Question about Brother Office Equipment & Supplies
Clean Unable 46 how pleaes brother dcp130c - Brother Office Equipment & Supplies
    Sergeant:
  • 336 Answers
The message "Unable to Clean. " will appear on the display if there is a
mechanical malfunction of the Brother machine OR a foreign object, such as a paperclip or ripped piece of paper is stuck in the
machine.
First, check the machine for any foreign objects:
1. Open the scanner cover by pulling up on the lower right corner of the
cover until it locks into place. Look inside the Brother machine and remove any foreign objects.
2. Close the scanner cover by lifting it slightly to release the lock,
gently push the scanner cover support located in the back of the unit
and then close the scanner cover.
3. If the error message continues to appear on the display the machine
will need to be reset. To reset the unit unplug the Brother machine
from the power outlet for several minutes and then plug it back in.
If the message continues to appear on the display and your machine is
within warranty, you can locate a Brother Authorized Service Center
(ASC) in your area by clicking on the link below:
http://www.brother-usa.com/service/default.aspx or contact Brother
Customer Service by calling 1-877-Brother (1-877-276-8437) Monday
through Friday, excluding holidays.
If your machine is out of warranty, you can locate a Brother Authorized
Service Center using the information listed above.
Please Let me know if this works, or if it does not.
Thanks,
Ryan Frame
Creative Energy Associates Technical Center
Posted on Aug 02, 2009
Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide" BROTHER DCP-135C
printer is flashing "CLEAN UNABLE REFER TO 46- TROUBLESHOOTING AND ROUTINE MAINTENANCE IN USER'S GUIDE..BROTHER 2480C
Feb 23, 2013 | Brother Multi-Function Center MFC-3360c...
My brother printer has an error unable to clean 50
XXXXX XXXXX look on the printer, do you have these keys:
Menu/Set, Black Start, or Function?
Brother Printer Support
Sep 28, 2012 | Brother LC51BK Print cartridge, Inkjet...
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
Unable to clean error 46
i have brother dcp 6690cw and it said unable clean 46 i want solution for this
thank you so much
Apr 14, 2010 | Brother MFC 6490CW InkJet Printer
Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Mar 24, 2009 | Brother DCP-330C All-In-One InkJet Printer
Dcp130c UNABLE TO CLEAN 46
press the menu and mono start keys next pess the arrow up key 4 times to make machine enter matinence mode
2 enter 8 and 0 by using arrow key and set key
3 press mono start key several times until the purge count appears on the lcd
4 ente 2 7 8 3 by using arrow key and set key to reset the purge counter to zero
5 press stop/exit key and return to the intial stage of mantince mode
6 enter 9 twicw by using the up arrows and set keys to exit from matince mode
Aug 23, 2008 | Brother DCP 130C All-In-One InkJet Printer
Clean unable 46 : what does it mean ?
...because you have run the cleaning cycles too much, the waist inktank is fed up! needs replacing. contact brother hotline or try to get one from a service partner which can be found on the brother homepage of your country.
Feb 09, 2008 | Brother DCP-340CW All-In-One InkJet...
DCP-130C Clean Unable
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
- ready to print
Jan 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
1,843 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
