Question about Whirlpool Refrigerators
I have a double door/ice maker and the freezer in not cooling or making ice. everyhthing has defrosted. I removed the panel in the freezer section and checked the fan. The fan is working,however, the coils were not cold.
  • Whirlpool Master
  • 1,606 Answers
Sounds like a bad overload/relay ( the piece plugged onto the compressor .with2 or3 wires going to it )
Posted on Aug 02, 2009
Avanti 1008W
To manually defrost just unplug unit from power outlet for 12 hours,it will automatically defrost.But if these problem is occurring again n again then issue is with defrost assembly parts,the defrost timer,the thermostat and temp sensor in freezer section causing the problem.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | Refrigerators
Deawoo fridge freezer FDF-358 freezer is cold, fridge is not getting cold
The freezer section is working,but fridge is not because defrost door is blocked.Its a defrost cycle issue.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Continuous beeping
Either any door is not closed properly or door sensor is not working,its not sensing the door closed.Or the problem is no defrost.The defrost is causing over ice in fridge or freezer section.
Reset the refrigerator by disconnecting it from wall outlet for 12 hours,then reconnect and see if still the same problem is there.
On some cases its issue with fan not working.There are two fans,one in freezer section and one in fridge section.If either of the fan is not working the controls will flash.
These will help.
Thanks,.
Dec 22, 2012 | Fisher and Paykel Active Smart E522B...
Fridge section not cold, freezer section o.k.!
Normally, the cold is only generated in the freezer compartment, and then the cold is pulled or pushed throuch cooling tubes from the freezer section to the refrigerator section. So if your cooling tubes become blocked by ice (usually caused by a defrost circuit failure) then the freezer will seem to work fine but the refrigerator section will not receive the cold air it should.
Suggest you remove the food from the freezer section, then remove the shelves and then the back panel of the freezer. If there is a lot of ice on the evaporator then you should manually defrost the unit. Unplug it from the wall and use a hair dryer to melt the ice. There will be an entrance to a cooling tube right below the evaporator make sure the you keep blowing the hot air from the hair dryer down than tube until you can feel it in the refrigerator section.
If there was ice, you also need to troubleshoot the defrost circuit and find out which component failed. It is normally made up of the defrost heater, defrost thermostat and defrost timer and troubleshooting methods can be found in the tips section.
NOTE: There will be a lot of water to deal with when you defrost your freezer so make sure you are ready to handle it with buckets and large sponges or a wet/dry vac.
Jul 13, 2011 | Frigidaire Refrigerators
Stop cooling every 5 days I defrost manual GSS201ETCBB
Does the freezer / fridge door close good? Check the hinges. Also check the seal and the amount of food stuff you may have close to the door. If you have an ice maker make sure you have it secured inside the freezer section.
It sounds like something is keeping the freezer door open or from closing good.
Mar 20, 2010 | GE GSS20IEP Side by Side Refrigerator
The bottom freezer of my Kenmore Refrigerator works fine but the top refrigerator compartment no longer cools? Thanks
All the cooling happens in the freezer.The refer section relys on a fan to blow cool air into it.When you open the freezer you should hear a fan running.If you hear the fan running, close the freezer door and open the refer door. Look for the vent/area where the air comes in.Put your hand in front of it.If little or no air is coming out it could be a sign of an icing/defrost problem restricting the air to the refer section.
It will take a tech with the right tools to find the exact problem.
If the fan is not running you will have to unplug the unit and remove the back of the freezer section from the inside and make sure ice is not keeping it from turning.If it is free of ice then replace the fan motor.
Mar 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Double door fridge stops cooling, autodefrost not working
It wud need a new defrost heater, the fridge gets its air from the freezer , if the defrost heater does not work , ice builds up in the airduct , equals to no cooling in fridge
Feb 01, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
GE Side By Side not cooling on refridgerator side.
Look on the back panel inside the freezer for ice beginning to show. Most times when this happens the fresh food section is the first to notice. Your refrigerator has a control board on the back. If not defrosting the air flow to the fresh food section is greatly reduced. Let me know, Sea Breeze
Jul 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Kenmore Elite model 73503201- FRIDGE DOES NOT COOL, FREEZER WORKS
Look in the back of the freezer, there will probably be a metal panel with a plastic vent on top.
Look through the vents in the metal panel, and you should see the shiny metal fins of the evaporator. If the fins or the vents are plugged with frost, that is your problem. The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. If either one of the parts fails, the freezer will plug up with frost every few weeks. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Dec 30, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
56 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
