Question about Bosch Axxis WFL2090UC
Error message is given won't start cycle- Message is F32
  • 3 Answers
U ***** stink
Posted on Aug 02, 2009
My washer is showing a f32 ,f71 codes what does that mean
Sd Error Suds Detected (Stored Error Code F71) Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle. The suds reduction routine removes extra suds and assures proper rinsing of your garments. If the code remains and the wash cycle dial is ?ashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press START. Do not add detergent.
Ld Error Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Is the pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.
Mar 02, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
I have a HP LaserJet 6040 with this error message 59.30
59.30 means that the fuser motor experienced a start up error.
If power cycling the printer won't clear the error you probably need a tech to troubleshoot and/or replace the motor.
Sep 16, 2011 | HP Color LaserJet CM6040f MFP Q3939A...
What is error 1 message mean?
What is error 1 When you start a dishwashing cycle, the dishwasher fills and then shows the error message when it should go into the wash mode
Dec 09, 2009 | EuroTech 24 in. EDW174E Built-in...
Error message f32 - not in manual
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
There is an error code comming up it is f32
The F32 error code is a pressure switch failure error code, this error could be caused by several different reasons.
More than likely the pressure switch has malfunctioned. Be sure you are using H.E.(high efficiency)detergent. Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains you will need to call for service. This type of repair will require accessing the inside of the cabinet area to make some checks. This will require a service technician to diagnose & repair.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
I get an error message F32.
F32 is a long drain fault code. Tip your washing machine back far enough that you don't have to hold it up. At the back of the unit there are two "things" with hoses coming out of them attached to the bottom of the outer tub. On the left is the recirculation pump, and to the right is the drain pump. Take a wet/dry vac and get as much water out as possible through the end of the drain hose, then pull the hose off the drain pump, remove the pump, and look for coins/shoelaces/whatever might be blocking it on the inside.
What make and model is your washer? This applies to Whirlpool cabrios. Just reread your message and realized that I have no idea what you're talking about. F codes are pretty common in different brands, but "32" could mean anything. All depends on what you're looking at.
Aug 24, 2008 | Washing Machines
F32 error messaged?
Sounds like we need to try to reset the system!
Huuum At your service!
Lets try this,
F32 is an error code.
This can reset the system if it is electronic!
Unplug the appliance and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works!
Waiting for your reply!
Please remember to leave a appropriate rating when you are done!
Thank You
Huuum
Jul 03, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
ERR message
unmount and remount the lens. Make sure you have the aperture ring on the lens set at the minimum f-stop number, ie f22, f32. There should be a small tab on the lens to lock the aperture ring in that position
Dec 27, 2007 | Nikon N80 35mm SLR Camera
Error message
You might want to check the position of the aperture ring on the lens. If it is not set at the highest number, ( IE smallest aperture, f22,f32 ), then the camera will display that error message
Dec 03, 2007 | Nikon Telephoto AF Micro Nikkor 60mm...
Bosch Axxis WFL2090UC Logo
127 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
