Question about Haier HSB03 Compact Refrigerator
Chiseling the freezer compartment I punctured one of he elements and now obviously not freezing.
    Novelist:
  • 116 Answers
Hi, need new refrigerator. punctures in evaporator, is one of the worst thing that could happened to ref. to repair you'll need to replace oil in compressor, replace filter dryer, repair puncture with special epoxy, or soldering of aluminum, which is difficult, vacum and recharge, if done properly, system would be o.k. water in system is refrigeration biggest enemy, it's better to buy another one.
Posted on Aug 02, 2009
Is it worthwhile getting my fridge/freezer repaired?
with the condition as you described, I would consider junking it as the water will freeze and do it all again and any repairs would be good money after bad.
May 05, 2015 | Refrigerators
I cannot understand the dual thermostat manual (" rolling " knob type) controls . They are printed in Japanese . There are 2 temp. control knobs side by side located inside the ref. compartment / lowe
Don't think it's the temp control problem, I suspect one on the defrost elements at the top is faulty, if food starting to defrost in the cycle indicates the lower element is working overtime.
Nov 22, 2014 | Refrigerators
FFA74 HIGH TEMP WARNING LIGHT
That indicates that your system is low on Freon or there is a leak somewhere in you sealed system.
samedayappliancerepair.ca
Jul 06, 2017 | Refrigerators
Freezer is working fine but the Fridge part is not
i take it the unit is frost free you need to replace the defrost element in the freezer whats happening is your freezer sends cold air through small holes to the fridge compartment but when the freezer cant self defrost those holes freeze over thus no cold air into the fridge compartment get a tech in to check the element shoulnt cost more than $ 80.00
Apr 21, 2010 | Refrigerators
FREEZER COMPARTMENT FREEZES AND WATER RUNS INTO REFRIG.
The problem is the drain is clogged. Remove the back panel in your freezer and at the bottom of the evaporator coil you will see a hole about ½” in diameter this is the drain tube. You might need to use some warm water to melt the ice and then run a wire being very careful not to puncture the hose and run it down the tube to free up the drain. This tube travel down to the bottom of your refrigerator to a pan sometimes located on top of the compressor or somewhere else down there. It collects the water there to evaporate. You can enter your model # at www.appliancehelponline.com for a diagram or illustration of your refrigerator. Not all models are available.
Apr 09, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer compartment got hold and is venting air,
If it still freezes then it should not be dangerous. It will add a lot to the cost of operation. You can fill the hole with insulation, that will help a lot. There is various types in aerosol cans that will work quite well.
Good Luck,
Gilshultz
Nov 29, 2009 | Haier HSB03 Compact Refrigerator
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Freezer side not freezing
It is possibly your defrost element which is not working causing a build up of ice and reduced airflow through the freezer compartment. This is located behind a cover in the freezer compartment. It is best to change both the element as well as the defrost limiting thermodisc which is attached to the fins of the evaporator.
Mar 04, 2009 | Amana SXD524VW Side by Side Refrigerator
Frostfree hoover fridgefreezer
If its freezing at the back that indicates refrigeration is good. it sounds like you have a thermostat control problem. Replace the thermostat.
Jan 12, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Haier HSB03 Compact Refrigerator Logo
347 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
