Question about Radio Communications
Alot of static very little talking
The station will come on but its just noises not talking, but the same station will be on my mothers scanner talking and i get either static or several beeps this is like this on all the stations we programed the weather alert comes in very clear what cn i do to fix it uniden bearcat bc148xlt
  • 27 Answers
Check you antenna on the scanner. You are describing loss of signal to the scanner. It could be the antenna, the antenna connector, the scanner its self.
Check everything over, Try a better antenna.
Posted on Aug 24, 2009
Why do radio stations have static?
Why are all my radio stations static? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Feb 20, 2014 - on all of the radio stations in my car, there's a static background noise. no ... It sounds like the receiver has lost it's sensitivity. either that, or the ... Why am i still getting static on my radio?
Sep 16, 2013
Why are all my preset radio stations static?
Sep 3, 2012
Why do AM radio stations have so much interference and static ...
Jul 2, 2009
My car radio makes so much static noise with engine running, but ...
Jan 17, 2007
More results from answers.yahoo.com
Dec 12, 2015 | 2005 Dodge Durango Limited
How can i hear what they are saying without that awful loud sound when they arent saying anything. cause when i turn the volume down i cant hear what they are saying
Turn up your SQUELCH button when no one is talking until the static noise just goes away.
Now your set will remain quiet until someone talks.
If you set the squelch too high it will also cut out the people talking, so always try to have it set just slightly above the background static level.
Good luck.
Apr 15, 2011 | Uniden BC350C Base Scanner
Why is my Samsung DLP Television is making a static noice when turned on?
Hi, what do you mean by static noise. Is your station unclear. Does this only happen on the cable coax connection or is it a loud noise. If its a loud noise then its your colorwheel if its an unclear station or channel then more then likely its your main input board. Please let me know if that helps any.
Jan 02, 2011 | Samsung HL-S5087W DLP TV
Scanner antenna causing static
Sounds like a bad, loose or dirty connection.
it's possible that there may be a broken soldered joint on the antenna connector.
Open up( power off first) and resolder the joints as they can breakdown over time(dry joint).
Aug 14, 2009 | Electronics - Others
Static on line
Make sure the connections between the base station and the wall socket is really clean. If the little brass pins get tarnished (green) then you will get problems like this.
If that does not help then use the divide by two rule.
Start swapping things out until the problem goes away.
Try connecting a boring old corded phone to the same wall socket.
If the problem persists then there may be a problem with the wiring in your house or with your connection to the telco.
Good luck.
Jul 08, 2009 | Uniden Cordless Phone
What are the frequencies for nz emergency services
Congrats on your purchase... you should be able to get fire, ambulance, police, local utiltity companies, local tv station radios, and a bunch more... the best way to get your frequencies is online. Alot are posted for different areas.
go to google.com and type in your city, county, and "radio frequencies".
you should be able to get free lists of the different codes. Also turn you squelch down.. as soon as you hear static, turn it up just a bit to eliminate the static...that will be at the most sensitive setting without the static.
Have fun... you can also get a list of the "codes" that police officers use so you can tell what they are refering to. google for "police codes"
Have a blast and let me know if you need more help.
May 27, 2009 | Uniden BC72XLT Handheld Scanner
Trouble programming
Part of this answer depends on whether your area is still running the standard broadcast radios or the "newer" trunk tracking style. The two are not compatible. If they are still standard, then press the E button to enter the program mode. Enter the desired freq. and hit the E button will enter the freq into memory. Tap manual to step to the next channel and repeat the steps to keep programming. Open the squelch to hear static then close just a little to quiet the noise and it should lock on and talk to you. Good luck with it,,and happy hunting. Mechanic
Jan 12, 2008 | Uniden BC340CRS Base Scanner
Radio Communications Logo
125 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
