Have problems at startup. I push the startup switch and I don't always geta full start up.
    Brigadier General:
  • 3,614 Answers
A possible error that printer may have usually a paper jam error. If you have any incident of paper jam or something happen before the problem came out, this could be a stuck paper debris inside or could be a stuck object resulting this error. Check the printer for any of this said possible cause.
Hope this helps
Posted on Aug 04, 2009
Why does my 1988 only start when its pulled?
The first thing you would need to know is why it won't start on its own.
It could be the key switch or a list of other things.
Try to narrow down the choices, fuel, ignition, or compression.
Jan 04, 2013 | GMC Sierra 3500 Cars & Trucks
I can't play browser games, what is the problem?
Try cleaning the system first. Download MALWAREBYTES at http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install, UNCHECK the TRIAL PRO version, you want the freeware. Run a FULL SCAN, DELETE ALL RESULTS. ALSO Download CCLEANER at : http://www.filehippo.com/download_ccleaner/. This will clean the junk from your system. In TOOLS, STARTUP, Disable ALL unnessary startup programs. It UNINSTALL remove ALL unnessary TOOLBARS, they are killers on broswer speed. That's a start. Respond to post for further assistance. By the way, Unless you have a problem that's directly related to the BIOS, let it be.
Dec 12, 2012 | Acer Aspire 2930-4661 Notebook
Why does this come up? There appears to be an error with your installation. Please reinstall the application. Always pop up everyone I
If this error appears every time you start the computer, then there is a program in your system start up that isn't properly installed. I can't tell you which program without more information. A quick search shows that this is a common problem with DriverCure and FileCure. Uninstall/reinstall them if you have one of these programs.
If you don't know which program it is, then you need to go through your startup programs one by one.
Press "windows key + R" to bring up the run dialog box.
Type in "msconfig" and click "OK."
If the UAC dialog box comes up, click "Continue."
Click on the "Startup" tab.
It will display a list of every program that runs when your computer boots. Uncheck the first box for the program that you think might be causing the problem and then click "OK."
A box asking if you'd like to restart your computer will appear. Click "Restart Now."
A dialog box will appear notifying you of changes to your startup, click "OK" and msconfig will reopen.
If the error reoccurs, then uncheck the next item on the startup tab and repeat until you find the one causing the error. Make note of the name of the last thing you unchecked and uninstall/reinstall that program.
To get rid of the startup notification box, simply check "Don't show this message..." before clicking "OK"
Oct 22, 2012 | Computers & Internet
2004 camry ac light blinking and throws hot air. Suggestions?
My 2003 Toyota Camry AC often starts blowing hot air and the AC light starts blinking. I don't know why the following process works, but it does. Using the temp selector (left) reduce the temperature all the way down to Max Cold and then push the Auto button. It will start blowing out very cold air. After a little while push the temp selector to the desired temperature.
Apr 03, 2012 | Cars & Trucks
Windows 7 too slow
The slowness might be caused by a configuration issue. Follow the steps in the tutorial below to correct problems with your Windows 7 configuration.
Feb 08, 2012 | Microsoft Windows 7 Ultimate 32 bit Full...
I have a 2003 chevy malibu. I'm having problems with my blinker lights. They don't always work when I turn them on and at other times they work just fine. What could cause this?
Hello and welcome. this is almost always the hazard switch. inside the hazard switch is the turn and hazard flasher. the next time the turns dont work, try pushing in and out on the hazard switch and see if they come back on.
Aug 21, 2011 | 2003 Chevrolet Malibu
Circut breaker blows sometimes when heater fist
u probably have a lot on that breaker and on startup units always pull a lot more amps cause starting up is like when u start off in a car u have to push the pedal more to get up to speed once u get there u barely have to push the pedal at all so this is gonna be a problem look on the info plate and see what the amps are or it may say f.l.a. (full load amps)
Feb 25, 2010 | Heating & Cooling
Mtd pro snow blower runs then die
it sounds to me like either the oil pressure switch is being plugged after startup and causint the engine to quit then the plug settles until you start it again and it plugs again easiest way to test is to take the swith and remove the wire to it and see if the engine starts and keeps running, if so then replace the old pressure switch. If this does not solve the problem then the only other thing I can think of is the needle valve is partially pluged, at startup the fuel bowl is full and the engine startsbut after starting the fuel bowl runs low on fuel as it is not filling fast enough and the engine stalls. By the time you try starting it again the fuel bowl is filled again and the whole thing starts all over. Hope This Helps Don
Dec 08, 2009 | Garden
2001 Chev Astro Cargo Van
the problem is your ignition switch.
the connection with the start contact is sometimes missing.
if you want to save money, you can trace the starter wire and hook up a push button wire to start your starter. the other lead of the wire goes to the ignition switch to from the " on " lead so that if you turn off your key, there is no accidental starting of your engine.
tnx 4 using fixya,
drcool
Sep 13, 2008 | 2001 Chevrolet Astro
Won't start on its own but will when gas/starting fluid is placed in the throttle body
Do you here a fuel pump? Ignition switch may be bad also, check the codes, if you geta P1626c it's most likely the ignition switch....
Jul 24, 2008 | 1999 GMC Suburban
35 people viewed this question
jasbo
jasbo
