Question about Samsung LN-S4051D 40 in. LCD Television
Samsung LNT4065 Turns Off/On
My Samsung LNT4065FX/XAA turns off after a few minutes then starts to cycle power (clicking noises). I read the capacitor solution (where you replace damaged caps on the power supply board), but my caps are not bulged or blown, so I am not sure what the problem is. I ordered a replacement power supply board (same version), but I still have the same problem.Thanks.
  • 286 Answers
SOURCE: viewsonic n3251w - no power
A lot of TVs are having their power boards go bad due to a poor brand of capacitor (CapXon usually).
If small problems are noticed with the tv, the solution is to replace the capacitors. However, once the TV gets to the point where there is no power at all any more (not even a stand-by light) then the power supply has to be replaced.
Visit Viewsonic's website or call your local Viewsonic repair shop to get a price on this board. They are usually under $100.
Posted on Nov 26, 2008
  • 2336 Answers
SOURCE: LN-T4061f samsung lcd no backlight, no sound, no picture
Replacing the capacitors would be a good start. Replace all the ones with the same capacitance and voltage rating even if they do not look bulge.
Let me know if you require further assistance.
Posted on Mar 14, 2009
  • 22 Answers
SOURCE: samsung lnt4065fx/xaa with 100's of colored lines
Sound like one of two things: A test screen, or a broken TV. More likely than not, your television is broken. Try hitting TV/Video on your remote, and if that doesn't work, power the TV off, unplug it, and plug it back in. If none of the works, it's time to call a repair man.
Posted on Oct 29, 2009
  • 927 Answers
SOURCE: Samsung model LNT5271f excessive relay cycling before full power
Howdy,
Yes, it is very easy to repair. Solder iron wattage should be at least 300 w.
The PSB is the center Board (towards left) after you remove the back off the TV. Remove the shield that covers the Boards and remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Good Luck, big IRISH.
Posted on Dec 28, 2009
Testimonial: "Great fix"
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
Tv turns on for 10 seconds and then turns off. Then a red flashing blinks 6 times and repeats
Search Results
    Samsung TV On/Off Issue - Repair - Instructables
    www.instructables.com/id/Samsung-TV-OnOff-Issue-Repair/
    InstructablesThe result of this issue is a TV that will cycle between on and off repeatedly and/or an annoying clicking noise while turning on. Time to get informed about the ...
    Easy fix for new Samsung TV switching on and off power ...
    ? 4:41
    https://www.youtube.com/watch?v=H0cG3lzjuw8
    Sep 15, 2012 - Uploaded by alwaysafix
    www.alwaysafix.com Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http ...
    Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
    www.cnet.com > Forums > Samsung
    CNETAbout 3-4 months ago, my TV would start turning off and on a few times at startup but eventually would stay on after a couple of minutes. Every once in a...
    Samsung TV turning off [Solved] - Samsung - Displays - Tom
Jan 19, 2016 | Televison & Video
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
More results from www.cnet.com
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
My samsung tv hlr5067wx/xaa screen turns black, sounds is fine. if i turn it off for awhile i can get picture for a few minutes, but it goes back to black screen
I suspect the lamp is failing on your TV. The lamp replacement code is listed on the side of the TV on a sticker that is orange and white. It will start with BP96-. The lamp code is crucial on these older Samsung DLP's because they used quite a few different styles. Please take a few moments to rate my answer. Thank you...
Nov 19, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung lnt4065fx/xaa with 100's of colored lines
Oct 29, 2009 | Televison & Video
Dlp TV won't turn on
possible color wheel , or just a lamp. depending on what the noise sounded like. check out some videos on you tube on how to replace color wheel. Not to hard
May 27, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung lnt4042hx/xaa 40in lcd tv wont turn on
I concur with Lightnbaby.... had same problem... my TV LNT4042HX/XAA took 10 min to start sometimes... the capacitors on the power supply board had bubbles on top 4 of them all 10/1000Uf. Samsung wanted to charge $220+ to have a guy come out and fix. J&J parts (samsung vendor) wanted $108 for a new board. I replaced the 4 capacitors for $4.68 and the TV works fine now!!!!!
Apr 14, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Samsung LN-S4051D 40 in. LCD Television Logo
481 people viewed this question
Jerry Greenberg
Jerry Greenberg
