Question about Nikon Speedlight SB-600 TTL Flash
My Nikon Speedflash SB-600powers up, but no flash with camera or test button. Has not been dropped.
  • 2 more comments
  • jgelders Aug 02, 2009
    Ready light comes on, there is even a little click when the flash button is pressed, but no flash
    Fresh batteries on both flash and my Nikon D50. No corrosion. STill no flash, but it sounds like its trying to discharge still (the little click still happens)
    If it is a hardware issue with the SB 600 (e.g. flash tube out) is it worthwhile to send it in for repair?
    Very helpful and analytical.
Hi
Does the ready light for the flash successfully come on?
Posted on Aug 02, 2009
  • Anonymous Aug 02, 2009
    Thanks.
    A low battery on the camera or in the flash unit can stop it from getting a full charge, and the flash will fail. Please check all batteries. Any battery leakage may also cause the contact to fail.
    After checking the batteries, and if that doesn't fix it, try adjusting the flash with your hand while taking a picture with the flash. See if it works if you press the flash unit down on to the contact points with your hand while taking the photo. The flash may not be getting a tight fit onto the contacts. If pressing it down while taking a photo helps, you may be able to fix the problem by carefully bending the contacts so they fit tightly.
    Finally, check for any corrosion on all contact points and have them scraped off then test again.
    Let me know how you get on. Please let me know the model of the camera.
    Thanks
    Thank you for your reply.
    It could be a fault with the contacts on the camera or the flash, or the flash itself may not be working. I would have to advise testing the flash on another camera if possible, or testing another flash on the D50, or you may need to have the camera serviced.
    It does sounds like a hardware fault to me somewhere. The tests above should help identify the cause of the problem.
    Best regards
    nLinked
MY SB 600 wont fire. I replaced the battery already but If I test fire it, it wont flash.
If you tried multiple batteries that you know are good and the flash will not fire while on the camera or via the test fire button, this unit will have to be returned to Nikon for service and repair.
Mar 12, 2011 | Nikon Speedlight SB-600 TTL Flash
I have a Nikon D40x with a Nikon Speedlight SB-800. The speedlight is not working. I have the camera on, new batteries in the speedlight and speedlight on. Not powering up. Is there some secret battery...
With new batteries in the flash, and it being off camera what happens when you press the test button. If still it does not flash call Nikon 1-800-645-6689
Aug 14, 2010 | Nikon Speedlight SB-800 TTL Flash
I have a SB-600 press the flash button and it doesn't work. It will not flash.
If after doing a battery test it still will not flash you could look inside the battery compartment to see if there is corrosion. If not call Nikon 1-800-645-6689
Aug 08, 2010 | Nikon Speedlight SB-800 TTL Flash
I dropped my camera now the flash is broken,
Sure. Nikon makes a line of what they call Speedlights. The SB-400, SB-600, SB-800, and SB-900 will give you full capabilities. Older models will give you somewhat less capabilities.
Third-party vendors also make flash units compatible with the D60.
External flash units tend to be more powerful than built-in flashes, which makes sense considering their size and additional batteries. They also move the light source further from the lens axis, reducing red-eye, improving shadows, etc. They also may allow bounce flash, which further softens the light.
May 03, 2010 | Nikon D60 Digital Camera
Postmaster 7200edf
Not flashing when you push the test button strongly indicates that the flash unit needs to be serviced.
Aug 15, 2009 | Nikon Speedlight SB-80DX TTL Flash
I have 2 Nikon D80's and a Bower 724AF speedflash
Set the flash unit to full manual.
Aug 12, 2009 | Nikon Cameras
Flash is not working for a nikon sb-600 speedlight
zoom the flash all the way in so you can see if the flash bulb is broke
Mar 06, 2009 | Nikon Speedlight SB-600 TTL Flash
SB 600 Not resetting...
my sb 600 speedlight won't turn on. Do I need to reset it? It has fresh batteries. Never been dropped
Jan 21, 2008 | Nikon Speedlight SB-600 TTL Flash
Re: nikon 5700 faulty flash
I've had this problem and Nikon repaired it twice for me at about Aus$200 each time.
Recently it happened again.
Quite by accident, I found that I could lift the black on-off main switch and that it comes off the camera body quite easily together with the chrome shutter button.
Inside was a little plastic tab with contact points.
Merely blowing off the dust inside and then replacing the shutter button and on-off black ring appear to have solved the problem for me.
However, my viewfinder and lcd were working normally and not black as  lsvettek said.
I did have a problem with the viewfinder and lcd on yet another occasion and this was a recognised fault which Nikon repaired free of charge.
Nov 09, 2007 | Nikon Coolpix 5700 Digital Camera
Nikon SB-800 Failure
Check by testing flash that I've posted on 1/15/08
atdlee@netzero.com
Oct 22, 2007 | Nikon Speedlight SB-800 TTL Flash
Nikon Speedlight SB-600 TTL Flash Logo
46 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
