Question about Dishwashers
Door won't latch. Model SHX68M
Door won't latch. There is nothing blocking the baskets or lodged in there. The dishwasher runs if I hold the door in. The latch won't hold the door in place.
  • 10,865 Answers
The most common cause of your stated problem is that the latch or the latch catch has slid over a little bit so it doesn't match up as it needs to. Typically, there are two screws there that you can loosen to reposition the latch. After it is in the right spot tighten the screws back down and you will be in business.
Posted on Aug 02, 2009
Stopped in mid cycle and wont restart
Hi....I think I can help you with this. I checked a troubleshooting site for Crosley dishwashers, and there could be a couple of reasons why the cycle stopped:
1. The thermal fuse shuts off power to the dishwasher if it overheats. If the thermal fuse blows, it will prevent the dishwasher from starting. To determine if the thermal fuse is defective, use a multimeter to test the fuse for continuity. If the thermal fuse does not have continuity, replace it.
2. The door switch prevents the dishwasher from running while the door is open. If the door switch is defective, the switch will prevent the dishwasher from running even when the door is closed. To determine if the door switch is at fault, use a multimeter to test the switch for continuity. If the switch does not have continuity, replace it.
3. The door latch ensures that the dishwasher door latches shut. If the door does not latch properly, the door switch might prevent the dishwasher from running. If the door latch is broken, replace it.
You can also find more related troubleshooting here:
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/31---/Dishwasher-won-t-start
You'll need the model number for your particular dishwasher.
I hope this has helped you.
2. 2
Feb 05, 2016 | Crosley Dishwashers
Filter basket door opens during coffee making.
sounds like there is a bad relay, that is shorting out, and releasing the filter basket accidentally. Also, check to make sure that there is nothing blocking the latch that holds the filter basket in place.
Feb 05, 2008 | Cuisinart Thermal DGB-600 Grinder
Door doesn't shut properly to start dishwasher, have to push door to work but stops if you let go
The machine will not function if the door is not fully closed. The locking/latching mechanism for the door probably needs to be adjusted or replaced if faulty.
Also make sure there is nothing inside the dishwasher that is fouling the door (like a basket rack that is not fully in position) and is not allowing the door to fully shut. Pull the baskets out of the machine and check inside as well.
Dec 20, 2015 | Dishwashers
My Samsung Dishwasher, model DMR78AH5 will not run. The heavy, delicate, quick and smart lights are permanently on. I cut off the breaker for one minute but that did nothing.
How to Fix a Dishwasher That Won't Start ' Dishwasher Repair
www.partselect.com/Repair/Dishwasher/Will-Not-Start/
If your dishwasher won't start the problem could be the door latch or door latch ... On manual timer models the timer is used to supply power to the pump motor, ...Missing: samsung ‎dmr78ah5
Samsung Dishwasher Won't Start - Model DMR57LFS ...
www.repairclinic.com/...Dishwasher/...-/Samsung-Dishwasher-won-t-start...
The door latch ensures that the dishwasher door latches shut. If the door does notlatch properly, the door switch might prevent the dishwasher from running.
What to Do When the Dishwasher Won't Start - YouTube
? 5:43
https://www.youtube.com/watch?v=L-bMqVb9kX0
Aug 15, 2013 - Uploaded by doityourselfstan
The problem could simply be a blown thermal fuse inside the control panel. ... Maytag Dishwasher Repair ...
Dec 16, 2015 | Samsung Dishwashers
Door won't latch
replace door latch ***'y
Dec 10, 2013 | Kenmore 15762 Dishwasher
Electrolux Dishwasher door won't close or latch shut
Contact a professional to replace the door switch or adjust it.
Aug 07, 2012 | Electrolux Dishwashers
Door seal issues on dmt400 rhs
try this , but will be a good idea to get service support from Samsung.
f your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time
God bless you
Jul 11, 2012 | Samsung DMT400RHS Builtin Dishwasher
Model KUDS01IJBL0 will not start. Keeps reverting back to 2 minute drain when Cancel button is pressed. After the 2 minute drain, I press "Normal" button, or any of the other start buttons with...
If your dishwasher won't start the problem could be the door latch or door latch switches. The door latch assembly is used to hold the door closed during the cycle to prevent water from leaking and it also incorporates the door latch switches that supply power to the dishwasher controls. If the door cannot close properly to activate the door latch switches or if the switches are defective then the dishwasher controls will not receive power and the dishwasher will not start. Inspect the latch assembly including the switches.
The door latch assembly is typically located at the top of the door, behind the inner door panel. To gain access you will have to remove the screws that secure the inner door panel and then separate the inner and outer door. The door latch assembly will normally have two switches that are wired in series as a safety feature. Verify that the door catch will activate the switches by manually inserting the catch into the latch assembly. If both switches are being mechanically activated then you should next check the switches for continuity with a multi-meter. Remove power from the appliance before attempting this repair.
You can learn more on our recent post about the dishwasher 5 simple mistakes you make while using dishwasher Kitchenutilitypro
Sep 26, 2017 | KitchenAid Dishwashers
Dishwasher door will not open.tried running it another cycle and still nothing.It is a GE profile with the latch that you just push in. The latch/handle seems stiff.
The plastic latch release inside the door handle is broken. Most likely one of the pins holding it in place has broken.
First go to your local dishwasher supplier and look at a similar brand (GE Profile in my case) and see how the mechanism works. Next, get a thin pair of siccors, pull the dishwasher handle down and slid the siccors into the opening above the handel and push the tab holding the door closed up so it will release.
Once the door is open, remove the inside of the door to get to the latch. Remove the plastic latch release and order a new one.
Sep 28, 2008 | Dishwashers
Latch problem...?
Make sure nothing is blocking the latch or the door.
Jun 03, 2008 | Kenmore 24 in. 16539 Built-in Dishwasher
Dishwashers Logo
79 people viewed this question
Top Dishwashers Experts
