Question about Garden
The lawn mower starts and then sputters and shuts off. Checked air filter - it's clean, changed gas, checked oil and spark plug. After changing gas it stays on a few minutes longer but sounds like it will conk out and then does. It is a 650 series Briggs & Stratton engine. Bought at Sears
    Novelist:
  • 168 Answers
Sounds like you have a carb problem here. If your not familiar with the carb have someone qualified to do it. Other wise it sounds like the jet in the carb has dirt in it, obstructing the gas passage. Most of those jets are directly in the bottom of the carburetor. Remove it and be careful not to drop the bowl because if you do you could cause the float to move and that could get stuck and then not shut the fuel flow off to the bowl when re installed. Good luck
Posted on Aug 02, 2009
Hi I did a tune up ,changed and checked every thing I done ..too I changed the oil ,oil filter ,gas filter air filter ,got a new battery changed the plugs there new too...even a new belt new key ...but...
Spark and gas??? Must have both. Pull spark plug wire and check for spark. If you have spark, check gap on spark plug. Check the bowl on carburetor. loosen bowl screw to see if gas is coming out. If you have gas coming out, carb needs to be taken off and cleaned or rebuilt.
Oct 11, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman lawn tractor
you may have a safety switch that has went bad or came unhooked. unplug and test for continuity. also under the hood you will see a fuse, check to see if that has blown. if all that is good you may want to unhook the coil try to start it and see if it has fire. it is possible the coil has went bad. hope this gives you an idea where to start
Aug 16, 2013 | Garden
Not getting any spark
Clean the Plug and replace the Seafoam gas with fresh. Althiough the Seafoam is a cleaning agent, it cuts back on the gasolines octane and it can slightly foul plugs.
Aug 07, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Lawn mower will start and will run if im pumping the bulb then shut off changed oil gas filter with air pump i blue out carb and changed spark plug still it fires up for a few seconds and shutsoff
have you cleaned the air filter?
and it sounds like carburetor blockage.
is the fuel getting into the carburetor.?
check the needle with the float.
Sep 27, 2010 | Sport & Outdoor - Others
Turned mower on its side and changed the blade and now the pull rope is very hard to pull..its almost like the motor is locked up..I checked the shut off linkage cable,removed the spark plug, removed the...
Your piston cylinder is partially full of oil and/or gas. Take the spark plug out and pull the rope four or five times to blow everything out of the cylinder. If it's still hard to pull over with the plug out check the oil level in the crank case to see if it filled with gas while the mower was on its side. Make sure the plug is dry and clean and reinstall it. When it starts it's going to smoke a lot until it cleans out the cylinder.
Sep 15, 2010 | Poulan "Poulan" Push Mower
I have a Craftsman 650 series lawn mower. It starts but sputters and smokes and finally dies. I replaced the spark plug and checked the oil but it did not help. What do I need to do now??
I have a similar issue in that my Craftsman 650 in that it sputters and smokes out of the muffler and spits oil out from there as well. It does not die, but I cannot operate the lawn mower with all the smoke and oil blowing out. Plus, I get oil leakage on the deck of the lawn mower (top). What would I check for here?
Nov 17, 2009 | Craftsman Garden
Mower sputtering and getting hot
To help stop the sputtering you will need to tune up your mower. As for it getting hot check the air filter, and the top air draw area to ensure that they are clean. During your tune up be sure to replace the oil, spark plug, and fuel filter. If your air filter is dirty replace it too.
Jul 12, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My lawn mower doesn't start
Hi Every 2 stoke engine needs three things to run:Fuel+oil/air mixture in correct proportions,compression and ignition.Remove the sparkplug and see if the spark appears when the piston in the cilinder is at top death point(almoust),if not check the flyweel key(not to be sheared).Check engine"s sealing(crankcase gasket,cilinder gasket,seals-crankshaft,carb gasket).Also the mufller(not to be clogged),disassembly the carb (check and clean it),fuel lines and fuel filter (check and clean them),gas cap tank vent(not to be clogged),the air filter.Please let me know. best regards savumihai71
Dec 22, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
418 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
