I have a problem with my thomson router if i shut the power of the router off then turn it on it shows me the connection is down. so everytime i shut the power off then turn it on i have to restore factory setting it and configure it again !!! Thomson TG585 v7
  • 404 Answers
Hi! I will be more than glad to assist u on this concern..It shows that it dont save the settings of your router.. pls try to go to your routers website and download the firmware of the router and this will fix your concern..I got this issue before with my dlink router and it fix the problem..Its a firmware issue.. the firmware of your router is probably one of the known product issue-kpi..
Posted on Aug 09, 2009
How to connect a rca thomson router to wifi
You are trying to connect to a modem, not a router, the router, a wi-fi version, is what you are connecting to your network.
First, power off all equipment, computer and modem, use the network cable you have connected to your computer from this modem and disconnect from the computer, connect it to the differently colored port on one end of the Belkin, the others have numbers, connect a network cable from one of the numbered ports to the computer.
Now power on the RCA modem, wait until lights are steady, then turn on the new Belkin router, wait until lights are active, just a few moments, then power on your computer, you should now have internet access and be able to locate the manual from the Belkin's website to further your setting up a passphrase or setting up some security on your wi-fi.
Jun 14, 2014 | Thomson Rca / Digital Broadband Modem...
Edimax
Put everything on an Uninterruptible Power Supply (aka battery backup)
Aug 04, 2012 | Computers & Internet
My Thomson 6728 keeps showing ! Profiling requires 20MB free space Shutting Down
Jan 18, 2012 | Thomson Audio Players & Recorders
Everytime i try to get on the internet i get connection error 80028EA1 and when i test my connection i get the ip address but not the internet connection and then the same connection error 80028EA1 shows...
Try the following a reboot can sometime fix a lot of different problems.
1. Shut down PC or PC's (ALL CONNECTED DEVICES)
2. Unplug Router/Access Points
3. Unplug Modem Wait Approximatly 2 Minutes
4. Plug in Modem wait 2 Minutes
5. Plug in Router/Access Points Wait 1 Minute
6. Restart/Reboot PC/Connected Devices.
More Information is needed for further Diagnosis! Thank You and Good Luck!!!
Jun 12, 2011 | Computers & Internet
I formatted my Thomson mp3 6742. Now it shows Thomson when I turn it on, says profiling requires 20mb free space and shuts down.
I've reformatted mine with no problems.
I saved the files and folders before reformatting, then copied them back onto the Thompson 6742. Also make sure to format the Thomson using the FAT32 file system.
Nov 16, 2010 | Computers & Internet
EMule TCP Port 11522 not reachable
Does you norton program have a firewall included with the software? If so, your windows firewall was probably turned off automatically because having two firewalls running simultaniosly can cause a conflict between the two firewalls and therefore will not work correctly.If you have a firewall included with your norton software make sure it is turned on and leave your windows firewall off, other wise turn your windows firewall back on.
As far as your situation with the broadband modem, I have to ask: Is your Thomson hardware a broadband router (wireless/wired), or are you using an access point? (wireless/wired) If you are using a "router" there is no way to set it up to work with the modem the cable company provided you. However, if the Thomson modem hardware is an "access point" the only thing I can suggest is to follow these steps:
1) Pull the power cord out of the back of the modem that the cable company provided to you.
2) Next, plug in your Thomson router in to the ethernet port of the computer.
3) You are then going to configure that device. Start by going to the "network and Internet" section in your control panel. There should be a section in there where you can click that says "setup a new network connection" There should be an option to set up and "access point" and it will search for your hardware. If your hardware is found you will probablybe promped to input information about your router and once that's done it should set up successfully. If it isn't successful by some chance don't give up just yet! Go to step 4-
4) Shut down your computer.
5) next, switch the ethernet cable going from your Thomson hardware to the modem from the cable company.
6) You will then need a second ethernet cable to go from a second port of the Thompson hardware in to the ethernet port on your computer.
7) next, plug the power cord back in to the modem from the cable company and your Thompson hardware and start up your computer.
You should be able to get a wired internet connection if all goes well. If you have a wireless access point go ahead and set up a separate internet connection only this time choose "wireless" and choose your settings. I hope this helps. Feel free to contact me anytime if you have more questions. Happy Holidays!
Rachel
Dec 04, 2009 | Computers & Internet
Can't conect to modem
I have just set up a broadband connection for some neighbours using the Thomson router and had similar problems.
Leave the computer on, power down the router, leave it for a few seconds and power it up again. It worked for me.
But it seems that we have this problem every time i,e if the router is on and you switch on the computer it won't connect, but if the computer is on and you switch on the router everything works as it should. I haven't got to the bottom of this yet.
Feb 18, 2009 | ASUS WL-138G 802.11g/b (wl138g) Wireless...
MY THOMSON DPL580HT DON'T WORK
ur tv was design 2 work on 120 u fried it by applying 220 volts in 2 circut advice usa purchase converte at radio shack change 220 120v cost about 30$ bucks
Feb 04, 2009 | Thomson Televison & Video
Thomson TG 585 v7 Wireless Problem
HI
The following info. might help you fixing the above problem:
For WIRELESS CONNECTION follow these Steps:
(Note: Keep the Ethernet cable plugged in unless we set up
WIRELESS)
1: Click on Home Network
2: Wlan
Click on Configure which is the 3rd last icon on the Top
Make sure that the option-Interface Enabled is ticked.
Channel selection should be ob Manuall.
Wireless channel can be 11( thats what is in my case).
Encryption is again depending on what type of sercurity you wants. I would suggest go for WPA.
After editing the above info. do not fail to note the KEY before clicking Apply
Now just enable the WIRELESS CONNECTION on your PC /
Laptop,
Pull the SSID of your router and Click connect.
It will ask for the WEP/WPA key?
Enter the key and Click connect.
Sep 11, 2008 | Computers & Internet
How can i hook up a belkin wireless g router 802.11g to it
my belkin wireless shows a lock, how do I get rid of that?
Jul 02, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Computers & Internet Logo
205 people viewed this question
David Payne
David Payne
