Question about Remote Controls
Navilight6 RCA universal remote
There are now numbers on my screen which won't go away...appear to be times...also, the name of the last channel that I scrolled to
Re: navilight6 RCA universal remote
Who can help me out with codes for a panasonic TV using a
RCA Naviligth6
Don't have the user guide and have forget how to program the TV
Or where can I download the user guide Naviligth6.
Posted on Dec 22, 2007
0 characters
3 Points
Yes the RCA universal should operate the normal functions like volume + & - , changing channels, power on & off. It may not operate certain other functions like picture in picture, on screen caller ID things like that. You should be able to get a stock replacement remote from the manufacturers web site.
Aug 01, 2016 | RCA Remote Controls
I threw away the directions to my RCA universal remote and do not know how to access the first tv unit I programmed as it will only turn on the second one programmed!!!! Do I need the code and then wh
Try going to this internet page. It has instructions for numerous RCA universal remotes. If you had included the model number of your remote you would have gotten more help.
Jan 04, 2013 | Remote Controls
We have an emerson model #tc-1966d no remote got a universal remote but can't get channel set & channel 3 off the screen
Try an other setup code. Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
Pull up older posts. You can gather all details. Sometimes, click open the adverts' by the side and bottom of each post might give you more details.
May 26, 2012 | RCA RCU300 Remote Control
My rca universal remote won't change the channel to video mode
Apr 05, 2012 | RCA Remote Controls
Need the codes to set up theRCA RCR660 NaviLight Remote Control
Go to this website they will give you instructions and the code list is 3/4 of the way down in a link.
Dec 30, 2010 | RCA RCR660 Remote Control
Need code for Emerson TV,DVD,VCR Combo
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Feb 12, 2009 | RCA Universal Remote 3 Device Remote...
I don't know if you guys even need this advice anymore, as it's 1-2 years late, but if your universal remote has a VCR setting, the Emerson 13" CRT TV/VCR combo I have operates under that mode.
The code I used was 002. These may also work: 278, 184, 479, 000, 121, 211, 037, 043, 061, 208
Remember, program your remote as if you were setting up a VCR (and NOT a TV). For instance, on my GE universal, I hold the "code search" button down until I get a steady light. I hit VCR, and then I entered 002. Works like a charm.
Mar 25, 2008 | RCA Universal Remote 3 Device Remote...
Numbers on my tv screen
It sounds like your tv has a programming problem not to do with the remote but the actual tv you will have to take it in to get repaired or you just might have to buy a whole new tv
Mar 20, 2008 | Universal Remote Control Remote Control
Universal remote
Consult VCR operator manual .....If I remember,there is a selection in the menu to designate a channel so that when a source box is used, the channel selected remains the same in
timer recorded is selected on box,in that
equipment step thru the video recorder
menu on page at a time.........T.
Dec 18, 2007 | RCA Universal Remote Control
Remote Controls Logo
100 people viewed this question
Top Remote Controls Experts
Are you a Remote Control Expert? Answer questions, earn points and help others
