Showing F-5 - Washing Machines
  • 15,935 Answers
"F05" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a block of wood under each front foot of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
The firing order diagram for a 2001 chevy Malibu posted by Perkins48 shows block one as #2 and # 5 and the post by Audie61 shows block one as #5 and # 2
if this is for the v6 engine this is the proper firing order.1-3-5 are in back by firewall, 2-4-6 are in front, the coils from left to right are 5-2, 3-6, 4-1, hope this helps. good-day !
Sep 20, 2011 | 2001 Chevrolet Malibu
Can't find a manual online. What does 5/4 mean, and how do I turn it off? Same for E. My biggest problem is that when I add up numbers with the print function on (for depositing large batches of...
The manual for the Canon P1-DHV is online at http://www.usa.canon.com/app/pdf/calculator/P1-DHV_G_USA_HWB.pdf>.
When the display shows "5/4", the calculator is doing 5/4 rounding which means: 5 or above round up, 4 or below round down. To control rounding press the "5/4" key.
When the display shows "E" the calculator could not complete a calculation. It can be because of dividing by 0, or because the total exceeded 1 trillion, or because the operator entered calculations faster than the calculator could complete them. Press the CI/C key to clear it.
I can't explain why you are not getting a total on the tape. Try the following example from the manual exactly as shown, and let me know if your tape shows the total.
  1. Clear the calculator (press [CI/C])
  2. Choose 5/4 rounding (press [5/4] until "5/4" displays)
  3. Choose add mode (press [DEC] until "A" displays)
  4. Choose cost-sell-margin mode (press [B-T] until "B" displays)
  5. Turn printer on (press [PRINT] until "PRINT" displays)
  6. To calculate: $12.55 + $15.75 - $5.30
  7. Key in: 1255 [+] 1575 [-] 530 [=]
  8. Tape shows: [0. C] ... [12.55 +] ... [15.75 -] ... [5.30 =] ... [23.00 *]
Apr 07, 2011 | Office Equipment & Supplies
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
Phillips magic 5 voice dect fax
phillips magic 5 dect fax showing ''1 pending error''
cant remov e it
Nov 16, 2009 | Philips Office Equipment & Supplies
My mobile is showing only 8 mb space 5 mb used and 4 mb free
my mobile is showing only 1 mb space 3 mb used and 1 mb free in nokia 5130
Jul 17, 2009 | Nokia 5130 Cellular Phone
Show two decimal places
Input the following and try:
  1. Press 2ndF and . the point button. This changes the screen to FIX DEG
  2. Press 2ndF +/- 2 Answer shown is to 2 dec. pl.
  3. If you want it to 5 decimal places, Press 2ndF +/- 5 answer shown is to 5 d.p. and so on
For normal, just take calculator out of FIX so just DEG shows.
Couldn't find you a YouTube video, so text will have to do.
crimsonnightt@hotmail.com
Apr 01, 2009 | Sharp EL-738 Scientific Calculator
I need help with the "if/then" formula on microsoft words spreadsheet
A B C D E F 5 TRUE 5 TRUE 5 TRUE 6 3 6 3 6 3 red blue red blue 27 blue
If :-
=if(A3<=7;A3*5;0)
It will show the resuls 30.
Above table shows if A3 is less than or equal to 7 then A3 should multiply by 5 otherwise result zero. Therefore A3 in this table is less 7 then hence it has multiplied by 5 so result would be 30.
Jan 20, 2009 | Microsoft Office 2003 Basic Edition...
Denon DCM 370 5 disc changer does not show all discs!
Probably drive belt that rotates the carosel inside is not lining up properly,or the belt that moves the laser mech into position,sounds like its just not lining up properly
Jan 04, 2009 | Denon DCM-370 5-Disc CD Changer
Display shows only L and R speakers.
I think you need a digital coaxial wire instead of the composite ones
Nov 19, 2007 | Yamaha HTR-5630 Receiver
Open Questions:
Maytag Bravos MVWX700XL2 won't spin the clothes and is making a weird whining/whirling noise when attempting to do so. Hi, I have a Maytag Bravos MVWX700XL2. It's about five years old. For about a year now, it would occaisinally make a weird noise while washing that seemed to come from the agitator working. I know this sounds funny, but the noise sounded like a chittering squirrel. It didn't do it all of the time, just mostly when I would wash smaller loads. Today I noticed while doing the weekly laundry, that the agitator wasn't fully agitating. It was turning back and forth, but very slowly and not "mixing" the clothes like it usually does. I went though two loads like that, and on the third load, when it was time for the washer to rinse and spin, it started to make a whining/whirling noise and it would not spin out the clothes (but it did drain). The control panel is not giving an error code. I removed the wet clothes and tried to have it just rinse and spin or drain and spin empty and the strange noise continued w/o any success. I have a video of it making that noise that I can post/send if someone can tell me how. I paid over $500 for the washer, and I really don't want to have to replace it this soon, nor do I want a $300 repair bill. My husband is very handy and could fix it if we knew how to properly diagnose the problem so we get the correct part. Based on what I've read, could it be the shift actuator or a broken motor coupler?
Jul 16, 2018 | Maytag Washing Machines
Washing Machines Logo
Top Washing Machines Experts
