Question about Maytag MEW6530DDS Stainless Steel Electric Single Oven
Gas oven electrical hookup issue
We have a Maytag MEW6530DDS oven that we are trying to hookup up into the wall. THe wall has a white wire, a black wire, and a ground wire. The oven has a white wire, a black wire, a RED wire and a ground wire. How do we match them up?
  • 10,865 Answers
Hello. I can help you. What you have there at the wall is a circuit with 120 volts of power available. Your Gas oven requires 240 volts of power, thus the additional [red] wire. That said, they do not match up.
You will have to run a 240 volt wire from your electrical panel to rear of your stove opening with the correct circuit breaker in the panel, the correct amperage wire to the stove, the correct receptacle for the stove and the correct plug on the stove.
This is serious electricity here so do not proceed on your own as you could get seriously hurt or worse.
Posted on Aug 02, 2009
How to hardwire a 3 wire wall to a 4 wire oven
Simply put, it won't work. New oven=white is neutral, black and red are power but not on the same "leg", and green is ground. If you use a meter, black and red should give you 208-230 or so volts. Wires from wall=White is neutral, blank is voltage (probably 120 or so volts) and bare copper is ground. The dual voltage plug can be used for either 125 or 250 volts, not both as required by the new oven. Need an new circuit pulled and wire/breaker matched to new oven power requirements.
Oct 08, 2017 | Ovens
Constant beep beep beeb from Maytag
forum.appliancepartspros.com/oven...ranges-cooktops/5209-maytag-ove...
https://www.maytag.com/product-help
Jun 30, 2014 | Maytag 30" Built-In Single Electric Wall...
I have white, black and ground out of wall, i have red, black, white and ground from oven, how do i connect
Unfortunately you can't. Your wall outlet is a 110V circuit (B-110V; W- common) and your oven needs 220V circuit to operate. Red - 110V; Black - 110V; White - Common.
You will need to installed a 220V, 30 AMP (10-3/w ground) homerun from your circuit breaker panel to the oven
Jun 21, 2011 | Whirlpool RBS305PR Electric Single Oven
What distance does the back and sides of the wall oven need to be from the other kitchen cabinets and drywall? What is the voltage and wattage of wall oven? What do the five colors, blue, black, green,...
the installation instructions are in the user manual and the wiring must be done by an accredited , qualified electrician
do anything yourself and the warranty is void
Aug 14, 2017 | Ovens
I have a Magtag wall oven MEW6530DDS model. The panel buttons do not work. I've had the oven about 3 yrs. Do I need to replace the control panel or control board?
The control board. As long as none of the buttons appear to be stuck. Press each button one at a time feeling for the retraction or click. If this checks good replace the control board. Here is a link that should help http://appliancehelponline.com/ovenerc.html
Sep 18, 2010 | Maytag 30" Built-In Single Electric Wall...
Its a Maytag wall oven and I need to replace the operating panel
usually you take off the handles with screws and the front panel is screwed to the door or held on by clips or brackets.
Jun 18, 2010 | Maytag Appliances 27" Electric Double Wall...
I have a Maytag in wall oven (part# MEW653ODDS). Only three buttons on the control panel are functioning (cancel, convection bake, and favorites). The oven seems to work properly, but the number of...
HI. This will be the actual control board in this case, that will be the culprit. the control board, and touch pad, are integrated. These symptoms are indicating that the key pad membrane is damaged. This will require you to replace the entire control board. Once the control is replaced, these issues will be corrected.
Nov 03, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
My Maytag Oven has 3 wires one red, one black & one white and then a copper wire. Will my oven model M5530DDs work with 220VAC? If so how can Identify which wire is which in electric terms?
red and black wires are the two "hot" power wires, the white is your "N" neutral connection and the bare goes to the appliance metel case as safety ground
Oct 02, 2009 | Maytag 30 in. Electric Single Wall Oven...
Connecting wiring into oven
The house wiring was not up to code so the white wire was not supposed to connect to the white terminal on the stove. Instead the white wire connected to the red, the black to the black and bare ground wire connected to the white terminal thus providing ground and two termianls with 110 each.
Sep 30, 2009 | Maytag CWE5800A Electric Double Oven
MEW6530DDS keypad not working
Check out www.appliancepartssolutions.com for a good price on your control board.Have the part# available you need or click on their "live chat" feature for help.
Aug 06, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
Maytag MEW6530DDS Stainless Steel Electric Single Oven Logo
198 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Mack Baxter
ashburton
Are you a Maytag Oven Expert? Answer questions, earn points and help others
