Question about Garmin StreetPilot c340 GPS Receiver
Garmin c340 gps
My garmin is only 8 months old and the battery is dead. it won't charge
and it won't turn on. what do i do?
  • Neil1962 Jan 02, 2008
    My Garmin street pilot 320 cannot hold a charge, though it works fine when plugged in. It is over a year old. Any solutions? Can the battery be replaced?
  • 174 Answers
It still should be under the one year warranty with Garmin. Call Garmin support and get a RMA.
Posted on Jan 01, 2008
I ran the battery dead on my c340 GPS Now
You will have to open up you unit, and replacing the battery, you can get them from Garmin.
May 08, 2010 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 will not charge. I tried pressing the reset button under the faceplate. Any other suggestions?
How old is it? Could the battery need replacement ?Mine still works but the battery like has gone down to an hour.
Feb 24, 2009 | Garmin StreetPilot c340 GPS Receiver
My Garmin C340 is dead!!!!
I had the same problem on a trip. Required two fixes and once I did this the unit worked fine.
1. Replace the fuse in the car adapter (reason it wasn't charging when I used it in the car).
2. See the users manual on page 31 regarding resetting your C340.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Jul 21, 2008 | Garmin StreetPilot c340 GPS Receiver
My Garmin c340 turns on then shuts off even when plugged in
I have the same problem. I have had it for only 4 months.
Jun 23, 2008 | Garmin StreetPilot c340 GPS Receiver
C340
First, be sure you are outside, in the open when making this diagnosis. If, when outside in clear view, you still have problems, try this...
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel.
* Use caution removing and reinstalling the front panel... it's somewhat fragile... wiggle it a little to get it off.
Press where it says "Press to Reset", hold for a second or two. Charge the unit with the car cord or USB cable, then try to turn it on again.
Once you can get the unit to (hopefully) turn ON, you should run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
Jun 02, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin Streetpilot c340 arrived dead
The battery symbol would show the charge, somethign doesn't pop up.
May 08, 2008 | Garmin StreetPilot c340 GPS Receiver
Dead Garmin StreetPilot c340
The battery usually has a small charge when arriving from the factory, but it can die before it is received. You should charge this by plugging it into the car or the computer.
Garmin C340 GPS - Will Not Power On
Thanks. This helped me fix the problem.
Apr 02, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 went black and can't get it working
The battery was completely dead. I must not have had the cord plugged in to my lighter, or maybe it wasn't sitting properly on the cradle, and it was running on battery power. I found that when I charged it by the computer, it was ok. It is working with no problems, now.
Mar 10, 2008 | Garmin StreetPilot c340 GPS Receiver
Display problem
Have you tried resetting the unit? It sounds like you may have a problem that Garmin needs to address. I would try to reset it first, then make sure you have the latest firmware loaded on the unit. If you still have the problem, it may have to be sent to Garmin for repair.
Feb 07, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
94 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
