My ac works inside, fan comes on and blows fine ,but outside fan wont kick on just makes buzzing noise and no cold air just air
    Novelist:
  • 116 Answers
Hi, normally when your freon is low, system won't work, look for filter dryer, follow high pressure tube from compressor to condenser, filter dryer normally have sight glass where you can see freon moving in system, if there's bubbles, you need freon, freon should be charge until glass get clears, hey remember to always charge from low or liquid side of system.
Posted on Aug 02, 2009
AC Compressor running but no cold air?
If no air is coming out, the blower fan is not coming on. Find the blower fan, follow the wires back from the blower motor to a plug, unplug it, set it so the blower should be on, check for voltage across the plug. If there's about 12 volts, but the blower doesn't make any noise when you plug it back in, the motor has a problem (mine once quit like that because a moth got into it). If it buzzes, etc. the fan may be jammed.
Jul 26, 2017 | Honda Cars & Trucks
I noticed some straining noise coming from my a/c unit today. The fan on top of the condenser runs fine but as soon as the compressor tries to kick on the fan stops for a split second and you get a kind of...
You amy ahave a bvad capacitor on the outside unit. It starts the fan and the compressor. You can change this yourself. Open the outside panel and you will see a silver canister with terminals out the top. Replace this and I think your problem will go away. On the cap. it will say something like 30uf 5uf 370 ot 440 Just get these numbers and get a new one. Russ
Aug 14, 2009 | Goodman CKL24AR24 Air Conditioner
My AC unit wont blow the cold air.
if the ac outside is working, but not the furnace, means there is a control problem with the furnace, check wires in the furnace, make sure there is a blower wire plugged into the contact marked cool on the control panel of the furnace
Jul 09, 2009 | Fedders A&B Chassis A1A07W2B Air...
1999 Dodge Dakota AC no longer blowing cold. And
You may want to have the AC cleaned out.  This involves removing the evaporator and cleaning it inside out.  While you have it out, have the vents check if you have the "door" that lets the outside air in if it is working,  Just to be sure that the dust did not come from the outside.  You may also want the AC freon checked out.
Jun 09, 2009 | 1999 Dodge Dakota
Goodman air conditioner will not turn on outside
When ever you hear a buzzing like you are hearing means one thing one of the fuses on the outside disconnect box is bad. Only getting 1/2 the power. Find the bad fuse and get the same size and will be good to go. ken
May 02, 2009 | Goodman CLQ36AR49 Air Conditioner
Outside unit come on for ac but inside won't come on for ac or heat
Turn Tsat to fan to see if inside unit will come on. If it does Tstat needs replaced. If not it is fan motor or fan relay. Possible cap. Do you here the fan relay come in. If it is a Good man unit it is time delay and you wont here it. Need to know your make of unit. Rusty
Apr 25, 2009 | Heating & Cooling
1992 honda accord ex 4 door heater not blowing
You may have a clogged heater core, leaking heating cores still provide heat.
Dec 04, 2008 | 1992 Honda Accord
Heating & Cooling Logo
163 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
