Bosch WFL 2860 Stops Part Way through Its Cycle
The machine stops and sounds an alarm when it is part way through its cycle (not completed the final rinse). If you complete rinse by hand and then try a few times to run it on spin it will eventually start spinning. The first couple of spin attempts its motor sounds (a groaning sound) but there is no motion. It's 5 years old, we're a hard water area and the machine has not been maintained in any way. (I can't move the large screwed in plastic thing in the bottom right hand corner).
  • briandaf Jul 12, 2008
    My Bosch WFL 2680 stops part way through the rinse cycle. It will only carry on when I turn the switch to spin. I can't make the machine do the entire wash cycle uninterrupted, like jrw_barton.
    President:
  • 1,294 Answers
When a machine stops during its rinse period, it is normally a block in your outlet filter. And you say it has not been maintained in any way for 5 years; at least you shd be doing the minimum maintainance like clearing your outlet filter.
Front bottom right, is where access to the filter normally is; get to it and clean out, plug off the wall first. The large plastic is to be turned anti-clockwise to remove, refit carefully after cleaning.
Posted on Nov 26, 2007
TURNED THE WASHER TO OFF, BEFORE FINAL CYCLE COMPLETED. DOOR WILL NOT UNLOCK.. TRIED ANOTHER FULL CYCLE, STILL WONT OPEN??
control knob has to be in a finished position before door will oped if it is and it still will not oped suspect faulty door interlock
Mar 19, 2010 | Bosch Axxis WFL 2060 Front Load Washer
My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
Dec 08, 2009 | Washing Machines
Clicking sound on Washer Spin Cycle
You are quite correct in thinking that it is the motor brushes that are worn.
You need to remove the motor and replace the brushes.
This will solve your problem.
Good luck.
Nov 28, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL 2061 motor starts running and then stops
Hi ! I have problem with my Bosch Washer wfl 2061 .. It was running till stoped to
realease drain water out... But no drain water come out.. I have checked drain water host... Nothing thaere.. Water was still in the drum Tank... Whoever knows this problem , please kindly suggest or help me to do something.. Thanks.. Peace pkurdnirund@hotmail.com , peacepattaya@gmail.com
Nov 28, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Nov 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
My washer stops!
You should check and clean the outgoing water screen to make sure your washer can drain properly. Sounds like you have a restriction in your system.. could be a filter screen or the pump itself. Try the screen first and then cycle a load of wash without any clothes in it to see if it empties the drum completely.
Hope that helps...
Aug 13, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Drum Does Not Turn
The belt that turns the drum has broken.
Mar 11, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WLF 2260
suspect you have filter blocked or a foreign object in pump. put drain hose as low as possible in a bowl and drain as much water as you can undo filter but be carefull, water will come out in considerable quantities. clean filter check nothing stuck in pump impellor
Jun 14, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
418 people viewed this question
Top Washing Machines Experts
