Question about RCA Televison & Video
RCA 27F534T SDTV TrueFlat -No picture, no sound,
Hello my RCA 27 trueflat does not respond to remote or manual on and menu buttons. When you plug tv in you have no picture (black screen) and no sound. You have to manually press ON/OFF button or ON on remote to power up tv and the blue light will flash for several seconds stays on but nothing else will work, stays in that mode.
  • 1 more comment
  • kcmatic393 Aug 02, 2009
    Thanks what usually causes this problem-wear and tear or not being plugged into a surge protector and having an outage or something....What is the usual repair $$Price for this..between what & what??
    Thank You
    My RCA 27F534T SDTV TrueFLAT has no picture or sound and yuo have to plug it in and use ON/OFF manual button or ON button on remote to power it up. Once it is turned on the blue ring flashes for several seconds and no picture(black screen) and no sound and the remote and all menu/control buttons on tv does not work. You have to unplug TV to turn off again. Thanks
    My RCA 27F534T SDTV TrueFlat TV-I have to Plug the tv up push the Manual ON/OFF button to ON or push ON on the remote the tv will power up but no picture(black screen) and no sound and the blue ring light flashes for several seconds, TV does not respond to the remote control or tv manual menu/control buttons. I have to unplug tv to turn off. Thanks
  • 10,594 Answers
Seems TV got problem in deflection circuit and most probably flyback transformer is defective that is why TV is not being powered up.
Flyback Transformer is available in Part Store (below in web link) and TV expert / tech will replace it because it requires soldering expertise.
It is solution for RCA 27F534T tv.
http://www.partstore.com/Part/Thomson/RCA/270879/New.aspx?ModelMfgName=Thomson&ModelBrandName=RCA&ModelNumber=27F534T
Thanks.
Posted on Aug 02, 2009
  • 1,869 Answers
This is an overheat cut-off problem; unplug your set; remove the back cover let the set cool or, place the set near a cool source such as an AC vent then; plug the set in and, it should restart... If it does wire a 12 volt computer fan into the power supply If the problem persists; use Radio Shack component cooler spray to coolt the chips, boards etc. to find the offending very hot component while attempting to start the set
    Brigadier General:
  • 8,619 Answers
Hi
It could be due to the fly back transformer. Although this is the most common component that fails in this particular model, there might be other components that need to be checked. It has a couple of pins at the bottom that need to be soldered. The other connection is the anode.
(Red wire with cap). This wire supplies around 20 to 30 thousand volts to the picture tube and even with the TV unplugged, the picture tube still holds dangerous amount of voltage. Extreme care should be taken in disconnecting and connecting this cap.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
RCA Trueflat 27F554T sdtv / rca dvd video player drc212n components masking laptop computer screen
1) restore go to control panel , use the system restore and use the DATE that you know was working good, and fix it.
2) or go to device manager, see if there are some yellow interrogation, if there are the problem is missing or corrupted driver.
go to the website supplier computer download free the update driver. uninstall the old one, and install the new update driver. and ready.
God bless you
Jul 05, 2013 | Computers & Internet
How do i get my rca 27 in trueflat tv to receive a digital sig
If the set does not have a digital tuner in it you will need a set top box.
Jun 12, 2012 | Televison & Video
My rca trueflat goes on and off by its self
Check its main power supply regualtor section circuit board for any loose solder terminals. Resolder suspected solder terminals by applying little more fresh solder.
May 26, 2012 | RCA TruFlat 27F520T 27" TV
Rca trueflat tv lock up no remore wont turn on
To unlock this set, you must ahve its original remote control.
Mar 28, 2012 | RCA Televison & Video
My trueflat 32" toshiba tv
Hi.Your tevevion have no power.Try to check the fuse if busted.The fuse is located at the inner parts of your tv,try to remove the back cover of your tv and find the fuse near the power supply.
Jul 04, 2011 | RCA TruFlat 27F520T 27" TV
Its an RCA TrueFlat and we cannot get more than 1 channel.Cable is fine works on other TVs.
yes. you have guide plus+. on your factory remote press while tv is on, menu,7, 1, go-back, tv. simple
Nov 13, 2009 | RCA TruFlat 27F520T 27" TV
I have a RCA 27" flat SDTV purchase in
Ur power inverter board is dead.
U need new one.
Aug 20, 2009 | RCA TruFlat 27F520T 27" TV
My RCA 32 ' SDTV TrueFlat doesn't come on
sounds like you have the parental lock on to lock the buttons on the tv and the remote look in your manual for the tv to see how to fix it and if you dont have it there should be one online
Aug 02, 2009 | RCA TruFlat 27F520T 27" TV
Lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter? i have a rca univeral remote, but it will not change my tv to input or output.
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Aug 11, 2007 | RCA 27F534T TV
Televison & Video Logo
57 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
