Flat Panel Televisions
Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Picture goes blank
By d2mmr on Nov 25, 2007
comes on fine then picture goes but still can hear the sound
Same Problem
Apr 18, 2009
-   The picture comes on fine then you hear a frying sound,the screen goes blank after 1 minute but you can still hear sound.-   showerpatch
Feb 24, 2009
-   Have an Element FLX-1910 19' LCD. Picture goes out after on for about one minute but still have sound. Have unplugged everything and recabled but still same problem-   tuggies
Feb 24, 2009
-   Picture goes out after about a minute b-   Guest
Feb 14, 2009
-   where to get a backlight -   Guest
Feb 04, 2009
-   Screen goes blank.a grey/white color-can still hear sound
-   t554
Best Solution
posted on Nov 25, 2007
Helpful)
bluenadas
Rank: Guru
Rating: 86%, 266 votes
What type of TV is this unit? An LCD or Plasma?
If it's an LCD, take a close look at the screen with a Flashlight and see if you can see some sort of picture (Almost like a ghost of an image). If this is the case, the backlight has failed.
If it's a plasma unit, you're probably looking at a power supply issue to the panel.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
how to unlock channels
Answer
Answer
i have sound but i dont see the picture in vizio lcd tv
Answer
my tv randomly turns on, and changes the channel... i have tried everything to get it to stop and... (More)
14 Other Users Have The Same Problem - Continued
Comment by Brandy77, posted on Jan 18, 2009
I have a Dynex 32 inch HD and even when first got it in would intermidently need to be reset to get the picture back. Eventually, all it would do is give sound. By eventually, I mean less than a month after purchase. I have tried hard resets, no luck. The "please wait" message still shows, but then goes blank and there is nothing on the screen.
We let it sit and used our old set for about a month or so, waiting to have the money to have someone look at it. Still no luck. It's still not working. I think this is a crappy brand and will never buy another Dynex TV again. Money down the drain as Best Buy was absolutely no help at all.
Comment by Isikins, posted on Jan 05, 2009
I have a sort of unique (at least I think) problem. It's an LCD television and it is hooked up to a PS2, and XBox 360, and normal cable. The XBox is hooked up to the HDTV YPbPr 1 hook up, and is the only unit producing a clear picture with sound. On the TV and AV hook-ups, there is sound, but the picture is skipping, and is a distorted black/gray color.
I've checked through all of the options in the menu section and I've come to no conclusion as to what th e problem may be. Someone help, please?
Comment by kgplancher, posted on Dec 07, 2008
I have the same problem. The tv comes on fine then the screen goes black. It is resolved by turning it off and waiting about 30 seconds to turn it back on. We it happens again, it won't come on at all. Can this be repaired?
Comment by heashfus, posted on Dec 01, 2008
my screen goes white too, how can i fix the backlight problem?
Comment by jennbuslach, posted on Oct 26, 2008
I am having the same problem with my LG plasma TV. The TV turns on and the picture and sound is normal. After about 7 minutes, the picture flashes a neon color, than goes black. The sound still works. If I turn the TV off for a few minutes, than turn it back on, the exact same thing happens. Any suggestions?
Comment by mike-burnett, posted on Aug 23, 2008
I have a gateway model number shd-3010 and after about 10 minutes it goes black with full sound. After turning it off and back on, it does it again. After another 10 minutes, it does it again but for the last time.
Any help woudl be appreciated.
Comment by hotazhell, posted on Jun 18, 2008
I too have the same problem. so are you saying that if i can see an image by using a flash light that it is the back light and not the back light inverter board
itself.?
Comment by arll, posted on May 27, 2008
tv turns on with picture, then within a few seconds picture goes off but has sound. Resetting the tv by holding down the power button has worked, but not anymore.
arl
Comment by music lady, posted on Dec 10, 2007
The TV ...Vizio...has been working fine for six months, then all of a sudden the picture goes white. The sound is ok, just a white picture. Turned the TV off and back on. The picture appeared for a second, but then white again. No idea.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Flat Panel Televisions:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 801
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
