Question about Hotpoint Aquarius WMA42 Front Load Washer
Programme comes on as test - Hotpoint Aquarius WMA42 Front Load Washer
  • 75 Answers
Hi
with machine on press and hold the on/off button and the start/reset button together untill d OFF shows on display then release.
the test program is now off and you can use the appliance
Posted on Aug 05, 2009
Thermostat is not coming on we are in san antonio is there help out there for us
Reasons for a Blank Screen on a Honeywell Thermostat ...
homeguides.sfgate.com > ... > Real Estate Rental & Lease Basics
Honeywell and other brands of programmable thermostats typically show a blank ...and the batteries can no longer provide power to the screen, it will go blank. ...electrical system, a blank screen indicates there is no power going to the unit, ...
programmable thermostat troubleshoot - YouTube
? 3:35
https://www.youtube.com/watch?v=pNVTAUcBx-U
Sep 26, 2011 - Uploaded by Maxxmentum
Programmable thermostat started to fail and behave erratically after being in service for a few ... My thermostat works but the remotes have stopped working. .... Honeywell CM907 Digital Programmable Room Thermostat user ...
HEAT WON'T TURN ON How Test if your Thermostat is ...
? 2:36
https://www.youtube.com/watch?v=lSJn69EAcAw
Nov 16, 2014 - Uploaded by You can Fix It!!!!
Heater fails to turn on it does not mean you have a faulty heating system ... 4th - Check programming on a programmable
Jan 10, 2016 | Honeywell Programmable Thermostat Heater
My washer wont go into spin cycle. I hear a clicking sound coming from the timer.
It isn't a timer it is a programmer that is probably faulty.
You can test this by setting it to spin in different program cycles.
If it refuses to spin in any , assuming that they are in different places on the programmer,, that may indicate another , different
fault.
A technician should diagnose your fault fairly easily.
Jun 22, 2015 | Washing Machines
I have a hotpoint ultima wf860 washing machine when trying to do a wash it just keeps saying test what is wrong with it ?????
SomeHotpoint's are designed to go into test mode when the start button and the on/off button are pressed at the same time. If you are stuck in Test mode, simply hold the start button down until it comes out of test mode, then hold both the start buttons and the on/off button down until you see 'D:end' (or similar message). Now try a normal wash programme again and hopefully it should be fine. If it goes into test mode by itself, then it may be an indication that there is a real fault, or a faulty programmer board. hope this helps.
Sep 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
The machine keeps showing test. it won't go onto any other programme. it keeps running through the test programme then stops, i then try and put it to wash and it will come up with test again.
http://appliancejunk.com/ge/washer/31-9103.pdf OK, to help you, I have found you your service and troubleshooting manual. Below is a DIY self help. washer link, this will help you to troubleshoot your issue. http://www.acmehowto.com/howto/appliance/washer/washer.php
You should try to reset it, but if that doesn't work, you may find you have a main controller board failure.
Jun 06, 2010 | Hotpoint Aquarius WD640 Front Load...
My smeg dishwasher stopped during a cycle and warning lights E2 come on. suggesting that it has drawn too much water and to contact customer technical services, any idea what i need to do
E2 shows that the water level switch has been tripped or its faulty,interupt the programm and switch off the dishwasher then switch it on ,programm it again and start the washing cycle again,if the problem persist then test the water level switch for possible replacement
Jan 10, 2010 | Smeg Dishwashers
WF220 Hotpoint - burning smell + wash cycle stalls?
The burning smell is coming from motor. Also your clutch is bad where you are hearing the rattle/grinding.
Dec 12, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Keeps going on test cycle
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Mar 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
SamsungG600 - PC Studio programme
Go to START then Control Panel then Add/Remove Programs
now remove ALL installs that you see there. Once that is done Restart your pc and go back there to make sure that there is not a copy still in there. If so Remove it If not Reinstall your program. You probably have either past versions running or pieces of past installs running.
Dale
Jul 28, 2008 | Computers & Internet
Hotpoint wf865
press on off button till test comes up then press on off and start cancel button together for a few seconds
Jun 26, 2008 | Hotpoint Ultima WF865 Front Load Washer
"Test" displays no washing done!
Your test mode is on, maybe accidently. Press "start", "cancel", "on" & "off" together for 10 secs, you will see d/off come on the display. Do the same & the test mode comes on again.
Rate pl.
Dec 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
60 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
