Question about Garden
Cant remove blade on lawn mower
The blade on my bosch rotak 43 lawn mower is bent and blunted and I would like to replace it. It appears to be held on with a single bolt. I tried undoing this bolt with a wrench but it wont move at all. Is there a trick to removing the blade?
  • Anonymous Mar 14, 2014
    Fix blade to mower
    Genius:
  • 1,114 Answers
Follow directions. See if this works;
Blade Maintenance
�� Warning! Switch off, remove the isolator
key, battery and grassbox before adjusting
or cleaning.
�� Always wear gardening gloves when handling
or working near the sharp blades.
Turn the machine on its right side and inspect
the blade; if blunt or damaged, replace.
Use the following procedure to remove and replace
the blade:
Insert a screwdriver into hole 26 to lock the
drive. Hold the blade 30 using gardening gloves
(not provided) and use a spanner (not provided)
to remove the blade bolt 29, blade washer 28
and blade 30.
Fit the blade 30, blade washer 28 and the blade
bolt 29. Ensure that the blade is the correct way
up (so that this symbol can be seen located
as in figure I) and tighten the bolt 29 firmly.
Ensure the screwdriver is removed before attempting
to turn the machine on.
If this procedure does not work then try the following;
It is not uncommon for the blade bolt to become seized onto the shaft due to all the gunk and moisture on the underside of the deck. Try to soak the bolt several times over with penetrating oil ( WD 40, PB Blaster, etc). Spray the bolt head, the top of the blade where it contacts the shaft, etc. Do this several times and let the penetrating oil soak in. Hit the bolt head gently several times with a hammer to loosen up the corrosion. Then try to remove the bolt per directions.
Hope this helps, if so Please rate, Thanks, and Good Luck!
Posted on Aug 02, 2009
  • elangonel
    elangonel May 05, 2012
    Make sure you turn the bolt head anti-clockwise (Rotak 40) to loosen - these bolt threads are made in the standard European way. If it is still stuck then use a very long handled rachet spanner to gain more leverage - your local bike repair shops could do this in 2-3 minutes. Rotaks usually use a 13 mm spanner.
How do I remove the cracked positioning lever from Bosch Rotak 34-13 lawnmower?
very interesting question
cant get at it from underneath for sure
you can buy the part
best guess is take off the engine hood and pull the whole top to bits till you get to the broken handle
Bosch ROTAK 34 Manuals
Jun 22, 2016 | Garden
Why does grass escape from the collecting box on my new Bosch Rotak 43 mower
Wigmoreman it sounds like the box isn't seated properly. Check that it's sitting correctly and make sure its on the right way.
Oct 20, 2014 | Garden
Why did lawnmover start smoking?
Some how the load was to great on the electric motor so it overheated. My first guess the blade was too dull or the grass too tall and/or thick.
Jun 20, 2014 | Bosch ROTAK-320 LAWN MOWER FOR 220 VOLTS...
Overheats and cuts out after 10 seconds
Sharpen and blance the blade. A dull blade will put more load on the motor causing it to overheat. Another thing to check is that there is continuity between the plug contacts on the cord and motor.
Jun 12, 2014 | Bosch ROTAK-320 LAWN MOWER FOR 220 VOLTS...
Manual for bosch rotak 36 mower
contact the seller or go online to Bosch to see if they have extra manuals posted online. Or ask customer service for help.
Jun 06, 2014 | Bosch ROTAK-320 LAWN MOWER FOR 220 VOLTS...
My bosch rotak 40 mower produced smoke from the handle and made a popping sound , i replaced the on off switch but still not working .
sound like you got some burn wiring ether in the handle or down in the lawn mower probably have to take to shop
May 02, 2014 | Electric Lawn Mower
Lawnmower electric
In most cases its not worth to invest TIME if you have a rotak 40 or so , because of the low quality of Bosch mowers its because of they have take over qualcast brand from England they are now owner , the last years there are mowers that have a belt drive from electric mower ROTAK i have replaced a belt but its takes so many thinking and working time to split and rebuild after that the bearings are also not fresh enough to let it be whats over when its over with the bosch mower get an other brand I've never been in working misjudged restoring so, one machine mainly perform the standard excess tension on the belt which the bearing to excessive heat, the stuff is made to break down. i have this year 20 years behind me in repairing also Bosch powertools and thats not only the problem that its BOsch , no its the Qualcast quality that fits the last years inside the bosch brand. the last 7 years the Bosch powertools are differend by model and price and from bad to perfect. but the most common problem is the working time that you will have on a green rotak mower. if you own a old model Bosch fore 8 years ago then the parts are sometimes difficult to get. difficult to place an correct answer but be warned if its handling a rotak .
Apr 05, 2014 | Bosch Saws
I need insruction BOOK for Bosch Rotak 344 GC LAWNMOWER
Here you go:http://www.bosch-pt.co.uk/boptocs2-uk/modules/oragetblob.dll/Rotak34_manual.pdf?db=ocsr55_s041&item=OCSHEIMWPDF.v$m$d$lobvalues.r55&id=90005,10446,20&filename=Rotak34_manual.pdf
Just copy and paste that into your browser it will take you straight to the pdf for it.
Jul 03, 2012 | Garden
Reassembly of the "control switch" to Bosch Rotak 40 rotary lawn
Taken to local commercial garden machine repairer
Apr 05, 2009 | Garden
Garden Logo
1,994 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
