Question about LG Refrigerators
LG LCS 26905 Fan won't stop squealing
I purchased this LG two years ago. I heard some squeaking from behind. It became nosier and now squeals. I can see the fan from the side. The fan isn't facing toward to exterior, but toward to coils. I vaccumed the dust, used a blowdryer to blow the dust. I sprayed a lubricant on the rod going to the fan. I even took a bendable straw and sprayed lubricant to the middle of the fan which is impossible to see. It helped just a tiny bit and now its just non stop. It's like Chinese Water Torture in our house. I don't even see a way to take the fan off to clean it. Please help!
    Champion:
  • 363 Answers
These fans have DC brushless motors, the stator is one piece with a disc in the middle. When these fans start to wear out the shaft begins to wobble, this distorts the the rotation of the shaft. This makes the stator disc touch the communtator.Generating the squealing that you are experiencing. But this fan might not be the problem. The freezer fan is behind the rear panel of the freezer draw. It is very hard to detect this problem because the fan spins but not fast enough to circulete the chilled air thru the freezer and refrigerator.
Posted on Aug 05, 2009
How do I fix a squealing or squeaking fan in my portable AC
unplug unit and check play in motor shaft. if it moves perpendicular to the bearing the motor needs to be replaced. There may be something loose causing a squeeking sound. you could check all the screws for tightness.
Aug 22, 2014 | Haier Heating & Cooling
Makes squealing noise
Dirt behind or ballbearing are you shure its the fan ? , the carbon brushes can also made sometimes a noise on the collectors of the commutator circuit if ingrained on the armature.
Apr 13, 2014 | Kirby Vacuums
New brakes squeaking
Sounds like you may have had soft compound brake pads before and now been replaced with metal compound pads.metal pads great for long wearing and long life but squeal a lot and are harder to stop the vehicle.
you can try to give front brakes a good pressure wash or hose the dust off as this is usually the reason for the squealing.
Nov 27, 2017 | Toyota Sienna Cars & Trucks
Squeaking fan belt
I had a book written for you and remembered something basic I learned in electronics school and had to delete it all. Sigh. So with a smile I start all over and hopefully make this short.
Are you certain there is a belt?
Let's assume there is. A belt means a motor is spinning the belt which is spinning another pulley or "wheel". You could be correct that the belt needs to be changed. They stretch over time causing slippage. That is one way you hear "squeak". The other way which I hate and am dealing with on my car right now is the pulley or pulley's themselves.
If you don't have a belt then your motor is directly running your fan. That means the "squeal" is coming from the pulley's bearings. Most fans I have seen come pre greased from the manufacturer and are not made with a hole to squirt a little inside. They are designed with an expected lifespan. That's another story though.
The bearings get too dry and they begin to, well, drag. That drag is the squeal you hear. Your warning sign that pretty soon they are going to stop dragging and just dry up and stop rolling completely. When that happens you may turn your fan on and hear a hum but the fan doesn't work. To simplify this for everyone, the ball bearings inside no longer roll so the fan no longer spins.
You may have a belt and two pulley's (or more like in a car) and have a good belt but a bad pulley. Most people throw away the product thinking it is no longer useable when all that is needed is to loosen a single screw in the middle of the pulley and replacing it with it's exact make giving the device another jillion years of use.
Now for the conclusion. If you find that the pulley is the problem, go ahead and change that belt that has never been changed to save yourself from the squeal you will hear from that new strong pulley making that loose belt squeal.
One last thing. Check by seeing if it wobbles when turned on or feels loose and slightly wobbly when turned by hand, with it turned off of course. Good luck.
Jan 05, 2014 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Fan belt squeaks, changed belt @ tension & idler pulleys still squeals
oh yah have your harmonic balancer cheched because you can change every thing but if the balan. gets out of wack it un alines everything
Dec 28, 2013 | 2003 Ford Ranger Regular Cab
2002 Ford Mustang pulley squealing
Replace the crank pulley before it costs you an arm and a leg. It has caused this problem. don-ohio
Mar 26, 2017 | Ford Cars & Trucks
We have a Pure Source Plus model, no manual as it came with the house we purchased a year ago. Things worked fine then. A few months ago the water pressure lowered and temp changed(became warmer) for the...
the ice maker slows as the tempt in freezer gets warmer . icw cream get softer ect . ck for ice build up in back of freezer and the evap fan motor may be running to slow causing poor air flow . ck these first . mm
Aug 10, 2010 | Frigidaire FRS3R5EMB Side by Side...
I have a GE GSS25IFR side-by-side refrigerator that is making a squealing noise. This sound began a month ago where it happened once in the middle of the night and I couldn't identify it. My wife...
Yes replace the Condensor Fan Motor.
The fan cycles on an off whenever the compressor runs. You will want to replace it right away or your compressor can burn up from the heat. The radiator thing you cleaned is the condensor this is what takes away the heat.The part # is AP4298602 enter your model # or the part # at www.appliancehelponline.com the part is in stock and on sale.
May 12, 2010 | GE GSS25IFR Side by Side Refrigerator
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
Refrigerators Logo
398 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
