Question about Admiral Washing Machines
Machine does not agitate. It fills spins and does everything else except agitate.
    President:
  • Admiral Master
  • 1,922 Answers
Your "wig-wag" coil isn't shifting washer transmission into agitate,either bad (open)coils or no power to coils at right time to agitate in the cycle
Posted on Aug 02, 2009
Ge washer whre5550k2ww tub wont spin
It may be the rotor position sensor. i used you tube tutorials. There are many washers that are the same, but different brand names. Matag, whirlpool, kenmore elite oasis, all the same and parts. I got lucky and a cleaning hack. It was to clean between the tob and thre shell. This is located up under where you cannot see, use a mirror and look wherr your detergent, fabric softer and bleach dispensers are. And i found a tutorial on diagnosting code that will do it for you. I think it was holding a cycle 5x for 5 seconds and it will tell you. Whats wrong, Good Luck
Jun 27, 2016 | GE Washing Machines
Why is the agitator not agitating?
Is this a machine withwith an agitator & a fixed drum? If this is the case I would think that the drive belt has stretched or broken.
Jun 28, 2015 | Washing Machines
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
Washer fills with water but will not continue with the wash cycle. There is power to the machine because I can her an electrical humming when I try to start the cycle.
If the water in the machine empties when you move the selector to spin but does not spin, you may have a machine that uses a coupler to connect the motor to the transmission (many Kenmore models and others). When the coupler fails, and they do, then everything will work except for the agitator. If this is the case, you can see it if you flip the unit over and look.
Jan 07, 2010 | Kenmore Washing Machines
Will not agitate 110 92587210 Kenmore Washer
I have 2 words for you: "dog ears".
the dog aggitation ears are what cause the aggitator to aggitate. Those things wear down and not grab after time.
Pretty easy to change out. You just need to pull the aggitator out and change the 4 little plastic ears. Good luck :)
Jul 13, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
GE Profile Washing Machine
There is a clutch which is mechanically engaged to stop the drum during agitation.
If the location pin is worn or bent it fails to engage and the machine tries to wash and spin at the same time.
Only solution is to call for a man who can fit a new clutch assy
May 25, 2009 | Washing Machines
WASHER WON'T SPIN OR AGITATE
Fisher and Paykel pride 5.5. It is about 11 yrs old
Oct 04, 2008 | Washing Machines
Everything works but machine won't agitate
The pull at the bottom of transmission should turn both ways.. one way for spin the other way for agitate... if transmission turns both ways means not locked up and probley bad motor..
Jan 06, 2007 | Amana LWA40A
Washing Machines Logo
116 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
