Question about HP LaserJet 4L Printer
I connected the power cord and I get no lights. The printer does not power up
    Scholar:
  • 96 Answers
More than likely your printer power supply has gone bad. if you have had this printer as long as i have, it doesn't owe you anything.
Posted on Sep 25, 2009
On the power and reset it for 15 sec wait for the green to light up but the green light dont light up . keep lighting orange light keep on light up. pls help
switch off your printer. remove power cord from its main source and remove usb cable connection from printer to computer. wait for 5 minutes then connect back the usb cable to you computer and plug in the power cord ,switch on the printer
Sep 02, 2015 | Office Equipment & Supplies
My printer won't turn on. I have tried turning everything off and back on but it still won't turn on.
There is only one way to find out if it is an issue with the printer or the Power cord or Power Adapter.
Normally every HP printer has 2 parts. One cord connects the Printer to an Adapter. the Adapter cord then connects to the Wall outlet.
Now that you have connected the printer to working outlet, Check after 10-15 mins if the Adapter ( black box ) is warm or cold. If the Adapter is warm and the green LED light on adapter is glowing, then it could an issue with the Cord or the Printer.
Try with another Adapter or power cord to diagnose.
For Other brand printers, there should be a power adapter ( black box ) and it should be warm when connected to wall outlet, if it is not warm then it is defective power adapter that you need to replaced. Else it is a problem with printer mechanism.
Regards,
Shawn
May 07, 2011 | Office Equipment & Supplies
I have a HP Deskjet D1560, and with the power cord plugged into a working outlet (I checked), the printer won't turn on. Is it just old? Is something wrong with the power cord or the printer?
There is only one way to find out if it is an issue with the printer or the Power cord.
Regards,
Shawn
May 07, 2011 | HP D1560 Deskjet Printer InkJet
Of 3 lights: green on right and red in center are flashing, unable to stop them.
How to fix blinking lights Printer lights blink in certain patterns to tell you about specific problems. Read this document until you see the pattern that your lights are making. The solution is below each pattern. NOTE: There may be more than one reason why the printer lights are blinking, so you may see several solutions. PRINT CARTRIDGE light RESUME light POWER light Off Off Off c00106861.jpg c00106862.jpg c00106863.jpg Problem
The printer will not turn on.
Solutions
1. Check the power cord or power module connections at both the printer and the power source (power outlet, power strip or surge protector).
2. Try disconnecting and reconnecting the power cord or power module to the printer.
3. Try reconnecting the power cord or power module to the power source or try a different power source.
4. Verify that the printer is connected to a power outlet that works.
5. Make sure there are no additional switches turned off, such as those on a power strip or surge protector.
6. Check the power breaker to make sure the power source is working.
If these solutions did not fix the problem, have the printer serviced. http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud09170&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=59129
Dec 09, 2010 | HP DeskJet 940c InkJet Printer
Printer will not turn on. Lexmark 7100 Series Model 4409-K01
if the printer is plugged in to the surge protector, plug in to the wall socket.. and then chek.. if it is not truning on , check if the power cord connected to the printer is warm ... OR.. if any light is glowing in the power cord..
If the power cord is warm/light is glowing in the power adapter, and the printer is not turning on. then the problem may be with the printer itself...
Oct 12, 2010 | Office Equipment & Supplies
Printer will not power on
Check that the corded power supply is plugged into a live receptacle. Verify by using a lamp with a light bulb to see that it lights before plugging power cord into the wall.
Check that the connection at the printer is ok.
Push the power button, and if nothing happens, you might have a bad transformer either on the cord or in the printer itself, depending on the design.
One can double check by getting a spare power supply transformer or cord and trying it.
Or else, a multimeter should show the voltage printed on the power supply or printer. Check that the voltage is within specifications when plugged into the wall whether it is AC or DC voltage.
Jul 04, 2010 | HP Office Equipment & Supplies
When plugged in power light does not come on
Check you adaptor and the power cord are they supply the power and may be the power section of printer is faulty just connect the power cord in other same printer model for testing.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
May 10, 2010 | HP DeskJet 3650 InkJet Printer
Printer Error Message HP AIO 6210 printer
Hi
If you find the lights flashing, we could try resetting the printer.I have explained the reset procedures below
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Remove the ink cartridges, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
Thanks
Riz
Jan 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
My hp 3310 wireless printer freezes and displays a blue screen (on the printer) with alpha numeric characters
Hi
Try resetting the printer
(Notes - resets will take a while)
Thanks
Riz
Dec 29, 2008 | HP Photosmart 3310 Printer
Alignment failed
Just try to reset the Printer.the pro L series printer can be reseted as follows.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button.
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button.
FULL NVM RESET:-Turn the printer OFF, Disconnect the power cable from printer and from the wall outlet.Wait for 1 minute.Connect one end of the power cable to wall outlet.Press and hold # and 9 button and connect the Power cord while holding.After connecting , release the button.Then Turn ON the Printer.
Feb 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP LaserJet 4L Printer Logo
118 people viewed this question
Seeker5211
Seeker5211
