Question about Hoover H140E Front Load Washer
On completion of wash cycle some garments have black streaky marks, these usually come off with second wash. there is sometimes a build up of "gunge" in door rubber and also in tray for washing liquid and fabric softener
    President:
  • 1,922 Answers
If its oily streaks its your top seal on the transmission and its called "back-wash" youll need a new seal installed or new washer
Posted on Aug 02, 2009
I am getting black streaks on clothes after washing.
Make sure the washer is level, especially front to back. Do not overload washer. Check to see if marks are coming from build up of gunk in the outer bowl.
Apr 09, 2015 | LG WM2301H Washer
Streaky dirty washing
try running some cleaner through the machine on a hot 60-90 degree wash cycle with no clothes in. It may take a few goes to remove the build up of soapscum from the inner drum of the appliance
Apr 09, 2014 | Hotpoint Washing Machines
Producing debris when in spin cycle
2.13.1 Scrud
If fabric softener is used regularly it will eventually cause a build up within the outer bowl. This can
result in black flakes present in the wash load that can stain garments. To remove scrud follow the
procedure below.
Step1: Add a full cup of a good quality dishwashing powder such as Active or a similar product
into the machine.
Step 2: Set the machine to a Heavy Duty cycle, select a Hot Wash temperature, High Water level
and allow the machine to agitate for 10 minutes.
Step 3: Leaving the lid closed, turn the machine off and allow to soak overnight.
Step 4: The following day, turn the machine on and advance to the spin cycle to drain the water
from the machine. After the water has drained, turn the machine off then back on again, and select
a Heavy Duty cycle, Hot wash, High Water level, and allow the machine to complete a full cycle to
ensure that all of the loose scrud and residual detergent has been flushed away.
Note: If there is an extremely heavy build up the bowl will have to be removed for pressure washing
Dec 15, 2012 | Fisher and Paykel GWL11 Top Load Washer
Siemens E14-16 Washing machine is not taking the softener when rinsing and posibly not rinsing completely. the dispenser drawer is clean and flows correctly when filled with water. I have checked the...
Same problem with same Siemens E14-16
Cleaned soap drawer inside out (no more black gunge) but still full of conditioner after full cycle and rinse despite 2 internal valves completely cleared and connected
What could be wrong ?
Feb 13, 2012 | Siemens Washing Machines
I am getting black marks and streaks left on my clothes. I have cleaned the seal after every wash and still it continues. The stains are extremely hard to remove and have ruined a number of garments and...
What you probably have is a build-up of scrud in the machine as a result of an interaction between the fabric softener and the detergent. This flakes off and marks the clothing.
Buy a commercially available cleaner for your machine for this purpose of do one or two cycles using a bottle of white vinegar in the tub without detergent. Clean the machine out doing another cycle using baking soda directly in the drum. Repeat this process if there are still any indications of scrud.
Take care that you use the correct amount of detergent in your machine according to load and water level and do a cleaning run about every 25 wash cycles to clear away any excess detergent that was not caught by the rinse.
Apr 12, 2011 | LG WM2301HW Front Load Washer
I have a whirpool duet. the door is on lock mode and i can not cancel. what can i do
This has happened to me...unplug and plug back in. If possible, start the machine on a normal wash cycle. It will start, then the door will unlock at the 'add a garment' portion of the cycle (usually a few seconds into it). Hope this works!
Jan 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Spin cycle not completing
have you lost any garments in the wash lately? there may be one in your pump causing loss of power on the suction. When the machine spins out, have you noticed a marked decrease in time or just the dampness of the clothes? This is what leads me to believe this is a clog in the pump or the hoses to drains
Aug 31, 2009 | Kenmore 24032\24036 Top Load Washer
Black marks on clothes after washing
Try running a few caps of CLR in the washer (without clothes, of course!) Then run a few cycles with no additives. I've heard that powdered lemonade works also. Might be safer to try first. Good Luck!
May 23, 2009 | Washing Machines
Whirlpool calypso GVW9959Q - Black stains on whites
At the end of the cycle, the wash plate nutates for
approximately 30 seconds to fluff the clothing after the
final spin. The action of fluffing causes the outer wash
plate seal to rub against the stainless steel basket while
they are both relatively dry. This condition causes the gray
discoloration.
RESOLUTION:
An updated machine control, part number 8542693, is
now available. The updated control reduces the fluff time
from 30 seconds to 8 seconds, allowing the clothing to be
fluffed, without causing discoloration.
Gray marks or smudges can be washed out of clothing
after wiping down the basket. The consumer should use
the recommended amount of HE detergent and the hottest
water safe for the fabric or hand wash the garment under
running water. In either case, the fabric must be cleaned
prior to running through the dryer
Feb 14, 2008 | Washing Machines
Black Stains on my whites
discoloration.
RESOLUTION:
Feb 13, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Hoover H140E Front Load Washer Logo
103 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
