Triton rapide 1 shower unit has started only giving warm water when turned to the highest settings, the water flow then dwindles until you turn to a lower setting and you only get a brief amount of hot water until you turn it up again and so on. This fault occurred just after the relevant circuit breaker was tripped.
  • 1 more comment
  • wireboy Aug 03, 2009
    The circuit breaker tripped one time is not the reason why the shower unit only gives warm water if turned uphigh and tepid water at what used to be the warm water position on the dial
    regards Dave
    The circuit breaker is ok is not the reason why I only get warm water if the dial is set all the way up high and tepid water at any other setting
    regards Dave
  • wireboy Aug 04, 2009
    fine
  • 2,200 Answers
Hi
Given that you experience a circuit trip with this the problem - it is most likely caused by one of two things;
Do take proper precautions to avoid the risk of electric shock when examining these items;
1) Faulty element in the heating tank there are at least two - three in a 10kw shower. You can check them with a multi meter and you should have a reading of around 12>18 ohms if they are functioning correctly.
If you have power to the elements and no heat the element(s) are faulty. If there is no power to the elements there may be a problem with a micro switch.
2) Faulty Thermal Cutout (TCO) This is a black disk with two wires going to it and it is mounted on the outlet pipe (The bit between the heating tank and the hose). This cuts off heat in the event of a problem being detected and may have been fused by the circuit tripping.
However the initial cause of circuit tripping may be faulty element as above.
Examine the connections on the TCO closely for any discoloration or signs of overheating. If this is evident the TCO needs to be replaced.
Hope this helps. If so please do rate my answer once you have accepted it. Many Thanks.
Posted on Aug 04, 2009
  • 10,865 Answers
The circuit breaker trips for a reason. Often, the reason is that the circuit breaker itself has gone bad. Begin by replacing the circuit breaker. That will likely solve your problem. If it does not solve the problem get back.
Posted on Aug 02, 2009
AS2000XT triton shower problems
1. make sure there is water getting to the triton control & pump
2. make sure there is power available to the pump
3. if 1 & 2 correct, then check to see if shower head needs cleaning to open the spray holes. if yes then use vinegar solution.
4. if 1, 2 and 3 do not fix problem, there is something wrong with unit and it may need to be repaired or replaced.
Mar 20, 2014 | Home
Triton shower T100E Thermostatic
May need to replace the whole unit.
Nov 11, 2013 | Vehicle Parts & Accessories
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
Water is hot until you adjust the shower temperature to warm from hot, then heat unit shuts off and it is 100% cold. Shower head is low flow so wonder if the flow is below minimum for heater to fire?? Can...
These unit is design to operate at a specific flow rate and cannot be ajusted if you need to have a warm shower you will need to get a bath remote where you can turn down the temp whenever you need without disrupting the flow rate
Jul 21, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have a Triton Rapide R2 electric shower problem
you can check the pipe lines there are normally more thane one way to set the pressure of the water one by the shower knobs 2 by the behind the head in the wall there are some water valves that may need to be opened up or by the water heater there are some valves there one coming off the heater one just on a pipe by the heater they may need to be opened. try that if that doesnt work come back and let us know and see what else you can do to fix it
Nov 11, 2009 | Water Pik Waterpik& Elements& Fixed Mount...
Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Nov 28, 2008 | Water Heaters
Triton Millenium Power Shower
generally if the flow sensor notices no water through the pump it will auto matically shut the pump down. so it could be the flow sensor is bad or the pump is not working like it should. now it depends on how old the pump is. i would start with the flow sensor.
Aug 30, 2008 | Home
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
