Question about Gateway Computers & Internet
The cpu fan is not working. when i start the computer, the fan starts up, but then it stops when the computer starts to boot up.
    Sergeant:
  • 263 Answers
Could be a heat issue try cleaning the cpu fan or replacing it with a new one.
Posted on Aug 02, 2009
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
It was just this morning when I tried to turn my pc on.. unfortunately it did not. ! when i press the power button on cpu it turns on for a few second like one or two but immediately after it drops the...
Try replacing the power supply - I had a similar problem that was fixed that way. If that doesn't work, it's probably the motherboard itself. The CPU is also possible - have you overclocked it or otherwise cooked it? Is the CPU cooler/fan blocked with fluff, or has the fan been slow (or stopped) - noisy fan is a sign of bearing stiffness/partial seizure which slows the fan and lets the CPU get too hot. If the CPU is fried, you get the symptoms you describe (MB won't start the PS)
Dec 23, 2010 | ASUS M2N-MX Motherboard
Cpu fan > just stops working
Most likely there is some kind of software management of the fan.
Boot to the BIOS CMOS settings, and see whether there is a "Quiet Fan" or "Q-Fan" setting (or the like) enabled.
Disable this by selecting "Fan runs always".
If you could provide the model number of the desktop, I may be able to give you more specifics.
Dec 20, 2010 | Computers & Internet
CPU fan error at boot.. Spin fan manually at power up and it works. Why is this? Fan continues to run just fine until computer is powered down
The fan needs to be replaced. When you provide the "umph" to start the fan, it is able to continue by itself. The exposure to heat and the accumulation of dust and dirt has begun to interfere with its ability to start from a stopped position.
The fan should be replaced with an identical fan - preferably from a new CPU heat sink. Do not replace the entire heat sink unless you are prepared to clean the CPU and apply new thermal grease, etc. It is far easier (and probably just as good) to replace the fan only by removing both the old and new fans and swapping out.
Eventually, starting the fan by hand will no longer allow the fan to run by itself. It is better to make the repair now than have the fan fail and cause the CPU to over heat - possibly catastrophically.
Sep 15, 2010 | HP Computers & Internet
CPU Fan sounds like a jet and computer won't start
It sounds more like the hard drive, the fan has nothing to do with your computer booting up. If the hard drive is starting to go bad it will not boot up, that's what it sounds like your computer is doing. I recommend checking out the hard drive and replacing it.
Jul 02, 2010 | Dell (Fan Only) M/N AFC0912DE, DC12V,...
Zalman VF2000 LED fan starts then stops right after boot
Sounds like a defective fan, something having to do with the thermal probe, it causes the fan to speed up when cpu gets hot and to slow down when the cpu is cool. I suggest returning it for another one
Feb 10, 2010 | Computers & Internet
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
I have a acer travelmate 290 and when i push the power button he start and right after this the processor stop (wont boot) and the light of the cd at the top of keyboard stay open please help me...
It could be many reasons. But worst one could be CPU fan failure. If your CPU fan is not working properly then your computer wont boot but most imp thing is, it could damage your processor coz of overheating.
Another reason may be faulty ram, motheboard problem, hardware failure etc.
so cant say for sure but make sure ur fan is cooling ur processor.
Hope it helps
please rate
Sep 26, 2008 | Acer Computers & Internet
Computer not booting to Windows and sometimes freezes
hiya
this cud be many causes, a corrupt driver or overheating
try booting into safe mode to find out if it is a driver or software issue, if it does not then i wud suggest checking your cpu fan is working as you say it shuts itself off.....as new cpu's have a thermal protection built into them to stop the from cooking.....
let me know if you have any joy
Sep 12, 2008 | Sony VAIO PCV-V200G PC Desktop
Boot-failure
I habe exactly the same problem. I habe the P45 Neo3 Board with E8400 CPU and 4GB Dominator RAM(1066MHz). No signal aber reboot. A Bios-Reset helps vor a Moment, but after Restart, i habe no signal.
Jun 16, 2008 | Intel Motherboard
Computers & Internet Logo
274 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
