Question about Friedrich ES12L33 12100/11900-10700/8900 Heat and Cool Air Conditioner with Electric Heat - TwinTemp...
Can an AC run without the filter leading to the compressor
Had ac issue and called a serviceman. He said the outdoor filter was clogged, and since he did not have one he took out the filter and just welded a piece of coil to reconnect. He never replaced a filter. It got ac running again. However, now, 3 months later my compressor gave out. Is he to blame?
  • 227 Answers
I would think. If there is a filter somewhere in any mechanical device, its there for a reason. Car, ac, water etc. if it has a filter it has a purpose. Sorry for the bad news, but good luck trying to get your ac to front the bill.
Posted on Aug 02, 2009
Our AC keeps cutting out. It runs for a few minutes then stops. have to switch off and restart. Any idea why? Have emptied water and cleaned filter recently
Look for:
  1. the ac needs air flow thru the indoor and outdoor radiators
  2. the outdoor radiator coil should get warm/hot and produce warm air.
  3. indoor radiator coil needs should get cold and produce cold air.
The ac needs the fan motor(s) working and compressor running and pumping. Compressor skinny copper line hot and thick line cold.
Jul 21, 2015 | DeLonghi Heating & Cooling
Airconditioner will not work
Defective compressor clutch, or ground fault in the ac switch circuit.
Disconnect lead to compressor from ac switch.
Run a fused line from the battery to the compressor, if it works without blowing the fuse, check for fault in the AC switch circuit.
Nov 09, 2013 | 1999 Cadillac DeVille
My ac compressor is not run but blower and the outdoor fan is running
filter is close dust so compressor dont work you will clean filter
Sep 16, 2011 | Kitchen Ranges
My central air unit comes on but it's not cool and
to me it sounds like filter are dirty, need to be cleaned or replaced, home systems, packaged or otherwise are hermetically sealed and should not need freon recharge. Always start with airflow and/or unit being set too low. An AC unit of any type will build ice if a) the filter is plugged up and can't move enough air, b) it has been run without the filter, clogging the coil, again, not moving enough air, c) setting an AC unit below 68 degrees F will almost ALWAYS cause icing, and d) running a standard AC when it's warm inside and cold outside (unless equipped for "low-ambient operation"). When in doubt, a bit of maintenance(thorough cleaning) by someone with AC skills can cure a b, common sense will cure c d.
Reply
Jun 23, 2011 | Goodman CKL42AR42 Air Conditioner
Warning light says Low Refrigerent-AC/Off. I tried to recharge the system but the Compressor won't engage, How do I get the Compressor to come on so as I can recharge the system. Is it a pressure swithch...
in order to recharge the ac you first must clear the trouble code for the ac off warning. when you get this warning the computer shuts down the compressor to keep it from running without the lubricant that is in the freon. clear the trouble code and the compressor will run and you can recharge the ac.
Jan 05, 2011 | 1998 Cadillac DeVille
2002 pontiac grand prix gt AC only blows hot air compressor full of freon and clutch spinning good temp control actuators working corectly narrow ac tube at firewall very cold thicker ac tube at firewall...
i had same problem 2 years ago. the actuator door tube was snapped in half and i used acquarium tubing to splice together. The tube runs along the passenger front well well inside engine and meets under the battery carriage. I could not tell anything was wrong without removing the battery to get a closer look. works like a champ now.
Also: there is also an inline venturi filter that fits in the aluminum tubing on the compressor, it may be clogged. You will have to have the freon sucked out to replace the filter. Check back with me so I can help more if this doesnt solve your problem.
Jun 19, 2009 | 2002 Jeep Grand Cherokee
Ac is showing e6
what does E6 error stand for
Jun 16, 2009 | Carrier Heating & Cooling
Our ac is not giving any cooling effect even after a long running time kindly suggest samsung AST18WJWDB
You need to make sure that the unit is clean and all filters are clean. This includes the indoor coil and the outdoor coil. After cleaning, and still not cooling properly, check that the compressor is coming on. If not, check that the compressor is being told to come on by the thermostat by checking the voltage. If not, then its the control board to the unit. If so then check the leads on the compressor by doing an ohms test on each individual lead and a ground source. Ohms should read infinite. Then test between each lead. If you get a reading less than infinite, then the compressor is bad.
Mar 31, 2009 | Samsung Heating & Cooling
2 problems.. AC Comp cuts out. And Fan will not stop.
Unit#2 -Sounds like the contacts on the master switch are welded closed or the switch is broken, Replacing the switch should fix this unit.
#1 is a little more difficult to diagnose. The compressor is being taken off line by a circuit that protects the compressor from damage either; 1- liquid refrigerant getting back to the compressor which can be caused by something as simple as a clogged return air filter or evaporator coil on a heat pump or 2- overload situation caused by a bad condenser motor or a clogged condenser coil. The first thing you need to do is clean both coils and replace the filter,. Then check to be sure your getting good airflow across both coils. I think it's most likely an airflow issue I hope this resolves the problem GL!
Jun 11, 2008 | Amana PTH123B25AJ Heat Pump Air...
Friedrich ES12L33 12100/11900-10700/8900 Heat and Cool Air Conditioner with Electric Heat - TwinTemp... Logo
128 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
