Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How to put gas and oil in it.
How u start a poulan pro saw
    Sergeant:
    Novelist:
  • 197 Answers
It's one fill of petrol to one cap of two stroke oil.
If you want to put in more, that is no problem, but it will smoke a lot!
Posted on Aug 02, 2009
How much chain oil do I need for my poulan chain saw?
fill the oil reservoir to the top, each time you fill gas reservoir, a quart of oil usually should last you the use of a gallon of gas.
Jun 04, 2014 | Poulan Pro Chain Saw 46cc 20"
What is the oil to gas ratio on Poulan 3314
Poulan and Poulan Pro chainsaws with 2-cycle engines require a 40:1 gas-to-oil ratio, which corresponds to 3.2 ounces of oil per gallon of gasoline.
Jun 15, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
New 18" Poulan Pro 42 cc saw, mixed up new gas
Don't use stabil. Use a modern synthetic saw oil (50:1 fuel to oil ratio) available at home centers, hardware stores, and saw dealers. Mix the oil and fuel in it's own container and be sure to shake the container thoroughly just before filling the tank each time to prevent oil starvation. If it becomes apparent that the carburetor adjustments are wrong, you will need to see your dealer for adjustment. Good luck!
Dec 18, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I bought a reconditioned Poulan pro PP4629AVX and I can't find a manual for it. What is the oil to gas mixture? Thanks Steve
The fuel-oil mixture ratio for all Poulan two-cycle products is 40:1. You can obtain this ratio by mixing 3.2 oz. of oil with one gallon of regular gas.
Sep 25, 2010 | Poulan Pro Chain Saw 46cc 20"
How much oil for a poulan pro Chain saw?
if it is 50 to 1 use 2.5 ounces of 2cycle oil per gallon of gas
Jun 30, 2010 | Poulan Pro Chain Saw 46cc 20"
Gas/oil ratio for fuel in a poulan pro 46cc engine
The standard mix for most chain saws is 40:1 that's about 3-1/4 oz per gallon.
Jun 12, 2010 | Poulan Pro Chain Saw 46cc 20"
My Poulan E300 Electric Chainsaw stop oiling the chain and bar
Hello JK; I am hesitant to answer this, these are all Poulan electric chainsaws that appear when the parts source is searched for Poulan Electric Chain Saws:
400E Poulan Pro Electric Saw
http://www.ordertree.com/modelinfo/PWE/400E-Poulan-Pro-Electric-Saw/75.400E-Poulan-Pro-Electric-Saw.1.59.1.html
400EX Poulan Pro Electric Saw
http://www.ordertree.com/modelinfo/PWE/400EX-Poulan-Pro-Electric-Saw/75.400EX-Poulan-Pro-Electric-Saw.1.59.1.html
ES400 Electric Saw
http://www.ordertree.com/modelinfo/PWE/ES400-Electric-Saw/75.ES400-Electric-Saw.1.59.1.html
PP250E Electric Saw
http://www.ordertree.com/modelinfo/PWE/PP250E-Electric-Saw/75.PP250E-Electric-Saw.1.59.1.html
PP300E Electric Saw
http://www.ordertree.com/modelinfo/PWE/PP300E-Electric-Saw/75.PP300E-Electric-Saw.1.59.1.html
All are plumbed the same to my eye. I assume you cleaned and tested the oil pick-up within the tank. If everything you say is true if the pump is driven it should oil.
1. What causes the pump to pump? I cannot tell from the IPLs. If gas and not gear driven, an impulse line (pressure/vacuum) from the crankcase drives it. There can be no impulse line on an electric and I see no gear. Does it rotate to pump oil? What imparts the rotation?
2. What purpose does item 27 (pinion) serve? Is it supposed to drive the pump? Is it missing teeth?
3. What is the purpose of item 44 (check valve). If it is an oil tank vent, and not opening, you are creating a vacuum in the tank if the pump is operating. Loosen the oil cap and see if it oils. If yes replace the check valve.
I think Joe Schmoe is saying Poulan redesigned the oil system to eliminate all the hose couplings. It makes sense, one hose from oil pickup (filter on hose end in tank) to bar is much less likely to leak, also no restrictions for any particles in the hose to form a clot on. I see nothing on my research to support Poulan doing that. There are a couple of new models that I cannot find an IPL for so it is possible. I have headache JK. If this does not solve it is not because I did not give it my all. Please post back (below) with success or failure. If successful what was the cause. TIA
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 29, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan 2 cycle gas chainsaw 18 inch. Was real
no bar oil should just hurt your chain and bar. remove them and try to start saw. if it still won't start you have other problems you may have to buy a new bar and chain
Feb 02, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan oiler don't work
Common problem with Poulan and Craftsman gas saws. Take off the chain and chain guide and clean out all the saw dust etc. Start saw without chain and look for port where there are signs of oil. If port is clear of sawdust, then it is likely the pump which is located behind the chain break assembly. you can get the diagram on Poulan website and the replacement pump will cost about $15 - $20 to replace yours.
May 22, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
POULAN PRO 295: RUNNING VERY STRONG, FOR OVER AN
Remove the air filter, squirt a little fuel into the carb. Start and let run if it will for a few minutes. Could be you had some water in old fuel. and it is still in the intake of saw. If it still will not run after squirting some fuel into carb. You have a firing problem.
Apr 05, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
75 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
