Question about E-Machines eMachines Desktop PC
I'm getting problems with my computer powering up. I'm getting only a partial power up it seems at times on my E Machine T3140. It takes several tries of shutting down and then restarting before I get the startup of the hard drive and here the fans. Usuaully I get it accessing each drive but it doesn't go to the DOS screen or Windows.
  • djpaystrup Aug 02, 2009
    What's my best line of attack. I back up my data to a external. But I'm no PC repair guy. Should I take it as a best bet. I bought it from Best Buy, but I'm sure the warranty is expired.
  • djpaystrup Aug 04, 2009
    Thanks. I'll try that.
  • 1,959 Answers
It could be several things:
  • Bad CMOS battery; the CMOS battery holds onto information about the last time the machine shut down and last good configuration; a bad battery will fail to hold onto the last good config and try to start in safe mode; a symptom of this is if your clock is constantly wrong
  • Bad Power Supply; the PS needs to fire up everything simultaneously; if any aspect fails to power up, it will prevent the machine from booting
  • Loose RAM
  • Loose plug on hard drive
Please post back with any questions. Best of luck.
Greg
Posted on Aug 02, 2009
  • Greg Margossian
    Greg Margossian Aug 02, 2009
    Unplug and open the machine and check for any loose connections. Make sure the RAM sticks are firmly in place. You should see a small round metal disk. This is your CMOS battery. They are inexpensive and easy to replace. They're held in with small prongs. I'd take this approach and fire up the machine again to see if this fixes your problem before bringing it to a technician. If it works, you've saved yourself some money and if it doesn't, all you've invested is a few bucks and your time.
Konica Minolta 2400 laser printer has a slow, 52 times per minute, yellow lightning bolt flashing on its control panel on the front right of the machine. It seems to be locked up. It wont print or r
Sir bad idea to replace with partial one. Replace with OEM cart Brand New machine counts how many prints for several different parts in the machine when it reaches certain counts on certain part it wants NEW stuff.
Dec 18, 2014 | Konica Minolta Magicolor Model 2400w Color...
I put new fan motor or heat pump now runs all time and doesat seem to heat well but line set going into a coil infurnace is hot
I would check the fan relay and especially the sequencer. I recently came across a problem with an older sequencer which had come partially apart and allowed the thermo disk to keep the fan running continuously. The sequencer controls not only the fan relay (24 volt), but the heating strips(220 volt) as well. Make sure all power is off to the unit and verify. Make a wiring diagram and take several pictures if necessary. Replace sequencer with only an Identical unit, even if you have to order it. The newer sequencers have two metal straps to prevent this problem from occurring.
Feb 15, 2011 | Heating & Cooling
Can the HP 1040 fax be cleaned to remove the two vertical lines that print? How? There is no glass to be cleaned and it does seem that the machine can easily taken apart?
This seems to a hardware problem. Resetting the machine fixes it most of the time.
There are many levels in reset, please try the the next level if the 1st did not fix.
Power Drain:
* Turn OFF the machine, disconnect the power cable from backside of the machine and from wall outlet.
* Press and hold the Power button for 60 seconds.
* Connect the cable and turn ON the machine.
Partial Reset
* Remove the power cable from back side of the machine while its ON.
* Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
* If machine turns OFF, press power button to turn it ON.
Semi-Full reset
* Remove the ink cartridges.
* Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
* Insert the ink cartridges.
NVM Reset
* Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards,
Riztech
Sep 25, 2010 | HP 1040 Plain Paper Inkjet Fax
My Acer extensa4420-5963 has been acting funky for the last three/four days. Started out my date and time went haywire. Clock kept losing time as soon as laptop was turned off and reverted to battery. Then...
First of all the RTC (real time clock, BIOS/CMOS) battery has run out. This means the computer cannot keep the date and time when its turned off and disconnected from the mains. You will need to take the laptop to a reputable PC repair store and have them fit you a new CMOS battery.
As for the power on problem, this well could relate to the CMOS battery being drained but also could be a number of different reasons why it won't power on properly.
In my experience laptops that have problems powering on is either to do with the DC adapter on the laptop that has a dry solder point or the power board is failing.
Either way i would take the computer to be looked at.
Regards.
Jan 25, 2010 | Acer Computers & Internet
HP 7780 says "turn power off then on again"
Your scanner assembly is defective, it will cost more to have it replaced than a new printer would cost.
Dec 20, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
How do we turn off the POWER SAVING MODE on the monitor screen?
Try going into your Start Menu then going into your control panel...then clicking on your "power options"....then switching the options to 'always on'..if this does not work..(as it seems you may not be seeing this because the monitor is in power saving mode) try fiddling with the setup option on your monitor and find a possible powersaving mode enabled function and disable it. every monitor is different so I couldn't really help you here...if this doesn't yield results try another monitor to see if it's the monitor having the problems or the computers video card...the video card could very well be the culprit...
Apr 08, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
E-Machine T6216 PSU fan runs, computer will not boot
It is the power supply. EMachines have a long history of using cheap power supplies. I have replaced over a dozen EMachine power supplies with a 100% success rate. They are easy to replace and can be had for less than $20. Just write down the model number and take that to a computer parts store or remove the power supply and take that with you. Steve
Jan 26, 2009 | E-Machines eMachines Desktop PC
View sonic flat screen monitor
Problem seemed to be a short in the power cable to the monitor. Replaced the power cable and for the time, the monitor is working correctly.
Jul 07, 2008 | ViewSonic VX924 19" LCD Monitor
PC seems powerless except.....
This sounds like a short of some kind or bad power supply or motherboard.
  1. Take any components that are not necessary to boot the computer. Try turning it on again
  2. Try taking all parts (motherboard, power supply) out of the case and then put them back in (I know that sounds weird, but it has worked twice for me before).
  3. If you get to this step, either the motherboard of power supply is shot. The easiest to try would be a power supply. Replace it if you have one laying around or borrow one out of another machine for troubleshooting purposes. This is assuming they are standard ATX power supplies.
Feb 20, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
43 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
