Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
Pump fan blades have broken off, I"m looking for a replacement part.
  • 1,305 Answers
Unfortunately, you're not alone on intex pump failures... in fact there's people intending to start a class action suit against the company because of the pump impellers failing and there are not parts available for replacements...and their customer service people aren't much help either.
You may be able to buy an inexpensive complete 635 pump, but it looks like an different model may be a safer bet.
Sorry to be the bearer of lousy news.
Posted on Aug 06, 2009
What is causing Scotsman icemaker to moan
perhaps it's unhappy? I can't say i blame it, if I had to sit there all day in the freezing cold making ice I would moan too.
here's a list of possible problems
If it makes excessive noise:-
Problem and Likely Causes/ Probable Solutions
Fan blade vibrates Blade is bent Replace fan blade
Fan motor mount is broken Replace motor mount
Compressor vibrates Mounting loose Check mounting
Water pump vibrates Pump bearings worn Replace pump
Panels vibrate Mounting screws loose Tighten screws
and ice can groan as it expands, but that only applies to large icebergs
May 14, 2014 | Scotsman Freezers
Need a 42" white ceiling fan blade
I would need to know what fan ( make/model) you have. Is the blade broken or the blade holder?
Apr 12, 2013 | Dryers
Car overheated and antifreze was boiling and spewing over until engine cooled. 2004 jeep liberty 2wd. Thanks!
Need to know what caused the overheating, possible broken serpentine belt, thermostat, water pump, radiator, fan clutch, cooling fan motor. After motor has cooled down fill radiator with water till full, look make sure serpentine belt not broke, start engine run about 5 minutes, turn off, let sit 3 minutes, start engine look at temperture gauge is it over half way of gauge, Do you have a fan blade driven by water pump or electric fans?
Feb 10, 2010 | 2004 Jeep Liberty
Wont drain
Check the drain line for kinks and obstructions. The pump can be checked. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken or missing blades and that the impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged pump or jammed impeller. Very sorry for your trouble and I hope this helped. Best wishes.
Sep 04, 2009 | Fisher and Paykel GWL11 Top Load Washer
The washer says f1 and stops
What you should do is get a flashlight, remove the hose from the pump and look into the suction port on the pump. Check the blades on the pump impeller. Make sure that no blades are broken or missing and that the pump impeller spins freely. If any blades are missing or broken or if you cannot get the impeller to turn freely, then the pump will need to be replaced. Hopefully, it is just a clogged drainline or pump. Hope this helped and best wishes.
Aug 16, 2009 | Dryers
Slow to drain
What you should do is get a flashlight, remove the hose from the pump and look into the suction port on the pump. Check for anything clogging the pump. Check the blades on the pump impeller. Make sure that no blades are broken or missing and that the impeller rotates freely. If any blades are missing or broken or if you cannot get the impeller to turn freely, then the pump will need to be replaced. Hope this helped and best wishes.
Aug 15, 2009 | Washing Machines
Removing ceiling fan blades
Wait? Why would you want to remove the blade? Are they broken? Is the fan unbalanced? Try cleaning the blade. If the fan still wobbles, try tightening the screws. If the fan still wobbles, Unscrew the blade and unconnect the blade from blade iron. Buy the new blade iron. If the blade is broken, Also buy the new blade.
Jun 13, 2008 | Angelo Brothers Westinghouse (r) Savona ES...
Broken fan blade
you can goto a habitat for humanity store they would have full or seperate blades or heck even a junker fan here with your blades for cheap or a thrift store but if your looking for correct size blades the most reliable place ive been able to order from is true value store
Jun 13, 2008 | Hampton Bay 24750 Huntington III Ceiling...
How to remove and install fan in freezer compartment of GE side by side
Most of these fans have a small dowell pin that goes through the fan blade sleeve and through the shaft look for a pin on the side of the fan blade sleeve then you will need a pin punch to push this pin through. After you do this save the pin or dowell because you will need it to attach the new fan.
Jun 03, 2008 | Refrigerators
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
711 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
