It is for a garden luxury spa model # gl16034
SOURCE: Spa Pools, setting up spa pool with chemicals etc
Hi curlyall,
I'm Harvey the Master Plumber.
Your problem is: You have just brought a secound hand spa, you are woundering what sort of chemicals etc are required, there are no instuctions with it
If your spa is the type that you fill once, then you must treat it just like a swiming pool. Go to the local pool supplies store. They will be happy to set you up. Don't forget PH testing kit! Test it every day. And I prefer non chlorine chemicals. It's also helpfull to have a small submersible pump in case you need to replace the water sometime. Happy soaking!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: what chemicals do we use in spa
same as a pool..unless its under 300 gallons..then its cheaper to drain it completely and refill..add a few cups of household bleach to it after filling..
