Question about Teac FD-05PUB External Floppy Drive
I have an old model (P/No 19308801-82), and want to copy floppy files before ugrading my Mac beyond the "classic" environment. The drive seems to work but the G4 doesn't recognize it even in classic.
  • Shehu Salihu May 11, 2010
    Hi, Please what browser are you using? Is it apple safari?
2 Suggested Answers
MalKontent68
  • 748 Answers
SOURCE: Can't get my TEAC External Floppy Drive FD-05PUB
Was it ever recognized?
Is it recognized on other computers?
Notebooks sometimes have poor power output on USB sockets; try all available USB sockets, and as a next step try a POWERED USB hub - ie a hub with it's own, separate power supply.
Posted on Aug 08, 2010
Can I use a Bytecc BT-144 usb external floppy disk drive with an iMac running OS 10.10.1?
I'm not a Mac tech, but I wouldn't see why not. Floppy drives are kinda old school now. You may need a driver for the floppy. Check online and see what you can find. Download and install it.
Or you may have to plug the floppy in, then reboot, to get the Mac to recognize it, especially with a USB port. Some old Windozz machines were like that...maybe your Mac too????
Mac OS is very close to Linux/Unix systems, which have awful support for floppy drives. That's another possibility.
If your windows machine can't read the disk, makes me think the floppy drive is bad or you have corrupted files on the disk. Try a couple known good floppy disks on the Windoz box and see what happens. Or another removable floppy drive. They cost $5 to $10 now.
Jan 22, 2015 | BYTECC (BT144) External Floppy Drive
Backyard 2001 wont work for my mac it keeps saying the classic environment is no longer supported. can i get it to work?
In short, no. Apple has completely dropped support for the classic environment. It's a simple case of out with the old and in with the new.
So another words any applications that requires the classic environment will not work anymore, within the new operating system.
Nov 29, 2010 | Apple MacBook Pro Notebook
Same problem with my MPF82E
You see floppy drives are pretty old technology compared to the Vista environment which is the latest. Your floppy external drive will most likely run better in the Windows XP environment along with the necessary drivers on device manager under control panel...and those drivers you can also download. Am sure it will work better with windows 98 or XP.
Thanks & Kind Regards
Sep 10, 2009 | Sony (MPF82E-U1) External Floppy Drive
I wanted to copy some files from a floppy disc to my external hard disc formated for Mac but there seems to be mechanical problems and it says it is unreadable and wants me to reformat it. I bought a new...
Copying files from Floppy Drive to External HDD.
01. Ensure that both Floppy drive and External HDD are configured properly in the machine.
02. Sometimes if virus affected the files of floppy drive, will not copy the full files.
03. Close the small led in the floppy top right side and check once again.
04. In start program, type coimmand and the dos prompt with Drive will appear.
05. keyin Dir A: and see it reads all files.
06. There also it gives error, you cannot copy these files to External HDD.
07. Try to use some other floppier which is already formatted.
08. Ohrr solution is just copy all these files from the floppy drive on to C: and copy the same files after creating a folder in C Drive.
09. Check the Interlink cable is also working fine.
10. If the problem not solved, please call authorized system service engineer to sort out the issue..
Mar 05, 2009 | Imation (01946) External Floppy Drive
I have an 8 GB PNY Attache flash drive that can be read by a Windows XP operating system but not on a Mac OS X operating system. The problem is even more confusing because a Mac that can run both Windows...
You may have the drive formatted in a way that the Mac cannot read. If you go to your "My Computer" in XP, find your drive, right click on it, look for something that says either NTFS or FAT32. If it's NTFS, the Mac won't read it.
You can copy files off the drive and then reformat it, also with a right-click in that My Computer menu. Format to FAT32. FAT32's major limitation will be no files over 2gb each.
There is free software out there that will -try- to read and write NTFS drives. It worked for me, but killed my brother-in-law's Mac.
http://macntfs-3g.blogspot.com/
Dec 05, 2008 | Computers & Internet
Nexxtech usb external floppy drive
The simple answer to your question is yes. The trick is getting the external floppy drive.
If you have one you should be able to connect it to you mac and simply drag the files on to your desktop. Depending what the files are you should then be able to still read them and save them on the mac in a new format.
It really depends on what format the files are and what app they where created in.
Floppy disks! I have not come across them for years! The process is quite slow!
Sep 30, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Copying disskette from hard drive
copy d:\ <path to file> a: <enter>
try that and see if it works
Aug 20, 2008 | Ye Data (YD8V07) Internal Floppy Drive
Transfer of files.
I recommend using a thumb drive (usb flash drive). They are cheap, very convenient and easy to use. If it is a very large amount of data to be transferred, then I would recommend getting an external hard drive that plugs into your usb.
Jun 27, 2008 | Computers & Internet
Teac FD-05PUB External Floppy Drive Logo
51 people viewed this question
Top Teac Computers & Internet Experts
k24674
Computer Links
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
