SOURCE: volume knob
In other words the lever that the front knob is attached to is broken or the microswitch is bad or broken.. if your not a tech please take the unit in to a shop as there are no user serviceable parts inside these units. Good Luck
SOURCE: sound
hi, ya, someimes the POT i.e the volume controller variable resistor loses its contacts with the carbon strip. tru using some switch cleaning solution( NoN Acidic) to clean the POT,let me know
SOURCE: Logitech Z2300 rustling sound on volume knob movement
I would definately not open up the wired remote. As for the rustling sound, I had the same problem with my set (only with a hissing sound instead of rustling). Make sure the output on your computer is all the way up, as well as the volume on whatever media player you are using. That eliminated the sound for me, but it might be a different problem alltogether.
SOURCE: volume control problem
bring good contact luricat cleaner from near radio shack and apply it over volume and move it forward and backward many times.
SOURCE: Wired remote bass control knobs
I'm wanting to know the same thing... But be careful on the pin out of the control you get.
I have an audiobahn 2300HCQ amp... Before I had the 1800. The 1800 came with a remote with 6pin remote cord. I got the 2300 used and did not get a control for it. The plug on the 2300 is a 4 pin plug... I can't figure out how to cross it over correctly to get the 1800 remote to work on the 2300.
I have tools to crimp an end... Just can't figure out the color pin out.
