate: 38 Mbps
  • Downstream bandwidth: 6 MHz
  • Downstream symbol rate: 64 QAM 5.069 Msym/s
  • Downstream symbol rate: 256 QAM 5.361 Msym/s
  • Downstream operating level range: -15 to +15 dBmV
  • Downstream input impedance: 75 ohms (nominal)
  • Downstream frequency range: 88 to 860 MHz
  • Upstream modulation: 8, 16, 32, 64, 128 QAM or QPSK (with A-TDMA or S-CDMA enabled CMTS)
  • Upstream maximum data rate: Up to 30 Mbps
  • Upstream bandwidth: 200 kHz, 400 kHz, 800 kHz, 1.6 MHz, 3.2 MHz, 6.4 MHz (with A-TDMA or S-CDMA enabled CMTS)
  • Upstream symbol rates: 160, 320, 640, 1280, 2560 and 5120 ksym/s (with A-TDMA or S-CDMA enabled CMTS)
  • Upstream operating level range: A-TDMA: +8 to+54 dBmV (32QAM, 64QAM), +8 to+55 dBmV (8QAM, 16QAM), +8 to+58 dBmV (QPSK), S-CDMA: +8 to+53 dBmV (all modulations)
  • Upstream output impedance: 75 ohms (nominal)
  • Upstream frequency range: 5 to 42 MHz (edge to edge)
  • Data protocol: TCP/IP
  • Operating temperature: 0 degrees to 40 degrees C
  • Storage temperature: -30 degrees to 80 degrees C
  • Operating humidity: 0 to 95 percent R.H. non-condensing
  • System requirements: Windows 95/98/2000/NT/Millennium, Macintosh, UNIX
  • Width: 2.3 inches
  • Height: 6.2 inches
  • Depth: 6 inches
  • Warranty, parts: 1 year
  • Warranty, labor: 1 1year
Posted on Dec 24, 2007
  • 2 more comments
  • mufasacfc Dec 24, 2007
    Also if you type in in the browser wile the mode is connected it should pull up the internal config of the modem.
    if it does click on the help tab and you should see the following
    Software Version: SB5100-
    Hardware Version: 2
    MIB Version: II
    GUI Version: 1.0
    VxWorks Version: 5.4
    and you should see this for firmware version 2.0 and above.
    Hardware Version: 3
    MIB Version: II
    GUI Version: 1.0
    Frequency Plan:
    North American Standard/HRC/IRC
    Upstream Channel ID:
    Frequency (Hz):
    DHCP Server Enabled
    The SURFboard cable modem can be
    used as a gateway to the Internet by a maximum of 32 users on a Local
    Area Network (LAN). When the Cable Modem is disconnected from the
    Internet, users on the LAN can be dynamically assigned IP Addresses by
    the Cable Modem DHCP Server. These addresses are assigned from an
    address pool which begins with and ends with Statically assigned IP addresses for other devices on
    the LAN should be chosen from outside of this range
    Resetting the cable modem to its factory default configuration will
    remove all stored parameters learned by the cable modem during prior
    The process to get back online from a factory default condition could take from
    5 to 30 minutes. Please reference the cable modem User Guide for details
    on the power up sequence.
    resetting the modem should sync up with the new Docsis 2.0 settings and features
    • DOCSIS® 1.1 and DOCSIS® 2.0 Certified
    • Front-panel LEDs to indicate status
    • User-friendly online diagnostics page
    • Supports standard Internet software
    • Specially designed architecture allows for future
Hardware Version: 1
MIB Version: II
GUI Version: 1.0
Posted on Sep 28, 2008
Sir i have a motrola sb5100 modem so i upgrade my modem flash ic with jtag cable but i do not have jtag cable sir please help me that i am making my own jtag cable but i have not jtag cable pin connection...
Those modems update the firmware automatically. That modem could be as much as 10 years old. As for JTAG upgrade of firmware, you are making this way too hard and expensive. The Jtag is only part of the issue. You have to have an EEPROM flashing machine to connect the cable to and those are not cheap.
Nov 20, 2017 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
I want the username and password to my router its a motorola sb5100i
I believe this device is managed by your Internet provider (cable company), and you cannot access it andmanage it like a Netgear or Linksys router you woudl get from your local electronics store. Who is your Cable Internet provider?
Feb 11, 2010 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Try to install the same driver for Windows xp
in windows 7 in Compatibility Mode
For running in Compatibility Mode in windows 7
Right Click the app and select the properties
select the Compatibility Tab
select the os =windows xp sp3
and dont forget ti tick "Run ad Administrator"
Download Here th driver(xp)
Feb 10, 2010 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
I need the driver for the motorola modem sb5100 usb
Jan 20, 2010 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Does the Motorola SB5100 SURFboard Cable Modem Work with XBOX Live?
You can find information on getting hooked up with your modem here
Good Luck!
Jan 05, 2010 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
I am about to change from dial up to broadband using Motorola's SB5100 series cable modem which was given to me. Should I remove the dial up bits from my computer before installing the SB5100, or just...
It is best to remove the dial up portions because it will help eliminate confusion within your system as to which connection to use. You will be much happier once you get hooked up with broadband....good luck.
Oct 13, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Need new ip and mac adress for sb5100 motorola for southwest
To get new IP unplugg power for 1 minutes the plug the power back in. MAC address is a unique identifier specific to that modem. To get a new MAC address you will have to buy a new modem.
Sep 13, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
I need to setup my motorola SB5100 cable modem to accept remote desktop connections. can anyone help?
by defualt it should be able already- you may want to check your computer and make sure there are no firewalls blocking you.
May 13, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
System can't Install the MODEM Drivers
You would need to install the USB drivers from the Motorola disk as windows does not have these USB drivers natively.
Jul 03, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
My power button blinks and the tv screen is black no picture what so ever
Call your cable company that indicates a billing / account problem in their systems.
May 15, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100) Logo
4,953 people viewed this question
Top Arris Computers & Internet Experts
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
