Question about Macally Screen Protector for Apple iBook,PowerBook Series
Mac Powerbook Pro is fully charged, but the hard drive doesn't seem to be engaging--leaves just a blank white screen. We're 300 miles from the start-up disk, any immediate fixes that you can suggest?
  • 846 Answers
Try to bend and warp the bottom of the Laptop body as you are turning it on. Sometimes, if it's a motherboard issue you can get it back to work by applying pressure to certain areas (broken soldering connections under the GPU etc). If it turns on when you slightly twist the laptop body, then you will need a new logic board in the long run. There is a company in new york that carries a parts for the powerbook : Mac Repair NYC
Posted on Sep 19, 2009
  • 600 Answers
When it is off (sounds like all the time now!) remove battery and then try to start, this will reset the Pram,refit battery and start, if ok good if not try starting with the left side shift key depressed, this should cause it to start in safe mode, it disables a lot of start up options and does some housework.
Posted on Aug 22, 2009
My PowerBook G4 does not recognize internal hard drive. when i boot without cd it will not boot and i will see a question mark on the screen and a small icon that represent mac os. i have Mac OS X 10.3...
If you plugged this into a PC and formatted it you probably formatted it with NTFS or another Microsoft file format. This will not be recognized by a Mac. You will need to pop the hard drive back into your Mac and boot to the installation CD. From here you will need to go into disk utility and reformat the drive with a GUID Mac Extended format partition. If you open disk utility and the drive doesn't show up you probably have an issue with the drive controller on the logic board.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jun 28, 2011 | Computers & Internet
How do i back up a power book g4? What application do I need to do the back up?
Suchisart,
If you want a stand alone backup solution, you can download a free program called "Carbon Copy Cloner" and purchase a USB 2.0 external hard drive. You can use the CCC software to backup the entire contents of your Powerbook's hard drive or just selected files to the external USB hard drive.
If your Powerbook is unable to boot into OS X and you need to recover the files that are on the internal hard drive, you can boot the Powerbook into "Target Disk Mode" and transfer the files via firewire cable to another Mac. To do this do the following.
  1. With both Macs off connect them with a firewire cable.
  2. Turn on the Powerbook and hold down the "T" during startup.
  3. Once the large icon shows up on screen your in "TDM".
  4. Turn on the other Mac and login to your account.
  5. The Powerbook's hard drive should mount on your desktop.
  6. You'll be able to transfer your files from the Powerbook's hard drive just like you would an external hard drive, thumb drive, etc.
Don't forget to vote and leave us some feedback. :)
Thank you,
Scott Computer Services http://www.scottcomputerservices.com
Feb 16, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Apple Mac PowerBook G3 M5343
since apple drives are formatted in HSF+, a file system that windows cannon read, the chances of it even being bossible to run anything on it from a PC is very very slim.
Jan 18, 2010 | Apple PowerBook G3 Mac Notebook
Mac won't acknowledge Mybook!
try restarting your computer with the mybook plugged into it. also, leave it plugged in for a while and check back to see if it shows up on the desktop. I had a similar problem with my hard drive too, and this seemed to work.
Jul 21, 2009 | Western Digital My Book Home Edition 500...
My computer would not charge. I have an appple powerbook g4. I bought a new battery. I put the battery in. It charges. Now the computr tries to turn on it makes the start up noises but the screen is blank....
Hi, sorry to hear you are having problems,
Are you saying that your Mac was working fine with the dead battery but then when you put in the new battery, the Mac died?
Well, if that is the case it might be possible that the battery ran down to ZERO and the mac's internal battery also is dead so, it does not even know what hard drive to boot into...
So, with the Mac Shut Down, hit the power on button and then VERY QUICKLY, press the ( alt ) key and hold it until you see a blue screen with a Big right pointing blue arrow and a circular arrow.
You can let go of the key, and the mac is now looking for suitable startup volumes to boot from...
You should see your harddive appear after a minute or so... If it does not appear, then either your system is damaged or your disk is KAPUT...
How old is your Mac? It is very very common for PowerBook drives to die after 4 years without advanced warning... :(
Good luck
Mar 24, 2009 | Apple PowerBook G4 Mac Notebook
Can't get my Mac to fully boot up
your problem is probably on the hard drive. The chime sound is a file and as to be read on the hard drive.
Try this: reboot system with cmd+s hold. Then type fsck -y or fsck -f (too long to explain, one of those will work) .
the computer compute and says:
***** FILE SYSTEM WAS MODIFIED *****
type your fsck -y or -f again until the computer no longer says
after that, you type reboot, or shut down and power again.
If this does'nt work, change the hard drive (mac shop - expensive)
Feb 01, 2009 | Apple Powerbook G4 1.33GHz 512mb 60GB...
Unable to start....
your hard drive has prolly crashed, same thing happened to my buddies macbook. when he turned it on, it went to a blank screen.  Im sorry  but hopefully you still have a warranty on it bc it was 300 $ for a new hard drive that my buddy got.  take it in to apple and have them look at it.
Nov 17, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Powerbook G4 (1 GHz), 15" LCD glitchy
It could well be the ribbon cable between the screen and motherboard is knackered. Depends how brave you are at dismanteling computers, if you search on powerbook parts you may be able to find a company that scraps computers who could sell you the cable if it is a separate item otherwise it will be an expensive Apple repair!
Kevan
Nov 18, 2007 | Apple PowerBook G4 Mac Notebook
Macally  Screen Protector for Apple iBook,PowerBook Series Logo
44 people viewed this question
Top Macally Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
David
David
Paul Bade
Are you a Macally Computer and Internet Expert? Answer questions, earn points and help others
