Question about Stanley Bostitch Industrial Manual Flooring Cleat Nailer - MFN200
I am using a Bostitch MFN200 Manual Flooring Nailer and we are having some trouble with it. The cleats go almost all the way into the floor board but are still sticking up about an inch out of the board. What could be causing that?
    President:
  • 497 Answers
2 things come to mind. I've installed Wood Floors for the last 5 years.
Make sure you have enough Air pressure running to the stapler,
and Second, Whack the hell out of it. You can be rough with it. Their designed to take a beating
When u hit it with the mallet, youre opening a valve which shoots the piston and drives the staple into the boards. hit it not hard enough, not enough air is being sent to the piston to drive it fully.
Posted on Aug 10, 2009
    Problem Solver:
  • 14 Answers
Only one of three things will cause this. Either the drive blade has been broken off and not long enough to fully drive the nail or you simply are not hitting it hard enough. Thirdly, 2 inch cleats are for 3/4" floor and 1 1/2" cleats are for thinner flooring or 3/4" floor nailed to plywood over concrete.
Posted on Jan 11, 2010
  • 30 Answers
I few different things could be your issue. Check the flooring specs. Flooring thickness maybe the issue. all flooring require you to use a certain size boot size. if the floors 5/16 it requires a thinner boot sometimes then a 3/4 wood. If you r nailing into certain exotics. Some are so dense they require a pneumatic nailer. also be sure not to nail into concrete. sounds crazy but people have tried it.
Posted on Sep 21, 2009
  • Lou544 Sep 21, 2009
    into concrete. sounds crazy but people have tried it. Also this nailer is not pneumatic on the pneumatic ones turn up the air pressure on the compressor.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
The most common cause is the pressure of the compressor you are using. We had the same problem, but, by increasing the pressure we were able to fix the problem. Pressing the nailer against the floor with more force will prevent it from jumping back and causing the staples or nails from sticking out.
Posted on Sep 09, 2009
My bostitch 201 manual floor nailer is stuck with cylinder in the down position. Brand new refurbished, about 50 2" cleats driven without a problem, then some sort of misfire resulting in the stuck...
Could be bent driver or debris. Easy to check. Remove air supply and nails. Remove the four bolts holding bottom of nailer together. Make note of how the pieces are assembled. Set bottom parts to side move piston in and out of the cylinder. Should be fairly easy to move but should not drop out of cylinder of its own weight. Next insert driver into nose to check for smooth fit. Bent driver should be obvious and can be straightened. If driver looks good, find and remove debris from nose of gun. Good luck with your flooring projects Order spare parts kit to have on hand because drivers will break and bend and the lower bumper will begin to break-up.
Aug 06, 2011 | Stanley Bostitch MIIIFN Flooring Nailers
Nail won't set to allow tongue to enter groove
Your nailer has variable sized plates /shoes bolted to the bottom. I believe that there are about three different thickness available. Take a look at the link below for a parts list showing the sizes available. For a quick fix to drive the cleat deeper, use a thinner bumper below the head of where you strike the nailer. If you manually push down the striker, you can see how much of the driver comes out the bottom. The bumper below the head (black rubber washer) cushions the striker against the body of the nailer. A thinner bumper (you must be creative here) will allow the driver to extend out slightly more. Good luck with your flooring projects.
nailer-parts-c-29443_29458_29679.html">http://www.ereplacementparts.com/bostitch-mfn201-flooring-nailer-parts-c-29443_29458_29679.html
May 30, 2011 | Stanley Bostitch MFN201 Factory...
My MFN-201 cleat driver will not drive the cleats deep enough into the 3/4 inch prefinished bruce flooring. It postitions the cleats fine. It is on the Rachet setting.
There is a piece of rubber under the head called the bumper. This rubber piece is what stops the driver from forward travel. If you remove this rubber or replace with thinner, you can drive nail deeper. Most likely your driver blade may be worn or where driver blade attaches to shaft may be worn. Tool would need to be disassembled to check. Parts are not expensive and available at www.bostitch.com Good luck
Apr 06, 2011 | Stanley Bostitch Mfn201 Manual Hardwood...
What is the correct way to place the nails into the gun? This gun uses both cleats and staples. I am using cleats but it does not seem to be working. I may be putting the cleats in wrong.
If you have a Bostitch MIII FN it is only for cleats. Bostitch doesn't make a universal nailer that takes staples and cleats. The MIIIFN is the "floor nailer" and the Model MIIIFS is the "floor stapler"
Maybe check exactly what model you have and ensure you are not trying to put cleats into a stapler.
Oct 17, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
Can u use a m3 model to nailer 3/8 flooring
yes, you need to shim up the plate of the nailer so the cleat goes thru the "v" of the top of the tounge
May 24, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
Using the BOstitch flooring nailer, good air pressure and using cleats. but when i tap with hammer noting happens. the nailer goes off as if it had gone off but no nail was driven.
1. check to make sure the magazine does not contain a jam.
2. check to make sure the driver retracts fully to allow the cleat to advance
3. Be sure to have at least 90psi and to hit the head hard enough to fully fire the nailer.
Sep 25, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
What size cleat/staple do I use for 3/4 hardwood flooring?
FLN-150 is 38mm staple and FLN-200 is a 50mm staple. you can buy them online in boxes of 1000. I would say choosing between the two depends on the thicknes of flooring you are using.
Jun 20, 2009 | Hand Tools
Question regarding Bostitch MIIIFN or MIIIFS
Read the warranty for Woven Strand Bamboo floors. I think you find this is the wrong tool. You`ll probably find that you need an 18ga 1/4" crown, so it don`t split!
Thanks,
Jeff
May 02, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
5/8 flooring nailer
the base plate may be shimmed, but that unit was designed for 1/2" and 3/4" however, the Bostitch MFN201 Manual Flooring Cleat Nailer Kit will install 1/2"- 5/8" & 3/4"
Feb 17, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
My Bostitch Manual Flooring Nailer MFN200 is only 3 months old and inner parts by the spring have broken....this should still be under warranty , but is there a repair kit
From what I can see at StanleyBostitch.com there is not a repair kit for this tool. Given the age I would take in for warranty service.
Jan 12, 2009 | Stanley Bostitch Industrial Manual...
Stanley Bostitch Industrial Manual Flooring Cleat Nailer - MFN200 Logo
762 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
