Ac unit will not come on
I hit the outside thermostat wires while weedeating unit went off now it wont come on at all i spliced the wires back together like they were still wont come on
    President:
  • 1,922 Answers
Pull the fuse/breaker disconnect panel outside by unit and main breaker inside,remove compressor access panel,re-power unit trace your thermostat wires to the terminals by compressor and short the two term together and see if unit starts,sounds as though you broke wire in more than one place.good luck be careful doing this,its 240 volts at most compressors on a central A/C
Posted on Aug 02, 2009
  • daniel  hendrickson
    daniel hendrickson Aug 02, 2009
    pull the fuse/breaker disconnect panel outside by unit and main breaker inside,remove compressor access panel,re-power unit trace your thermostat wires to the terminals by compressor and short the two term together and see if unit starts,sounds as though you broke wire in more than one place.good luck be careful doing this,its 240 volts at most compressors on a central A/C
My AC unit had been blowing warm air for a couple of days so i went outside to take a look and noticed that the dog had chewed through the thermostat wire so I spliced a new wire in. Since then, the AC...
When you spliced the wires you shorted out the low voltage side of the system..
Now the fuse blew on the circuit board of the furnace or air handler if you are lucky enough to have a fuse in there...
If there is no fuse then the transformer is blown and will need to be replaced...
heatman101
Aug 11, 2011 | Heating & Cooling
Furnice air blows, but my ac unit outside want cut on
if the inside unit is running but the outside unit isn't - I would check the fuses or breaker. I suspect you have a blown fuse or a tripped breaker.
What is also possible is that the 'low voltage' thermostat wire (coming from the thermostat inside the house) has been cut - possibly by a lawn mower or weed eater - or chewed into by a dog.
If this is the case - you easily splice (with all power off) the wires back together using the color of the individual wires.
Jun 06, 2011 | Heating & Cooling
Outside unit won't come on. Drain pas appears dry/.
if nothing comes on (on the outside unit) when you turn on AC (and the inside unit runs ok) I would check the fuses and/or the breaker for the outside unit. I would suspect a fuse blown or a breaker tripped. It's also possible that your 'low voltage' (24V) thermostat wire has been cut (by lawn mower) or chewed into (by dog). If the problem is the low voltage wire you can easily splice it back together - just be sure all power is off.
Jun 06, 2011 | Goodman CKL36AR36 Air Conditioner
I have tried replacing my honeywell twice in the past year. My problem is that I have to push and try and move my thermostat around for the ac to kick on. Once I can get the ac on, it turns off again and I...
Hello, sounds like the problem Is a wiring issue, there might be a loose wire in the wall causing this problem with your thermostat, however usually the wires don't get loose in the wall unless they were spliced. Also, make sure the connections on the thermostat sub base are tight to each terminal and that the thermostat is mounted securely to the wall.
Mar 18, 2011 | Heating & Cooling
We have a RUUD AC unit, model number UAMB-042JAZ. ...
Those are the low voltage wires from the thermostat and transformer. Yes he can just match up the colors and splice with wire nuts or something else to hold the tight. If the transformer got shorted out during any of this it may need to be replaced. Hook them up and if the unit runs, then no problem with the transformer.
May 21, 2010 | Heating & Cooling
My dog chewed up wiring on outside unit and i dont know where they hook up it is a 4 wire set up with red white blue and green large ac unit dog chewed thru little brown wire leading to house and now ac...
That wire is to your thermostat which of course turns the A/C on/off. One thing you can do is to splice the wire back together w/ small wire nuts (available at hardware store or wal-mart, and just hook it up color to color and then tape w/ electrical tape. Make sure you turn your breaker off and turn off the thermostat control.
Feb 11, 2009 | Heating & Cooling
Carrier (outside) Coleman Evcon (inside) Air Conditioning question
transformer has just 4 leads. 2 for primary which is your 110 volts and 2 for secondary which is supposed to be 24 volts ac. if you splice the two secondary wires coming out of your transformer, you should be able to get a 24 v ac there.
the box that you are referring to could be a fire controller that in case of fire, it would shut off the fan and the compressor outside.
tnx 4 using fixya,
drcool
Oct 01, 2008 | Heating & Cooling
I have a Carrier 38tra048340 ac 4 ton unit outside, heater in attic. Thermostat is Totaline P374-1100. Power went out than back on after a few hours due to vehicle crashing into power pole. AC was running...
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Jun 23, 2008 | Carrier Heating & Cooling
Air con
Could be the thermostat or the low voltage line to the outside. Usually a dog chews through it or the weedeater hits it and breaks connection. Turn on cool, go outside and see if it gets 24 volts to the two wires going to contactor (have to take off cover to get to it) DO NOT TOUCH THE CONTACTOR IT HAS 240 V AT ALL TIMES, unless disconnect is thrown, so turn it off. If you aren't getting anything, then it's either the low voltage wire broken somewhere or the thermostat malfunctioning. Make sure you turn off the inside unit before messing with thermostat or you will pop the transformer. If it pulls the contactor in, and you still aren't getting anything, then check for voltage on the load side of contactor (opposite from the inlet or lead side). If you are and you hear a hum from the compressor and the condensing fan motor is running, then it's your compressor. You'll have to remove the top cover to do the next step. Check to see if it when to ground by using a meter set on resistance and with the connector to the compressor removed, put one lead on one of the copper pipes going up to it and touch the other lead against any or all of the pinouts on the compressor. If you get a reading, it went to ground and you will need a new compressor or whole new condensing unit, depending on the age of the one you have now.
Jan 27, 2008 | Heating & Cooling
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
