Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Arcing issue? My tv seems to be arcing in the right rear(facing front of tv) Is it an easy fix that I can do?
    Champion:
  • 230 Answers
Common problem on this tv, ceramic capacitor .087uf 1600V.
Take out the chassis,and inspect under fly bac area, you will se a burn area; replace thsi ceramic capacitor. for parts. go to:
encompass.com thank you
Posted on Aug 07, 2009
Already replaced the clutch fan on our 98 isuzu rodeo but now it revs up when first started until it finally changes gears then it doesn't do it anymore until the next time it is started. Thought maybe we...
The fan has an arc to the individual blades. The inside of the arc goes to the rear, and of course the outside of the arc points to the front. Imagine if the blades were cut out of a very large piece of metal tube, the arc or curve of the blades would still be visible as you look at the individual fan blades. This is the arc I was speaking of. The part of the blade that would have been the inside part of the very large piece of metal tube, the blades cut from faces the rear, and the part of the blade that was the outside of the tube faces forward.
Dec 20, 2010 | Isuzu Rodeo Cars & Trucks
White arcs across screen when the screen is dark or black.
Replace a color gun in your KP51HW40. Then adjust the picture brightness to eliminate these rings by turning a little button behind the front (cloth like) panel (the one covering the front bottom half of the set). You may have to to dim the lights to be able to do that properly. The little dial button as is in the middle.
Jul 03, 2010 | Sony KP-51HW40 51" Rear Projection...
Can't seem to get the color +'s to line up, print on arc
your chips are burned out, had the same problem with mine cost about $200 to fix.
Feb 25, 2009 | Philips 9P5544C 55" Rear Projection...
Kp57ws500
You have a BAD Tube RED.
Aug 24, 2008 | Sony KP-57WS500 57" Rear Projection...
SCREEN RESOLUTION ISSUES - RED, GREEN, & BLUE
you can get a service manual for your set at this link I posted its listed under zenith projection tv R45w46 for $15.99 they e-mail it to you right after purchase and sign you up for free online tech support
http://servicemanuals.vstore.ca/
Apr 08, 2008 | Zenith R40W46 40" Rear Projection...
HD52W59 CRT Arcing
Blue Crt arching... on the board or on crt? most likely if it is arching you are right in suspecting the tube. These tube are around 240 dollars per tube and then i would sugest replaceing crt board. I work on alot of these at the shop. bottom line if there not under warenty then really not worth fixing. these set cost about 800 new it would cost around 500 to fix. crt replacement of these set is a very involved process. I think almost ever screw in the set has to come out and then after you get it all back together. theres the alignement issues.. im not saying dont do it just if you like a challenge go for it.
Feb 18, 2008 | RCA HD52W59 HDTV Projection Television
Arcing Picture tube
get a different tech from a different store to come out, needs to replace convergence ic's good luck
please mark the post with a fixya
Feb 16, 2008 | Toshiba 65HDX82 65" Rear Projection...
T.v. not coming on ,turned off by itself with an arc noise
The part is known as a flyback transformer.. it will have to be replaced.. also the horizontal ouput transistor will possible most likely be bad..
Dec 16, 2007 | RCA D52W19 52" Rear Projection Television
Convergence problem?
That board, P/N Bp94-00155a should fix the problem and be fairly easy to replace. Make sure you unplug the TV before starting the repair though. Duh!
Mar 11, 2007 | Samsung HCN4226W 42" Rear Projection...
Sparks arcing from rear of tv
Wow they are charging you alot for this repair my friend. Go to this link and you will see! The High Voltage transformer, also known as a flyback only cost 50.00 Bucks!http://www.partstore.com/ProductDetail.aspx?ProductSKU=2187762&ProductType=PART&ModelID=420798 I would get the part and let someone replace it If you have no soldering and or TV repair experience, as this is a dangerous place to be experimenting with if you do not know the safety issues involved. Good Luck Please dont forget to rate this thread.
Nov 25, 2006 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
