This is the Model of my Gateway T4C831007038 My issue is that when the computer is starting up it restarts right after the Gateway symbol pops up and I never get to the point where it lets me choose a username and log in. I have tried several times to use the "Windows Vista Home Premium 32 Bit with SP1 Operating System Disc" that came with it to fix the startup issues and it wasn't able to fix it.
  • 10 more comments
  • jenniemarina Aug 02, 2009
    I've tried everything so far and it hasn't fixed it yet.
    I still cannot figure out if I did everything correctly that the expert asked me to do.
    That didn't work either. I forgot to mention that I already tried to set it to an earlier date.
    It seems like my files and stuff are still there but I cannot get to them
    It does beep when I press F8 over and over again
    The laptop is just over the 1 year warranty. Just my luck!
  • jenniemarina Aug 03, 2009
    Is there anything else besides resetting to an earlier date, pressing delete in the beginning, and pressing F8 continuosly? I've tried all of that and also tried to fix startup issues on my installation disc.
    So since the hard drive is not being detected, I would definetly have to take it to a tech to have it fixed?
    Does that also mean that I will possibly lose my data?
    I was advised that perhaps my hardrive isnt getting recognised...does that mean I will lose my data and do I have to take this to a tech to repair for sure or is there anything else I can do?
    I tried that before and it just kept beeping. I also tried to reset it to an earlier date. I'm concerned about losing my files since I was in the middle of writing a book and poetry collection. Luckily my photos and home videos are safely stored on discs though.
    ok, I'm at work right now. When I get home tonight I will email you back after I check out the beeping pattern and such. Thanks.
  • 15,935 Answers
During bootup - by pressing F8 continuously - you will be given the selection to enter safe mode.
Do so.
Have you recently installed/deleted a program(s)?
Once you are able to boot in safe mode - re-post and we can give you more instructions.
Please accept this answer to remove it from the work queue.
Posted on Aug 04, 2009
Hi there
I understand you've been through correspondance with some experts here but haven't yet come to solving the problem. I have read through your replies and I usually do manage to resolve issues like this so I'd like to work with you to try and target the fault. Appologies if you've done some of the following because I am unable to read other expert's replies here, only yours.
Firstly, when the Gateway logo goes, and the computer restarts, just at the moment the Gateway logo disappears, does ANYTHING appear on-screen? No matter how quick it is, or even if you see a black window after the Gateway logo with a flash cursor, does ANYTHING at all appear or does it just immedietely restart after the Gateway logo?
Secondly, if you simply turn it on and wait for it to restart itself without touching anything, do you hear any beeps? If so, what it is pattern of beeps (like 2 quick beeps and 1 long beep)?
This should help me continuing to assit. Please do not rate this answer just yet as I still want to assist, and if you rate this reply now, the question will just go to someone else and you'll have to start over again.
I look forward to your reply.
Thanks
Posted on Aug 03, 2009
  • 1,000 Answers
Have you tried rebooting in "safe mode"? If not, here are the steps.
  1. Restart your computer.
  2. When the computer starts you will see your computer's hardware being listed. When you see this information start to gently tap the F8 key repeatedly until you are presented with the Windows Vista Advanced Boot Options.
  3. Select the Safe Mode option using the arrow keys.
  4. Then press the enter key on your keyboard to boot into Vista Safe Mode.
  5. When Windows starts you will be at a typical logon screen. Logon to your computer and Vista will enter Safe mode.
  6. Do whatever tasks you require, and when you are done, reboot to go back into normal mode.
  • Bruce Bracey
    Bruce Bracey Aug 03, 2009
    Im not sure if this didn't work for you or there has been a mistake.
  • Bruce Bracey
    If you are unable to enter safe mode, I would take it to a tech, have them backup your files and investigate the hard disk issue.
    Regards,
  • 1,272 Answers
It seems that the laptop is not able to detect hard drive. if you are not able to press F8 and get into the startup menu then the only thing you can do is to contact your computer vendor. Cause apart from these steps there is not any other step which can be performed without being physically near to the laptop.
Try and press F8 when the computer boots up and select last know goog configuration. If you do not get this step then its for sure that the hard drive is not being detected.
Good Luck
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Is this a new desktop that you are facing issues with? Have you checked whether the RAM is seated properly?
Please press F8 key while the system is starting and keep on pressing it until it asks you to boot in "Safe Mode". Also tell me if you get any beep sound when you start the computer.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Aug 02, 2009
  • Rylee Smith
    Rylee Smith Aug 02, 2009
    After pressing F8 continuosly does it ask you to boot in Safe Mode, if not then it is an issue with the RAM, RAM slot of your laptop or the processor is overheating. You'll need to get the laptop checked for overheating of processor or will need to change the RAM to correct the issue.
    Thanks
    Rylee
    President:
  • 3,278 Answers
Hello, Jennie.
Sounds like a problem with your operating system.
But, I can't tell from your comments what the expert advised you, so here goes:
1. When the system boots, boot to Safe Mode (repeatedly select F8)
2. Login to the prompt in Safe Mode
3. Select Control Panel - System - Advanced System - System Properties - System Restore and choose a recent date when your computer was working well.
Note: This will take your computer back to an earlier time, including any files (documents, etc.) that you have saved.
Hope this helps.
  • 19,396 Answers
If when you tried to reinstall Vista, the installation program started and was able to write files to har disk, but then installation failed, then the problem can be either the Windows disk used, or the hard disk drive. Sometimes you also get troubles with a faulty device that may not let the setup complete.
If you could not even start Vista setup, then you may have a faulty motherboard.
Try first unplugging power and removing laptop battery to reset, it may not work but must be done.
If you find a different windows Vista disk , try it out.
Try accessing BIOS settings and resetting to factory settings.
If optical disk is removable, pull it out from the slot.
Test the laptop with no battery and ac adapter only.
If you have two RAM modules inside, try starting the laptop with one module at once, so that you can find out if one module is faulty.
If that does not work, next thing to do is testing the hard disk with a bootable disk utility. If the disk is fine, then it can be the motherboard or a fried BIOS.
Try the suggestion in order, up to the RAM test you should not need a technician. Unplug the power. Grab RAM modules on their sides adn never touch circuits or contacts, components on boards are very sensitive.
Good luck.
G.
  • Ginko
    Ginko Aug 02, 2009
    If the computer restart before POST test , and cannot even start from CD, then it can be the motherboard, or in any case you need a technician.
    If a boot disk like Windows setup disk can start, then you can try updating bios.
HOW TO REBOOT
Click on the windows symbol, normall on the bottom left, then click on SHUT DOWN or RESTART symbol on that menu that just popped up. It is normally on the bottom right of that menu.
Mar 31, 2013 | ASUS Computers & Internet
How do i reset my gateway mt6705 computor back to factory setting
Step 1:
Click "Start" on your Windows desktop. Navigate through "All Programs" and "Gateway." Click on "Gateway Recovery Management." Click "Restore" when the Gateway Recovery Management window pops up, which will take the system back to the default factory specifications. A box will pop up asking for confirmation, click "Yes" and then "Start." You may have to enter a password as well, but only if your particular Gateway had a password set. Wait for the computer to restart. A "Restore from factory default" box will appear, requiring you to click "Next" twice in a row. Click "OK" in the box that appears next, and wait for the hard drive partition to be created. The factory default installation will then be moved over to the hard drive. Click "OK" in the box that appears and wait for a second Gateway restart. Several minutes will pass as Windows "starts for the first time." When restarting finally finishes, a "Set Up Windows" dialog box will appear. Click "Next," followed by checking the license agreement box, and then "Next" again. Enter a user name and picture, if desired, and a computer name. Also, customize the background wallpaper for your desktop, optionally. Click "Next." Click "Use Recommended Settings" on the Protect Windows-based dialog box that pops up. Set your correct date and time settings in the next box. Select your location in the following screen. Click "Next," followed by "Start" to finish. Wait while Windows checks for your individual Gateway computer specifications and adjusts accordingly. This will likely take several minutes, so leaving your computer for a short time is fine. Windows will then prepare your hardware and finish your Gateway restoration process, including the installation of Gateway Recovery Management. Once completed, your Gateway is good to go and ready at factory settings.
Feb 25, 2013 | Gateway Computers & Internet
Do you need a disc to restore a 450rog
hope this helps
Sep 21, 2012 | Gateway 450ROG Notebook
How do I reset it to factory?
hope this helps
Sep 08, 2012 | Gateway 832GM PC Desktop
Restore gateway sx2850
· Click "Start" on your Windows desktop. Navigate through "All Programs" and "Gateway." Click on "Gateway Recovery Management."
· 2
· 3
· 4
· 5
· 6
· 7
· 8
hope this helps
Jul 19, 2012 | Acer Computers & Internet
I want to know how to restore my DX4200-09 to factory settings?
· 2
· 3
· 4
· 5
· 6
· 7
· 8
hope this helps
Jun 25, 2012 | Gateway DX4200-09 PC Desktop
I have a Gateway DX-4200-09 64 bit with a Gateway keyboard model no KB-0817. For the last 6 months every time I reboot I get this error message "multimedia keyboard driver has stopped working". ...
The factory installed drivers and applications can be re-installed by using Gateway eRecovery
Click Start, and then All Programs
Click Gateway, and then Gateway eRecovery Management
You may be prompted to enter or create a password. This password will be required to use eRecovery in the future.
In the next window on the left toolbar, select Restore.
Choose Reinstall Drivers or Applications
Choose Contents
Choose the driver or application you wish to install
On the right, click the Install link and follow the prompts.
The computer should restart when installation is completed. If it doesn't restart, manually shutdown and restart the computer by pressing and holding the power button until it powers off. And then start it as you normally do.
Don't forget to rate this if it helped fix your problem.
Jan 14, 2011 | Gateway DX4200-UB001A Desktop Computer
I have gateway web camera and it says grapg render fail and wont let me start tge web cam
You have not mentioned the Operating system.
The below step should fix your issue with Webcam
1. Click on START button
2. Right click on "my computer". Or "computer" in the start menu
3. Select "Manage". Wait for the window to pop up.
4. Under system tools, select Device manager. Go to where it says Imaging devices and click sign,
5. Under it, it should display the Webcam name like ex:, "gateway USB 2.0 webcam"
6. Double click it on the Cam name and select the driver tab. Go down to Uninstall and uninstall the webcam (when it asks if you want to delete the software for it, don't select the box).
7. Click ok and It will unistall the drivers, restart the computer and after it starts back up, it will detect the webcam and re-install the drivers.
This should work.!
Sep 07, 2010 | Computers & Internet
I have a gateway computer running windows vista with a gateway multimedia keyboard. When i log into the computer a message pops up that says "multimedia keyboard driver has stopped working. A problem...
goto start right click on my computer click manage click device manager. on the right of computer management screen click keyboard right click the device and uninstall. restart your computer
Jun 30, 2010 | Computers & Internet
What is the problem you are having
Aug 02, 2009 | Computers & Internet
Computers & Internet Logo
169 people viewed this question
David Payne
David Payne
