Question about DeLonghi Ovens
Delonghi twin cooker dtc90 do fsd light comes on fan work only top element working
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    barkencoa
    • 3463 Answers
    SOURCE: fan oven on zanussi electric cooker does not heat up
    From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
    Plz rate this solution.
    Thanks.
    Posted on Dec 27, 2008
    SOURCE: delonghi professional dfs903 cooker
    have a Delonghi dual fuel DTC90DF range.
    The oven has been temperamental for a whil, working then clicking off so that you had to turn it on again and it would work for a while again. Eventually there was a bit of smoke coming through the hob and it smelt of electrical burning and stopped working all together. It is the main fan oven that is now not working.
    Please help
    Bev
    Posted on Apr 18, 2010
    • 174 Answers
    SOURCE: my cooker won't heat up
    remove the rear panel covering the fan (4 screws) from inside oven. The element is round the fan. you may see where the element has burnt through or split or distorted the element.
    Posted on Jul 23, 2010
    • 3 Answers
    SOURCE: beko dvc 62 ,all electrics tripped out ,put cooker
    The element has blown. It will cost you around
    Posted on Sep 17, 2010
    Replace cooker element in delonghi dtc 90 df fsd
    Kirsty
    Open the oven lift the element and pull back. I have replaced many in multiple brands but make sure you get the correct one by getting you stove model info.
    Sep 11, 2016 | DeLonghi Ovens
    Beko dvc 62 ,all electrics tripped out ,put cooker
    May 16, 2010 | Ovens
    Hi.i have a hotpoint creda c362e cooker the rings work grill works but main oven and top oven elements dont come on even when lights come on when switched on fan works but no heat could you help me on this...
    Hi.
    Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
    The element is located at the rear of the oven compartment behind a removeable cover.
    In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
    If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
    Hope this helps.
    Jan 09, 2010 | Creda Ovens
    Fan oven on zanussi electric cooker does not heat up
    Thanks.
    Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
    Tricity bendix fan oven
    The element is almost certainly burnt out .A replacement element is fare cheaper than a new cooker and relatively easy to fit
    Apr 07, 2008 | Ovens
    Cooker
    I just installed one in my house. I found that when you start the lower (gas) oven you need to turn the dial all the way on to 500*, push the knob in (you should hear the igniters clicking), then even when you see flames coming out of the burner, continue the ignition for 10 to 15 seconds. It should continue to stay lit thereafter.
    Apr 01, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
    Delonghi professional dfs903 cooker
    Please help
    Bev
    Jan 03, 2008 | Ovens
    Ovens Logo
    Top DeLonghi Ovens Experts
    Jason Harris
    Jason Harris
    Lollo Pop
    Marvin
    Marvin
    Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
