Where can i find a manual for an old servis 6036 washing machine? im getting error code F2
  • 15,935 Answers
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Top loading Gorenje WT 52113, it stops a few minutes into the washing cycle, an error message comes up on the small digital display, looks like d02?
This washer only has f fail code, they recommend you contact svc person for repair. Fail code for F02: F2 Door lock fault detected The door lock on the washing machine has been detected as faulty or failed to engage correctly.
  • Check that the washing machine door has been closed correctly and is engaging the door lock correctly
  • Check wiring to door lock
  • Check door lock
  • Check wiring at control module or timer
Aug 12, 2016 | Washing Machines
Gorenje wa72145bk erro f2
it your door lock that faulty
Jul 01, 2012 | Washing Machines
Servis 1100 rpm manual needed Moved in into a new house with a Servis 1100 rpm washing machine but there is no manual; As the company Servis does not exist anymore - where can I get a manual...
You will need to type into your search engine/web browser '(make) washer manual' and you might be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
(I have just typed in 'servis 1100 manual' and there are a number of sites from which to select))
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Apr 18, 2011 | Washing Machines
Manual for Servis 1100 rpm washing machine
Hello, try eManualOnline.com or contact the old factory direct
Servis UK PO Box 14, Darlaston Road, Wednesbury, West Midlands, WS10 7TJ
Jul 17, 2010 | Washing Machines
My servis easi logic 1400 doesnt switch over in cycle.
Check the control card for dry joints. This is a common problem with these machines
Jul 04, 2009 | Washing Machines
ERROR CODES ON MY WASHING MACHINE
join todays crowd!!! im in the same issue it is f2 error thatfollowedf suds error huh?
f2 is long drain issue after 8 minutes occurs anf the water valves to machine can be not fully iopoen; unplug ist
next keep off 2-5 minutes tpo clear memory
replug in
check drain hose not kimked
check drain pump inside is the next issue for prom is filled with foriegn objects that is known for this unit!!!! their a tech online kctech thats great try his answer online to use a shop vac and **** out any water in the inside and the hoes: and the drain pump inside the machine: see solution #6 may 2008 posted by washer gut in knasas that is eceptional to follow great day danw.
Mar 19, 2009 | Kenmore Elite 45986 Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Im getting an f2 error code in my copy machine sharp 2020
SHARP 2020 F2-31 ID sensor error SHARP 2020 F2-32 ID pattern reading error SHARP 2020 F2-33 Grid voltage error SHARP 2020 F2-35 Grid voltage error
probably need a part
Oct 15, 2008 | Copystar (023-JF503) Fax
Washing Machines Logo
Top Washing Machines Experts
