Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Pollan weedeater my weedeater will start in the choke position but shuts off before i can move it to the run position
    Novelist:
  • 168 Answers
That unit probably has a high side and a low side screw in the carb. Maybe, the screws are out of adjustment. One should have the letter L along side of it, that's the low side or idle side. The other of course would be the letter H which is the high side. That adjustment is only to be made when the unit is started and idling. When you give it full throttle that's when you adjust the H screw. Factory settings are usually 1 1/4 turns out from dead stop on the L screw and approx 3/4 to 1 turn on the H screw after unit is running. If however, this doesn't solve the problem a simple carb kit can be purchased for about 5 bucks and very easy to install. Good luck.
Posted on Aug 02, 2009
  • Wayne McNeil Aug 02, 2009
My murray weedeater want run off choke why?
Carburetor needs to be rebuilt. I won't even think twice about. the diaphram is on it's way out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/anthony_e4f197748c31eabd
Aug 29, 2017 | Weedeater Garden
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
How to start
Full choke until it tries to start, half choke until it does, and once it's running, open the choke fully and wait a few seconds for it to warm up before using it, as well as 15-20 seconds to let it cool down before shutting it off so as not to warp any metal parts of the engine
Nov 08, 2013 | Poulan WeedEater Hedge Trimmer 25cc Engine
Can't start new stihl weedeater fs 45
The Stihl FS45 has a particular way of getting started as do all the stihl products. We sell Stihl equipment in our store and service and repair them also. The normal starting procedure is to:
Be sure the switch is turned to the ON position which is the negitive sign (-). The (O) is the off position.
Press the primer bulb 3 times.
Move the choke lever to on.
Pull the starter cord three times only. If the engine fires, turn the choke to the off position and pull till it starts.
If the engine did not try to start during the first three pulls with the choke on, you must turn the choke off and pull till it starts.
Remember:Pulling more than three times with the choke switch on will flood the carburator on every stihl product thats on the market.
However, if the units still refuses to start, being its new and still under warrenty, return it to the repair shop that services Stihl products and they will repair it according to warrenty. All parts and labor should be honored at no cost to you. Please provide your receipt and serial number located on a silver tag located on the unit or the mechanic will get it off the unit when he works on it. Either way, it will most likely have to have a new carburator put on it. I hope this helps. Please comment back if this was helpful. Thanks; George
Mar 17, 2012 | Weedeater Garden
Weed eater starts and idles after it warms. When I accelerate it sounds like it is choking itself out or it is starved for gas then stalls.restart and it does it all over. Sometimes it stalls when i go to...
Take out carb and spray with carb cleaner through and into all portals. Blow out with air compressor.and reassemble.
Adjust idle and low and high mixture screws according for proper operation.
Aug 31, 2017 | Weedeater Set (Weedeater)
Weedeater gbi 20 leaf blower will not start, how do I start it and what could be the cause?
Start procedure is, switch igbition on, lever to full choke, pull until it fires once, do not continue pulling with full choke, move choke to central position, crank engine until it runs, once warm move choke to off, if it refuses to start, drain the fuel tank and re fill with fresh mix, remove spark plug and check for a spark by earthing the plug against the cylinder, if after many pulls the spark plug is dry, there is a blockage in the carb, remove the air filter cover, remove the two allen screws holding the carb on, remove the single screw securing the alloy pump cover, under the diaphram is a filter, replace this filter, rebuild and try again.
Apr 23, 2011 | Garden
I need someone to tell me where to start when adjusting the carb.
steps in adjusting a carb
1 take off the air filter case you'r carb will be under it
2 move choke lever to full choke the float should be closed move to to half choke there should be a small gap then move to run float should be all the way open 3 there is one more float in the back of the carb it uses a screw to open and shut the screw should be almost completely screwed in
4 put air filter case back on and if the problem is not fixed then its not your carb and is most likely in need of a new air filter,has bad gas or the fly wheel is not inline with the armature
Feb 27, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
I have a Ryobi trimmer and when I start it will not stay on
Here was my solution:
I was having problems with my ryobi cs30 weedeater also. It would start up fine on full choke, but i could not give it more than half throttle or ever take the choke off or it would stall out. I replaced fuel mixture, spark plug, spark arrestor/exhaust, fuel lines, cleaned carb, and still nothing! I was considering getting a better machine. Then i decided to play with the carb adjustments.(on my cs-30, they are two screws on the carb that have a "L" and "H" next to them) I dont think you can get the specialty tool for adjusting the carb unless you are a repair tech, so i just took a Dremmel tool with the circular cut-off wheel to the head of the specialty screws and made them into "flat-head" screws so i could adjust them with a regular screwdriver (if you dont have a dremmel too, get one!) (As i was cutting into the head of the screws, i also cut into the casing protecting the head of the screws that was in the way, this does not cause any damage to the unit, that casing is only there to keep "un-certified" people from adjusting it for themselves.)
Now to the easy part: The "L" screw adjusts the idle fuel mixture and the "H" screw adjusts the full throttle fuel mixture. turning the screws clockwise make the machine run leaner (less fuel) and counter clockwise makes it run richer (more fuel).
-I started out by turning each screw 1/2 turn counter clockwise and started it up, then as it was idling, i started adjusting the "L" screw as i was moving the choke position to run, after a few full turns counter clockwise of the "L" screw, it was idling perfectly in the run position, then i did the same thing the the "H" screw while holding down the throttle and i got it to run perfectly in the run position. Now it is running way better than it ever has. I hope this helps everyone.
Good Luck!
Mar 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
289 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
