Question about HP Compaq Presario V6048CL Turion 64 X2 TL-52 1.6GHz 1GB 120GB 15.4"EZ502UA PC Notebook
HP Compaq Presario V6048CL Overheating
Compaq Presario V6048CL has a new (refurb) motherboard and new AMD CPU, but shuts down during installation of XP Pro while copying files. The heat sink fan is running and increases speed to the max as expected, after which the shutdown occurs. That's what leading me to believe it's an overheating problem. Heat sink compound was applied during reassembly and heat sink pads are all in place. Adding an external, supplemental fan increases the time to shutdown, but it still shuts down. I'm not anxious to put any more money into this unit, but if there's a solution available, I would like to give it a try.
  • HP Master
  • 4,338 Answers
Verify that the Processor is locked in place. This is ussually the case when you r/r a system bd. and cpu.
Posted on Aug 02, 2009
  • HP Master
  • 4,924 Answers
Take a look into bios and see if the the there is a shut down at certain temp is set ..to be sure ..just restore to factory defaults ...but the best thing is to take a look and remove the settings if there is a temperature limit on ..cpu temp...its risky ..but I always let it without limit and it was ok ...
Installing new motherboard, processor, mem, and video adapter. Powers on but no post.
If the beep is a very high pitched tone, turn off the computer. Your CPU is overheating. The thermal paste may not be spread correctly on the CPU or the heat sink isn't properly installed.
Otherwise, it's probably a memory error. This machine takes 2 GB of memory as 2 single GB memory sticks. Try booting the machine with only one DIMM installed. Try each stick individually before getting replacement memory.
I hope this helps.
Jan 27, 2013 | HP Compaq Presario SR1215CL (82916052980)...
Will a AMD Athlon 64 processor work in a Compaq Presario SR1050NX Desktop? My old processor Died and I purchased one of these off of Ebay, now just want to make sure it will work...
No Donnie, the motherboard for the Compaq Presario SR1050NX won't support an AMD Athlon 64 processor.
The reason why is;
A) The Processor socket on the SR1050NX's motherboard is a Socket A. (Also known as Socket 462)
Hp Support > Compaq Presario SR1050NX > Specifications > Motherboard Specifications >
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00072236&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=405454
CPU = Central Processing Unit. Another term used is Microprocessor, or Processor for short.
Look to the right of the CPU heading:
Socket A (Processor socket)
This is the Socket A processor socket used on your motherboard,
http://en.wikipedia.org/wiki/Socket_A
You can click on the photo of the Socket A processor socket, to the upper Right, to enlarge.
The AMD Athlon 64 line of processors came out after the Socket A, and used the Socket 939 first.
Then on to the Socket AM2.
(Socket 940 for some models)
List of AMD Athlon 64 Microprocessors,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors
http://www.weirdstuff.com/cgi-bin/category/10201
Oct 12, 2010 | Compaq Presario SR1050NX (DW257A) PC...
Cpu powers on. Monitor goes to Windows XP and
Dear, This is due loose connection of power cable
(which connect from CPU TO MONITOR). Just check your power, m sure ur problem would be fix out.
Feb 01, 2010 | Generic Memory Compaq Presario SR1215CL by...
Cpu Models to upgrade Compaq Presario sr1920nx
CPU/Processor
  • Socket: 939
  • Supports the following processors:
    • AMD Athlon 64 X2 up to 4800+
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Cpu/Processor Type
Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Dec 22, 2009 | HP Compaq Presario SR1920NX PC Desktop
My cmpaq laptop shuts down by itself after 20 mins...i'm finding difficult to even install a new OS...any solutions
overheating possibly.. when the notebook starts does the fan roar at full speed?? .. if not.. then you have a bad cpu cooling fan
I can trouble shoot more after your reply
Oct 14, 2009 | HP Compaq Presario C770US Laptop
V2311US overheating and shutting down
Try to clean heatsink and fan. Make sure fan is spinning(common problem).
Mar 20, 2009 | HP Compaq Presario V2311US (EC186UA) PC...
My HP Compaq Presario v2000 has new mobo, new CPU
You probably put more than a pin-head size drop of heat grease compound on CPU, thus "bleeding" over on the CPU, effectively overheating processor (very common). In any event, your problem is overheating -that's *the* place to look for now.
gurutim
Mar 18, 2009 | HP Compaq Presario V2000 Notebook
COMPAQ PRESARIO V5000 POWERS OFF RANDOMLY
I do not believe this is OS related.
Dust bunnies under your bed? The CPU might be overheating. Check for dust and lint blockage in the cooling fins at the lower left rear. Vacuum the stuff out.
I have repaired 3 V5000s overheating because of dirt.
When you are trying to solve problems, remove the battery and run on AC. The battery is just another variable to complicate the issue.
Apr 19, 2008 | HP Compaq Presario V5000Z Notebook
HP Compaq Presario V6048CL Turion 64 X2 TL-52 1.6GHz 1GB 120GB 15.4"EZ502UA PC Notebook Logo
127 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
