posted by Mel3540 on Nov 25, 2007
When I turn it on, it stays on about 5 seconds, then all lights start flashing and the buzzer goes off that it is done. It also leaks fluid out from under it then. What could be wrong?
1 Other User Has The Same Problem
Comment by Guest, posted on Nov 27, 2007
Same here. I just got it and had only used it a few times before all the lights started flashing.
Solution #1
posted on Jun 07, 2008
Per the manual, periodically you should clean the rubber lining in the dirty water tank(it comes out). I found mine a little dirty, but after cleaning it, it solved my 'all lights flashing' problem.
I have a feeling is this the solution for most people whose manual mode works fine but, automatic mode stops with lights a' flashing. Why manual still works though is a mystery to me. You'd think all modes wouldn't work then.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Feb 14, 2008
This has a 1 year warranty on it, take it in for repair if less then 1 year. If the hose and tanks aren't on correctly, it can cause problems. Other then that it would have to be taken apart and checked.
This Problem Also Relates To:
Black & Decker CHV1400 Bagless Handheld Cyclonic Vacuum
Black & Decker CHV1500 Bagless Handheld Cyclonic Vacuum
Black & Decker CHV9600 Handheld Vacuum
Black & Decker CWV3630 DustBuster Wet/Dry Vacuum
GE 106585 Upright Vacuum
Bosch BSG81360UC Premium Health Guard Bagged Canister Vacuum
Kenmore 22812 Bagged Canister Vacuum
Can you Help with these Vacuums problems?
Hoover F6212-900 / F6215-900 SteamVac Agility...
It wont **** the water
what could I do to fix it? Answer This...
Repair Service
Find Vacuum Repairman Near You:
