Question about GE WJSR4160DWW Top Load Washer
My washer is not draining during the spin cycle
  • GE Master
  • 19,396 Answers
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
Keep a container ready to collect water when you undo pump hose.
If all the rest is OK, test and eventually replace timer board. Problemwith water pump are far more commonly causing this problems thenfaulty timer board.
Parts and diagrams available here.
Posted on Nov 14, 2009
    President:
  • GE Master
  • 1,922 Answers
Not draining your washer at all, pump may be bad or no power to pump, take the drain hose out of the "stand-pipe" where water enters the sewer drain, and lower to floor and see if water drains by gravity if only slowly your pump or hose may have a slug of crud in it blocking drainage to sewer pipe
Posted on Aug 02, 2009
4 Suggested Answers
JULIANFIX
  • 975 Answers
SOURCE: GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Posted on Apr 16, 2008
SOURCE: Washer pauses during spin cycle
Check the filter. I have the same problem and I found an string (slip) in the filter. The filter is back of the front pannel (under the door).
Posted on Oct 02, 2008
miket756
  • 2702 Answers
SOURCE: clothes washer vibration during spin cycles
the vibration and noise is most likely from the drum bearings wearing out to test the bearings try this out,,,
open the door, hold the top of the drum and lift it up, if it has any free lift in it the bearings are going, now spin the drum by hand and you should here the rumble off the bearings
Posted on Dec 29, 2009
Testimonial: "Thanks so much. There isn't a lot of lift, but there is a noise when it spins."
Why does it leak all over floor after last spin cycle?
my washing machine leaks water onto the floor during each spin ...
https://answers.yahoo.com/question/index?qid...
Feb 3, 2010 - During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. ... It happened to us due to over loading. ...something can get betwen the two tubs it this all fails your tub seal is ...
Sep 30, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Softener tray is not draining during wash cycle
This tray empties during the spin cycle not wash cycle. Is the agitator spinning during the spin cycle? If so, you are getting softener on clothes during this cycle as required.
Feb 17, 2015 | Kenmore HE3T Washer
Washer is not completing the spin/drain cycle. Stops spinning and draining.
does it drain out all the water? after it stops or is there still water sitting in the tub?
Mar 22, 2011 | Kenmore Elite 45986 Front Load Washer
Our whirlpool sport will not drain, 5d code has appeared. what can we do
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained and it will try to spin or drain again.
Possible Causes/Procedure
• If too much detergent was used:
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent,
• This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Nov 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not turn on...
My washer makes a wierd clinky sound during wash and rinse cycle and it has began to stop spinning the water will drain but clothes will be soaked. Also sometimes during spin cycle it will agitate instead of spinning
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
High speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
Mar 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
GE WJSR4160DWW Top Load Washer Logo
338 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
